Trickiejohn
Everything posted by Trickiejohn
  1. I have an SE L 2025 Superb with the Alcantara ventilated massage seats. Only 4K on the clock. Both my wife and I find the front seats more comfortable than the mk8 Passat it replaced, I’ve never used the ventilation, I hope it’s needed in the next couple of months. I drive on average 21 miles each way, with shorter and longer every month 95 miles each way and local journeys. The seats are very comfortable for me at 6 foot tall and slim, the adjustments are easy to setup and work every time you exit/enter the vehicle. The massage options are a boon for my aging back, offering relief over the medium and longer journeys. The only minor issue with driver comfort for me is the centre arm rest is too low down and not adjustable for a comfy rest for my left elbow. I’m used to it now and it’s not really an issue, but initially I missed the adjustability of the Passat centre rest.
  2. 20 years old this year, learned to drive at 17? You’ve put some miles in there mate 😎😂😂😂😂😂😂😂😂😂
  3. Very nice indeed🤩
  4. I’ve done 4,217 miles in my 75 plate 2.0tdi 150 Superb SE L from new. I changed oil and filter at 1,213 miles - no oil consumption visible on the dipstick. Today at 4,268 miles Of 50% A roads and motorway, the rest B roads and small country roads no sign of oil consumption on the dipstick. I can only think that those with noticeable oil consumption drive at higher revs at low oil temps than they need to……….. Or, I’m very lucky with over 30 years of VAG oil burners from the first diesel Vento to this Superb. I have never had significant oil consumption in any of the 7 cars in that time. VW, Audi or Skoda 🤷‍♂️ What do you think?……
  5. The Hyundai Ionic 9 Htac, looks absolutely bl**dy awful to my eyes as do a lot of the large slabs of EV’s. It’s almost as though designing a good looking large EV motor ans style are totally incompatible
  6. On your screen, there should be an icon of the rear of your car with brackets( ) around it click on that it will open the options, the front collision is on there - however you need to un select it every time you switch on the ignition - currently there is NO alternative or ability to switch it off forever 😵‍💫
  7. I asked my friendly AI: AI Overview A rattle from the airbox on a Mk2 Skoda Superb is commonly caused by deteriorated or missing rubber mounting grommets holding the airbox to the engine bay, causing it to vibrate . Other causes include a loose intake snorkel, a poorly fitting engine cover/airbox lid, or broken plastic clips, particularly on TDI models. Common Causes for Airbox Rattles: Failed Mounting Grommets: The rubber mounts that secure the airbox to the engine break down, resulting in direct plastic-to-metal contact and rattling. Loose Intake Snorkel: The air intake ducting (snorkel) leading to the front grille may become loose. Poorly Sealed Airbox Lid: The lid of the airbox may not be seated properly, or its clips may be broken. Airbox Hitting Components: The airbox may vibrate against the engine cover, bulkhead, or nearby hoses. How to Fix It: Replace Rubber Mounts: Check the rubber mountings under the airbox and replace them if they are broken or worn. Secure the Intake: Check that the plastic snorkel is firmly attached to the front grill area. Tighten the Airbox: Ensure all clips on the airbox lid are secure. Using thin rubber or foam tape to seal the box or prevent it from touching surrounding parts can resolve the issue. I hope this helps 🤞
  8. I chose an DSG box for my Superb (I know only available as a DSG, however if I’d have wanted a manual I’d not have bought a Superb). I owned a DSG A3 in the past, nice to drive and the gearbox worked very well. I swopped it out for. Passat estate after 9 months as it just didn’t have the internal or boot space to accommodate family holidays and my hobby.
  9. I found this RossTech info: RichtungsBlinken RBS Rain Brake Support (now BSW BremScheibenTrocknung) RCEPS Rack Concentric Electric Power Steering RD RestDruckventil RFT
  10. I wasn’t aware of that tbo
  11. A decent resolution, I’ll need to see if my SE L has the same issue and do something very similar, thanks 👍
  12. Yesterday, after a very entertaining match at Hereford (who won for a change). Across the road that I was about to turn onto out of the car park was a young family with a girl of about 7 years old, patiently waiting for the pedestrian light to change, I drove slowly out of the carpark the girl just turned around to her Mum, the Superb stopped dead in the middle of the road. Later on the A49 cruise control on, I kept getting messages to Take control of the wheel (or similar) this was despite me haveing both hands on the wheel at all time and looking forward out of the windscreen. Later on the M4 it became every minute or so I was getting the message if I failed to add input to the wheel despite my hands firmly holding it, a couple of seconds later I got the warning sound I moved my hands then, having the Harvard lights come on and the car braking to a stop wasn’t going to be fun. I switched it off then I’d had enough. Maybe it couldn’t see my eyes at night wearing normal clear lens glasses and as the roads have long straights I wasn’t doing much in the way of inputs. Who knows, if it carries on in the dark I will just stop using it.
  13. As my Mk4 SE L has the option to change in the settings, I’d be surprised if it changed automatically to be honest. Check out the settings before travelling would be my recommendation.
  14. Is it possible that when the wing mirror was clouted, it caused a disconnect on the cabling in the wing? A loose connection that’s taken a few years to give way? I had a similar issue on a Saab I owned for about 12 years. Someone in a Ford Escort tapped my rear end (bent all the front on his, just a few small scratches on the huge rubber bumper for me 🥳) one off the day lights on the rear stopped working, I couldn’t figure it out, a mate did after and hour or so.
  15. I’ve a June 2025 SE L, so your software should not be less able than mine. I haven’t yet attempted this to be honest however: In the 2025 Skoda Superb Estate SE L, the 10.25-inch Virtual Cockpit is highly customisable, allowing you to manage phone calls without looking at the central infotainment screen. You can cycle through several distinct display modes by pressing the "View" button on the right side of the steering wheel. YouTube YouTube +3 Key Virtual Cockpit Display Modes for Calls Classic View: Displays traditional circular dials for speed and RPM. The area between the dials can be configured to show a "Telephone" widget, displaying your current call status or a list of recent contacts. Modern/Infotainment View: Shrinks the dials to the sides to make room for a large central display. This is ideal for seeing caller ID photos or navigating long contact lists using the steering wheel thumb wheel. Basic View: A minimalist layout that shows only essential driving data (like speed and range). When a call comes in, a pop-up notification will appear briefly to allow you to answer using the wheel. Extended View: The phone or media information covers the entire width of the display, with your speed shown as a small digital readout at the bottom—perfect if you want your call details to be the primary focus. YouTube YouTube +3 How to Customise the Display Select Layout: Press the lower right button ("View") on the steering wheel to choose one of the five basic layouts. Adjust Widgets: Use the right-hand thumb wheel to highlight a specific part of the display (like the left or right dial "well") and click it to cycle through options until you find "Telephone". Hopefully this will help🤞
  16. @OccyVRS That’s just what I do 😂
  17. My Superb tells me the same sorted data . However, mine will be serviced about every 8,000 miles. Also I find it totally ridiculous that a first oil change is scheduled at 10,000, I’m at 3K and the first change was done (not by the dealer of course) at 1,100 miles, a little later than planned, but life gets in the way sometimes.
  18. Steve, I hope they finally get it sorted for you. After all the cleaning you’ve done on the w/screen, I’m surprised it’s still smearing to be honest. Out of ideas, I asked an AI. The response is below, hopefully there is a gem in there somewhere (I doubt it, you’ve done most if not all of them) The inside of the screen seemed a bit left of field 🤷‍♂️ John Why the Smear Keeps Returning Invisible Contamination Layers: Standard glass cleaners often fail to remove "road film"—a tough mix of exhaust particles, tyre rubber, and road tar. Other culprits include silicone residue from car wash waxes or rain repellents (like Rain-X ), which can emulsify and cause a milky smear when wet. Contaminated Wiper Blades: Even if you clean the glass, dirty or aged wiper blades will immediately re-deposit "gunk" back onto the surface with the first wipe. Over time, the rubber edge also hardens or cracks, preventing it from making full contact with the glass. Wiper Fluid Issues: Low-quality or overly concentrated screenwash can leave its own film on the glass. Glass Imperfections: Micro-scratches or tiny pits from road debris can trap dirt and air, causing the water to smear rather than clear cleanly. Stack Exchange +6 How to Remove It Permanently Deep Clean the Glass: Degrease: Use rubbing alcohol (isopropyl alcohol) or white vinegar to cut through greasy road film. Clay Bar: Use a detailing clay bar to pull out embedded contaminants that liquid cleaners miss. Abrasive Polish: For the most stubborn residues, use a dedicated glass polish or cerium oxide paste to restore a perfectly smooth surface. Restore the Wipers: Clean the rubber edges thoroughly with a cloth soaked in rubbing alcohol until no black residue comes off. If the blades are over 6–12 months old or feel hard/notched, replace them. Refresh the Fluid: Drain old washer fluid and replace it with a high-quality concentrate diluted correctly with distilled water to avoid mineral buildup
  19. Hi Minter. I have a 3 Month old SE L 2.0 TDI estate, not a lot different from yours. 3.1k miles on the clock. My driving is at least 25% small country Somerset roads. I get no rattling on any type of road and my dash is very quiet. Anti collision systems flash on the screen frequently. I’ve had 4 or 5 occasions where it’s just applied the brakes for a fraction of a second. Yesterday for the first time it locked up the front wheels at about 35mph for no apparent reason that I saw. Washer has fast and slow as well as on demand 2 speed. Now the windscreen…….. it’s not run on oil, just from the electric motor. I would, Clean my screen and wipers a couple of times to remove the oil. Have your washed the car and applied a spray finish after washing? This can have a similar effect (don’t ask me how I know 🤦‍♂️). It took about 4 applications of screen cleaner and a decent amount of elbow grease to remove 80% of it. Most of the rest has worn away by now. If this applies to you….. Remember the clean the blades as well otherwise it will be wash rinse repeat sadly
  20. Trickiejohn commented on Legin T's gallery image in Skoda Scala
  21. A bit late, I’d forgotten about this. I have the same issue not able to answer calls with the drivers door open. I can make them 🤷‍♂️ Still not figured out how to (if I can) cancel calls from the steering wheel. It’s the “thing” I miss most about my Passat 😩
  22. There is an option to not have the clock. That’s how mine was set on collection. I did however see the option on the screen to show clock when infotainment is off
  23. I’ll try the using the phone with the door open tomorrow, I don’t expect to get a different response than you did 🤔
  24. I’ve tried this now on a few occasions - it’s never worked for me me 🤦‍♂️
  25. Yes, on a Passat about 5/6 years ago. I did what you’d said. Split the pipes, blew down each one, I had a partial blockage eventually blew it out (a pain) sucked the washer bottle dry, refilled and emptied it again, on 2nd refill all worked well. I did however about a year later need to swop out one of the jets, drivers side if I remember correctly. I syphoned out the majority and bought a cheap syringe type thing with a capacity of about 1/4 pint.
