Everything posted by Cairus
Tested and working coding Octavia mk4
Sorry, I don't tell everyone everything. A little personal responsibility never hurts. You should learn and understand what you're doing, not code haphazardly.
You have to remove the function in the control unit 09, adaptation, for the channel for low beam left and channel for low beam right.
The Car have SFD 1 or SFD 2? If SFD 2 which PR Code? Basically, SFD 2 and obd 11 do not bring much
Navi and Traffic sign reconition malfuntions
Yes, you need Calibration Error Log is The "No Basic" Error?
IT Dont Work with EU Firmware and HW
Lane assist is dangerous
Correct, only ACC hold the Speed Downhill
mk3 octavia mk3 vrs dsg folding mirrors upgrade
Pre Facelift or Facelift?
Now i unterstand... This is normaly an Audi Feature, but try this: Unit 13 Coding Operation_moden From Mode 1 Change To 2 The Change is 10km/h step To 1km/h
I think I misunderstood it at the beginning. You can set the speed in 10km/h or 1km/h on the ACC lever.
No warrenty: Byte 21 Bit 0-1 pACC_Regulation_on_priority (on off) Bit 2-3 pACC_Reaction_to_end_of_traffic_jam (with or without speed adaptation) Bit 4-5 pACC_Learning_to_drivers_offset (on off) Bit 6-7 pACC_Reaction_to_narrow_places (dynamic_obstables, static and dynamic, off)
A thank you for the post would be a nice gesture ☺️
- Dynamic Chassis Control Retrofit
- Problems with car start-stop system, front assistant, electric parking brake + airbag
pACC you can Turn alone off
Tiptronic Paddle Module Replacement
https://www.oemvwshop.com/3v0951523-whs-pushbutton-for-tiptronic-satin-black-white-p286746/?sti=8398743
Works fine in Octavia
You mean this: 3V0.951.523 / 3V0 951 523 / 3V0951523
following: unit 13, unlock SFD, Coding, CC To active........ Control unit 17, unlock SFD, adaptation, display longitudinal control coordinator, CC active...... Attention, both depend on HW and SW
CC ACC and pACC is SwaP Protection Or did you mean CC in Unit 13
VCDS options on Kodiaq I. FL
You have Odis? Vcp or VC Tool? GeKo for CP?
Mk 3 Octavia Facelift v Non-Facelift
Let's not forget the technical aspects. The facelift model has the significantly better control unit generation
IT dont Work at this Car year
Voice Control & Skoda Connect Services Management Activation????
Yes,
