Everything posted by Cairus
Retrofit ACC by exist Front Assist
Let's take a look at this topic: Skoda Kodiaq VFL Model Control Unit 13: Hardware Number 2Q0907572B Hardware Version H03 Software Number 2Q0907572Q Software Version 0342 What hardware is required: Steering column switch for ACC: 5Q0953502AL ---> NOTE: Depends on the vehicle's production date. Steering column cover for Kessy & ACC: 565858559G 9b9 for Satin Black I bought both for €90. The rest is all software-related. Request password via PM https://drive.google.com/file/d/1gvzALfST6INKoTQLhB5SqGNY11FUr-Gu/view?usp=drivesdk
280 4x4 haldex service
The principle and functionality of the Haldex has remained the same since its development. A multi-disk friction clutch, controlled by oil pressure. I know the part inside out, having supported the assembly line for almost 10 years.
- Blind spot assist retrofit
3th zone AC retrofit
I know...
- Facelift Crystal Style taillights in the VFL
How many you need?
Don't you also need to retrofit the 3-zone temperature flap? Seat heating is a simple job.
MY17 Superb Retrofitted with Direct TPMS
Byte 11 Bit 02 is by my non Superb virtual Cockpit the Activ TPS BAP
Retrofits update
Why don't you do one retrofit at a time? What you're doing is unnecessary troubleshooting.
Retrofits update
If you don't share an auto scan here and say how some of your retrofits were coded and what doesn't work, nobody can give you serious information
wrong coding, assuming the Virtual Cockpit firmware supports it from the Kamiq platform... a polite note, Karoq questions do not belong in a Superb topic
How remove front headrest - 2020 Scala
It is allowed
Light switch Auto mode
If you Change Settings by the light, you have To do a Reset in the Main Settings of this ",Modul," in This examble, light,what you have Change
Misunderstood... Have you connected the switch yet? Coded it in the BCM?
Tested and working coding Octavia mk4
Which module? If you had read the text carefully, you wouldn't have had to ask this point.
This is normal... You can do nothing
Windscreen sensors
Every 2Q camera have SwaP Protection by TSR. Patch IT with the Dataset
Amundsen MIB2 Firmware Update
You mean FW480?
Windscreen sensors
You have unit A5. You can Code the Lane Assist
The rear windows can be operated from the driver’s control panel, but the rear door switches not work.
Child safety lock activated on the driver's side keypad?
