Everything posted by Crucian
Ignition key controlled positive supply in the engine bay ???
CTHE 1.4 2014
As the title has anyone identified a keyed + in the engine bay ? if so where was it and the wire colour if possible As ever any assistance welcomed
the truth about electric cars
@stonekeeper Possibly
Hmm With the snow this morning (3") the the number of EVs that were falling foul of the hill in our street was surprising, unable to slow enough to make the stop at the junction and equally number (probably) unable to maintain momentum / traction up the incline, could it be extra weight, higher tyre pressures ? driver ability ?
Hello
Welcome (back ??) Plenty of knowledgeable people on here
Windscreen protective grille missimg part?
I have a cover under all of the scuttle (plastic trim the wipers come through), don't know the part number
No oil pressure shown via OBD socket ?
@Rooted I don't have an oil pressure issue I was just wondering why it wasn't displayed but thanks anyway
I'll get me coat
That'll be why then 😂
I have an aftermarket obd hud fitted but there is no oil pressure displayed on it (it has an oil pressure display but just reads 0) any suggestions ? I assume there will be no oil pressure displayed via VCDS but will check later this week
Wing Mirrors not Heating
Fuse 18 is the fuse for the heated function on the door mirrors Check it (may be missing/blown) Wiring harnesses passing through door grommets are a weakness S/w could be defective
Hot and cold air
You'll have air in the heater core it needs bleeding correctly (I don't know how this is accomplished)
Car alarm keeps sounding
excellent, glad it sorted 👍
Rattle when accelerating
My random rattle turned out to be loose rivets in the charger drive pulley clutch plate
1.4 TSI sound improvement
👍 I'll be controlling the bypass valve either determined by RPM or a selector s/w
Will bypassing the exhaust rear back box give much of an exhaust note change ? toying with removing the resonator after that ?? as ever any assistance welcomed
Check for moths / spiders etc in the vehicle, assuming its not scum trying to make you leave it off
Vrs
I can confirm the mud flaps (all round) are simply remove screws, fit flaps tighten screws
DSG Gear Shiftre Switch top part is broken and quite sharp
I sourced mine (VRS fabia) from Skodaparts.com 5E0 713 146 E The gaiter is available from your local vag dealer not a bad price, 5J2 713 123 N DYT It took me about 30 minutes in total to replace
Amundsen Mib2 Map Updates 2023/2024
@langers2k Thought as much Current loaded map is EUR_W_00388
Nav update and Bluetooth gremlins
Hmm the Skoda update portal asks for my vin. obviously there's no update for my 2014 Fabia as it didn't have nav. I've retrofitted and Amundsen+ unit so anyone willing so share a suitable vin. (Private message) that will suit my RNS315 TMBFP65J1F3038497
RNS315 Amundsen+ is an Amundsen head unit that has sat nav, DAB and inbuilt bluetooth
Hmm, Venturing into the map update. (RNS315 Amundsen+ retrofitted into my 2014 Fabia) 1, how do I determine my current Map version to see if I even need to consider an upgrade ? 2, is the Amundsen MIB2 map I see compatible with my nav unit ? Again, any assistance welcomed
