Everything posted by Cairus
- Blind spot assist retrofit
Retrofits update
If you don't share an auto scan here and say how some of your retrofits were coded and what doesn't work, nobody can give you serious information
MY17 Superb Retrofitted with Direct TPMS
wrong coding, assuming the Virtual Cockpit firmware supports it from the Kamiq platform... a polite note, Karoq questions do not belong in a Superb topic
- Facelift Crystal Style taillights in the VFL
How remove front headrest - 2020 Scala
It is allowed
Light switch Auto mode
If you Change Settings by the light, you have To do a Reset in the Main Settings of this ",Modul," in This examble, light,what you have Change
Misunderstood... Have you connected the switch yet? Coded it in the BCM?
Tested and working coding Octavia mk4
Which module? If you had read the text carefully, you wouldn't have had to ask this point.
This is normal... You can do nothing
Windscreen sensors
Every 2Q camera have SwaP Protection by TSR. Patch IT with the Dataset
Amundsen MIB2 Firmware Update
You mean FW480?
Windscreen sensors
You have unit A5. You can Code the Lane Assist
The rear windows can be operated from the driver’s control panel, but the rear door switches not work.
Child safety lock activated on the driver's side keypad?
- Heated nozzles: where in BCM and coding?
What have you done to your Kodiaq today?
- [GUIDE] Activated Android Auto + Apple CarPlay on MIB2 Technisat for €0 (No dealer, no paid codes)
Loss Of Rear Right Lights
You've already released the safety lock on the plug, right?
