Everything posted by gregoir
Bulb Failure Warning
Yes, that's what it means...
Yesterday evening I got a warning to check the right hand brake light. The handbook guided me through the dismantling process. Toolkit didn't have the necessary T20 tool. Got the whole fitting out. The handbook does not say which bulb is which, so I pulled them all it and checked them for continuity. All ok, but one was gettered. Changed it. Warning now gone. Is the CANBUS system designed to be sensitive enough to detect a failing filament? Car is 10 1/2 years old and this was the first bulb changed involuntarily.
Rear DRLs?
Thanks. My requirement also for my Mk3(pre face lift). I asked the Skoda dealer several times. They said that it was not possible. They'd done it easily for my Mk3. I must look out an independent specialist for 'Scandinaviam DRL'.
Check oil level warning - level seems fine
I got that warning when cruising along on the M25 in a 2l diesel 150PS Octavia. Three solid lanes of traffic at ~75 mph. Pulled into a petrol station. Dark by then. Level was down to half way between max/min. Waited for 10 minutes and it was still down bought 1l of oil at enormous expense. Topped up. Ok. I now wonder if the steady high speed running pumped a lot of oil to the top half? Got through about 1l between annual services.Warning never recurred, sold it at 145,000 miles.
Sat nav card !
I use Waze on my Android phone. The constant traffic update and route adjustments is much easier for me than a built in system.Magnetic Yosh mounts fitting to a centre vent.
- Battery condition
My Audio Journey
I've got the same model year and Bolero set up. I use the free Waze navigation app. on my Android phone and attach it to the middle vents via Yosh magnetic mounts. The app has been great and advice is always up-to-date date.
Rear springs for towing a caravan
Remember the maximum permissible tow bar weight as well.
French Crit'Air rating for Petrol 1500 Octavia, reg 2018: Euro 1?
I have one on my 2016 1.4 TSI Combi. I'd to scan the V5 which satisfied the criteria. Only a low quality scan was accepted.
Boot Foam Insert
A full kit is available from Skoda. I have a steel full sized tyre and spare. Marked 50mph though...
Boot Foam Insert
I also keep my locking wheel nut key in there. Also a reflective jacket and gloves etc...
Door auto locking inhibit
The option to auto lock is on one of the many menus. The handbook is probably a good start. Not so handy if you are picking up an impatient passenger. But good for security in an urban area.
Clutch change
You will get warnings of the clutch failing. You can eke the life out by driving carefully.If you are towing a caravan then your priorities might be different . I ran a Passat Diesel and an Octavia diesel to similar mileages with no clutch problems.
Front passenger door lock/window issue
A new lock motor is inexpensive if you go for a pattern part. My local trusted garage sorted mine out cheaply a couple of years ago.
Brighter and Better Headlight Bulbs?
My brighter bulbs are lasting well. Not the huge improvement that I was expecting though. My wife's standard Kia Picanto (2019) has better spread of lights and penetration. My eyes are now good enough not to need my varifocal glasses to drive, in theory, but my closer vision needs thespecs for correction.
Noise on Depressing the Clutch Pedal
Recurred only once and easily sorted with the WD 40 PTFE spray.
Are the higher spec seats more comfortable?
I recently did a 5,5hr trip to Dundee. Perfectly comfortable. And on the return. I've only done 48000 miles. Foam does collapse eventually. Apart from early Polos all my VW group cars have been comfortable. Only ever got to 140,000 miles in a Passat diesel. Repair costs to older cars get tedious and expensive. My old Renault 18 TS had extremely comfortable seats even with limited adjustment.
Tailgate button water ingress
I looked at mine yesterday for the first time. Id to hold the tailgate half open on my Combi. I used to test and certify such switch actuators. It looks a superb (no pun intended) design. The moulded rubber diaphragm would be given a very high IP (ingress protection) from me. And it faces downwards. I often take my car through a soft brush automatic car wash with no trouble. That doesn't help you. Don't use a pressure washer close up as others have said. You will cause damage to the car. Seal the number plate lights and the aperture which the switch goes into, if you must, with clear silicone sealant. BTW is your rear window washer working OK? Hope it goes well.
- Tailgate button water ingress
Heard a different squeak from the same area. Another spray with WD-40 Dry lubricant sorted it.
Hi Thanks everyone. I've just had OSRAM bulbs fitted, purchased from Powerbulbs. Night breaker Laser +150% H7 Cool Blue Intense Next Gen H15 Both claim to be 120% brighter. The wider spread of the H7 is noticeable as is the increased whiteness of both beams. And yes, I've a manual thumb wheel adjustment -hidden by the steering wheel.
Just ordered OSRAM from Power Bulbs. Those H15 are very expensive though.Thanks. My current bulbs simply do not illuminate the grass verge. My eyes have been checked by the finest eye hospital in England.
Well, yes, but needs must. I don't want to hit a walker on a dark verge.
After a number of eye operations and getting older, I'm finding it more difficult to drive in dark conditions. My eyes meet and exceed the DVLA requirements. I'm driving with the foglights on to pick up ill -defined road edges, pedestrians and pot holes on dark roads. I know that my 2016 Octavia Mk3, standard halogen bulbs, has an odd bulb covering the dip and DRL. Have you any recommendations for decent, legal and brighter bulbs? Dip and main.
Help with weird noise.
Wheel /tyre imbalance is what springs to mind.
