Everything posted by BlueWagon
cooling fan unit advice
I wouldn't if the fans work and aren't noisy (bearing noise). Mid range maybe ok, or look at a more reputable brand on Skoda part net
Coolant fan issue
Do this, before it gets to 120 degrees preferably....maybe as soon as it starts to rise over 100 Id spin the fan by hand and make sure there isn't something jambing it. Maybe string or something wrapped around it close to the shaft Maybe it needs new bearings or you may be able to lubricate the fan bearing with a squirt of WD40 as a very stop gap solution. Need to open up the bearing cover so that may be hard work/poor access. Replace fan motor??
Broke down in my 1.5 TSI - oil in spark plugs
Is the new PCV installed correctly and is it a good or genuine one. If a cheap ebay rip-off it may still be letting alot of oil past More likely oil entering combustion chamber. Oil or soot? If Oil, then its probably not the poor fuel ratio, maybe the poor AF ratio and injection codes are a symptom of Oil getting onto the O2 sensor If it was soot, then its all about the AF ratio
- Coolant Loss. Heater Matrix?
Start stop system
10 seconds of cranking...must be a half decent battery still unless it was cranking very slowly
1.0 tsi ticking noise on start up
Sounds like a bit of valve train rattle. Change the oil and make sure grade is correct. Maybe a noisy cam phaser or something but seeing as it goes away, probably just a bit of wear. Hell, plenty of engines used to tick and rattle when cold. My old 18R toyota motor was terrible for it. Still ran fine, just rattled when cold
Shaking harshly at 90° C. No error shown in the dashboard.
So it does it at 90, or before it gets to 90? Because thos makes it sound like it doesn't happen if it is warmed up to 90? So how long before 90 does it run rough? Eg, when you first start or say 5 minutes after? Can you explain the sparodic problem? Why exactly did you change it? So are you saying every time between 80 and 90 it runs rough but you can still do 140 kmh no problem? I would avoid just changing parts without good reasoning because it will cost you alot and unlikely to fix much. Really need to do some diagnostic work. For example, next time it runs rough, try stopping and seeing if it idles or you can rev it freely in neutral? Try turning the engine off and restart and see if that helps? Does it blow black (or white) smoke when running rough?
Octavia II Gearbox Drain / Fill Plug
Maybe an aluminium crush washer or O ring? You can put the oil you drain from the box back in if its very fresh. Just make sure you drain into a clean container
Coolant pump belt change
I have not removed one but if you are saying the pulley turns and this the engine turns when you try to undo the bolt, maybe try locking the engine up. If manual try in gear with handbrake on. If auto or dsg need to use a breaker bar on the crank pulley
remove the engine splash shield underneath the front bumper
Grab a few sizes and see what fits. If 40 doesn't, try 45. If too loose, try 43. T45 rings a bell for me but you are the one looking at your car. You are best placed to choose the correct size
Octavia 2013 Tdi estate. Can't get gear shift into reverse.
Do you mean the stick won't move into the right position for 5th and Rev? Maybe a wasp or rat nest blocking the shifter on the box. Have a look while someone moves the stick inside. Maybe a bit of wd40 on selection cables too
Can you select these gears with engine off? Maybe clutch just a bit gummy so won't let you push into the gear. Maybe ride the clutch a bit to clean up the plates
Prepping to do 2.0TSi clutch in future, rear main seal ?
I would and certainly do on any car I have the clutch out of. Also replace spigot bearing and thrust bearing
Walnut Blasting: is it worth it?
Clogged air filter or dirty sensors on intake side??
- Oil cooler
Octavia Mk3 1.4 TSI – Droning or Humming Noise Only With A/C On
Maybe...but what are you going to do about it? Probably wait until it either dies or starts really making a song. Id just be aware of it and monitor it. My Landcruiser one makes a fiar noise and I know its gonna die some day....but probably just let it run on until it stops working
Sounds like the noise of the AC compressor working. If it cools fine and the noise isn't that loud under the bonnet, Id probably just go on living my life and let the compressor work away as it should. My suggestion would be to have someone cycle the AC while you listen under the bonnet if you are really worried, but other than tinkering with the AC compressor its probably a leave it alone kind of thing
Diesel / oil leak in engine bay - safe to drive ?
Why? Can they not use degreaser and a hose? Id do the same if I were you. Just wash engine bay with spray degreaser and water at car wash close to garage. No need for steam clean
Strange whistling/scratching noise from 2014 1.8 TSI
Does it make the sound with engine turned off. Might be easier to answer if we can hear it with the engine turned off
Octavia Mk2 oil filter advice
Personally Id just go to the dealer and get a genuine one. In Aus they are about $35....which isn't too bad for something made in Europe and you know isn't cheap Chinese junk. Or, local auto parts store and get the recommended Ryco or Mann filter. They will have a book with all the applications
Spluttering engine on cold start
Did you check coolant etc after overheating? Maybe water in the combustion chambers. I can't see how a water pump could cause a misfire and stall. No way. If it jambed it would just snap the belt. Im thinking an electrical issue there. Bad earth....
- 2010 Skoda Octavia DSG7 - judder in 3rd at ~2500 rpm, uphill shift hesitation, delayed engagement from standstill
My Mk3 with 7 speed dsg does this if I shift into D or R to quickly after starting. As in less than 1 second after start. I suspect it is just me beating the computer's start up sequence. I dont think its a big problem. Solution: start, wait say 2 sec, maybe put seatbelt on, then engage gear and drive off.
