Everything posted by BlueWagon
- Skoda Octavia mk3, CKFC engine, 2.0 TDi 150hp, coolant looose
what should I do
I doubt you'll get a refund but repair should be fine. Might be a simple fix. Is this the first problem you have had with it? If so, one issue isn't really giving you grief. Id just get the mob that sold it to you to repair under warranty and go on living your life. Maybe after 3 or 4 failures you could say it's giving you grief
- Plastic sump plug leaking
DSG 7-speed problems/questions/advice
Really depends on what box it is. The DQ200 doesn't require an oil change. The other 7 Speed wet clutch one does. There was a thread here about the dq200 and the final word was that it won't hurt to change the oil but it won't do much to help. The clutch will likely fail well before an oil related failure occurs and just change it then.
Cut out and won’t start
Surely a fault is present. Maybe need a more sophisticated code reader to get it. I can't imagine its a complex issue if it suddenly happened while driving at low speed and you have compression still. The no spark suggests wiring or plug undone somewhere. I'd say if you can get a decent electronic diagnosis it will show the fault. Eg get a live feed of engine parameters while cranking. Maybe crank angle sensor is simply failed or wire broken or unplugged. Or, engine immobiliser has somehow kicked in
Coolant problems and timing belt replacement advice needed
The person on the phone probably saw that it is a non serviceable item (regarded as a lifetime of engine belt) and ASSUMED it was a chain. Probably an easy mistake to make if you don't know engines well, or Are trying to assure the customer it is fine. I'd agree with them, at 43K it's probably aok for another 150K. The belts are pretty good and in alot of markets, the same engine is Inspection at 240K km and every 30K after.
I think it's more a Mileage thing. The belt is probably fine for ages. The timing belt tensioner and idler is probably the weak link in these, but again, more a Mileage thing. If it were me, I'd inspect it and leave it alone. Inspection on CHPA engine is a 10 min job. Just pop the cover off and look closely as you rotate the engine. I'd replace the water pump though. That will be a problem if it leaks badly.
Possible uneven brake wear
Because you are mostly cruising on the motorway.
Coolant issue
Because the tank is full of air....not coolant. The prongs probably detect coolant conductivity which the coolant is alot more conductive than air. Because the tank is full of air, air likely come out of the cooling system as the coolant circulation happens. When you open the cap, the pressure of the air is released to the atmosphere, so the coolant comes back into the tank. The air pressure in the tank had been holding it down in the engine and other pipes. Coolant tank now has coolant in it, so warning goes off. I'd say this is the issue. I'd keep topping it up as needed Question: Does the coolant tank show low in the morning when the car is cold? Next time you get home, have a look at the level, see if it comes up overnight as the air in the tank cools and contracts a bit.
- Changing Transmission Oil – 2016 Octavia 2.0 TDI (DQ250 DSG)
Coolant issue
That doesn't make sense....the coolant flowed into the tank but went out the hole in the bottom.... Do you mean it came out the cap? What did the mechanic say about the coolant levels?? Does your heater still get hot? If so, then he hasn't bypassed that. Not really understanding why you think he bypassed something but won't admit it. Test the heater I guess. That will confirm. As for the low coolant, I'd be asking the guy why it's so low. Maybe it is just a bit of trapped air comming out. Is it still low now? What happens if you opened the cap now.
Coolant issue
So did the mechanic fix the issue or is it still building pressure. I doubt a mechanic would steal Hoses. Are you sure they aren't on the other side of the firewall? As in the passenger side. Also, wouldn't there be open connections where the Hoses went onto? Can you see that? Maybe google the engine bay or look for cars for sale with a pic under the hood
- Radiator Fan Relay
Octavia mk2 FL repaint
A quick and dirty maybe 2-3K. Maybe a bit cheaper if you just want the lower parts painted black. But the rust will be back within 12 months. Rust comes from inside the panels, not the outside. For a good fix, double the price, and it will be back within 24 months. I'd say just keep it and either do it yourself or don't.
Fuel filter housing screws completely stuck
You'd probably have to bleed the air out. Might happen automatically when it primes. Just make sure all the lines and the filter housing, particularly on the clean side of the filter are scrupulously clean. Don't fill the filter with diesel when youinstall it either. Needs to be actually filtered through the filter.
- Fuel filter housing screws completely stuck
Engine help , cracked mount.
They want to offer a whole lot more than that. Could potentially get it welded but it will always be pretty weak. If the rest is good I'd offer maybe 40% of what they are worth.
Error: tyre pressure loss indicator
I have had error messages from driving on an uneven road surface. Likely related to the different rotation speeds of the wheels. If be considering where you were driving at the time, eg were 2 wheels on the grass or on roadworks or something like that. Maybe even a slightly larger crown on a street. I get mine if I put the wheels up on the crown of a dirt road (to increase the ground clearance).
Adaptive Cruise Control resetting
Mine doesn't reset. Can't really help more than that sorry
Oil Leak
I think you answered your own question... At the back, low down. Look there and you will find it. I'd suggest cleaning the engine well then checking once you have driven a bit.
Superb 3 2.0tdi Coolant Refill From Empty After Engine Replacement
Maybe the matrix does have flow all the time, but I think having the temp set to hot but the fan OFF would be fine. Every cooling system Ive filled I have left the heat up high and just have the fan off. You won't get much cooling with fan off. No idea why people turn it up full blast when trying to bleed system.
- Possibly Done Something Silly! - Got A Skoda Octavia VRS TDI MK2 Facelift 109k Miles - Things to look out for?
Water pump replacement - DIY, or Mechanic with Van,
That's a big difference. Maybe the man with a van is not understanding the complexity of the job. Has he / she done one of these before? Suspect it will be harder to get a warranty if it goes bad from a fly by night dude in a van....at least a garage is a fixed address and you don't have to search the entire country to find them again. I'd be worried old mate in a van will just disappear into the ether if it goes wrong. Google part price. Can't be alot of margin in 250.
Rust on door sill
I think your local panel shop could fix that pretty cheaply as a cash job. Just a bit of surface rust and paint degradation. Small area, easy to mask and blend.
