Key fob
Does the red LED illuminate when you press any of the buttons on the key fob?
Digital Service Record
That''s not true, ANY Skoda dealer can access the service record of ANY Skoda car whether it's in their workshop or not.
Skoda superb exterior temperature sensor
Sounds like water could have got into a connector in the sensor wiring?
Memory card slot not working?
That could be any of them as infotainment systems weren't spec'd by engine size/type. Best to post a photo of the screen.
Reusing a router on another account
I used the same router when we moved from Hampshire to Devon (stayed with same ISP) - connection was FTTC in both cases.
I'm using a 256GB SD card for music (with over 190GB of music on it) with my MIB1 Amundsen
Amundsen playing double CD in the wrong track order
Whenever I rip multi CD albums I always use an MP3 editor to renumber the tracks from CD2 onwards so they follow on from each other, then I make sure all the CDs have the same album name WITHOUT a CD number. So if CD1 has 16 tracks then track 1 of CD2 I renumber to track 17, etc. Works even for 5 CD albums, yes it takes a few minutes but it only has to be one once.
- Infotainment system not switching on. Octavia 3.
Flat Battery
A kaput battery will appear to take charge but won't hold it, as a rough test measure the battery voltage just after getting home and again a few hours later - if the first is over 12 but under 15 and the second is under 12 then the battery likely isn't holding charge. The only way to be sure is with a battery tester which checks the ability of the battery to supply starting current - any workshop or car electrical place will have one.
Finally got to test the all season tyres!
Remember a 4x4 gives you better traction to get moving, but when it comes to braking there's no difference between 4x2 and 4x4 versions it's all down to the tyres - that's when All Seasons will really make a difference.
Battery change
You're wrong there, battery Ah is one of the parameters that can be set/changed in the BMS.
Remove MIB1 folder from Columbus navigation
Those are not MIB1 Amundsen maps. MIB1 Amundsen maps have one file (DBinfo.txt) and one folder (markets). Visit the VW map update site here select Golf until 2015 and Discover Media to get to a link to the correct maps for a MIB1 Amundsen.
What do you use for fuel consumption comparison.
Always used miles per gallon for the 44 years I've owned a car - which works out at miles per litre multiplied by 4.54609 To me litres per 100km is more difficult to use as the numbers are smaller which means to have to use more decimal places to 'see' the difference to any accuracy.
Anyone got any experience of this? - Wireless Apple CarPlay Android Auto Interface for Seat/Skoda MIB 1/MIB 2
Getting fed up with neither Skoda nor VW making updated maps available for the MIB1 Amundsen in my 2015 Octavia (no 2021 maps, still the 2020/21 maps - which Skoda ominously label as 2020/22?), while surfing I found this: Wireless Apple CarPlay Android Auto Interface for Seat/Skoda MIB 1/MIB 2 Seems like less hassle (and easier to 'sell' to SWMBO as it's chaeper) than replacing my MIB1 with a MIB2 during lockdown (and trying to persuade my uncooperative local dealer to do CP removal). Wondered if anyone has any experience of this, or of Unique Auto Developments in general?
Service
When my Octavia was out of warranty I used a local independent - half the price and no hassle/delay getting a loan car. For many years before we moved I used a VW independent near Southampton, was always 100% happy with their work. I only use dealers when I have to - during the warranty period. The last time I used Kwif Fit for tyres they didn't have a clue how to reset the TPMS and they set the tracking up for a different model - so I won't be darkening their door again.
If you have a MIB1 Amundsen (Octavia built prior to May 2015 - which is what I have) then an 8GB card is correct and will have a part number beginning 5E0. The "latest" available maps for a MIB1 Amundsen on both the Skoda and VW websites have not been updated since mid-2020 - which is annoying (especially as the VW website alleges that they were updated in November 2020, but a file-by-file comparison I have done proves they are the same maps as the 2020/21 update in mid-2020 so VW are "being economical with the truth"). The MIB2 Amundsen uses different maps which need a larger SD card with a part number beginning 5L0.
Please help - coolant temp gauge issues
Sounds most like a stuck open thermostat to me?
Speed ,i items to be fitted to all new cars by 2022
Couldn't agree more - I cite Golf 8 and Octavia IV as my evidence.
Oil temperature gauge
No it doesn't - other than the good sense of the driver
70C seems far too low to me for normal oil operating temperature - my 1.4TSI normal runs nearer to 90C (higher on hot days when on the motorway or climbing long steep Devon hills). Plus - my previous car (Audi B7 RS4) didn't remove a 4500rpm rev limiter until the oil temperature reached 70C
New Octavia 2020 vRS?
If stopped they might get asked why they cannot work from home - Devon & Cornwall Police are stopping cars on some of the main routes into their area and asking the purpose of the journey.
Amundsen MIB1 Map Update 2020-2021
Check on eBay, I've got all of my genuine Skoda SD cards from there.
No ignition
Fuse or ignition relay? Check the fuse diagram in the owners manual and give all the relays you can see a jiggle. Failing that you'll probably need a wiring diagram.
Toyota dealership rip off on GR Yaris already ( don't blame it on Covid-19 or Brexit)
Given all the hype around the GR Yaris I think that's a given.
Looks to me like neither VW or Skoda are going to be offering any MIB1 Amundsen updates beyond the 2020/2021 version? Is there some kind of undeclared 5 year (or thereabouts) limit on map updates? I don't plan to change my 2015 Octavia anytime soon, but to get up-to-date maps (or better CarPlay) I may be forced down the unofficial MIB1 to MIB2.5 upgrade route.
