Ignition on but still have "This function is only available with ignition on"
The CAN bus is a twisted pair not a single wire so it should be easy to spot.
2020 Octavia vRS headlight cluster with LED's (maybe corner LED's)
A 2020 Octavia could be a Mk3 or Mk4, which do you have? From your description of the LEDs on the side of the headlights I suspect (but could be wrong!) that you have a Mk4.
Body work details
You need to post in English for us to understand...
The infotainment uses data on the Infotainment CAN bus to tell it that the ignition is on, sounds like the connectors on the rear of the main infotainment unit (usually in the glove box) are not properly seated.
Most reliable option (octavia)
Since you mention 1.9TDI not 2.0TDI I guess that's an Octavia 2? A 2013 Octavia could be an Octavia 2 or Octavia 3, might be helpful to clarify.
the truth about electric cars
I would add to that - and costs to customers as well as quality of service provided. The 12 tonne electric vs 20 tonne diesel rubbish disposal vehicles failed on that last point.
OBD not connecting
There's a permanent 12V pin on the OBD socket, if the fuse to that is blown the diagnostic cable won't work.
Octavia Mk3 - TMPS reset with OBDEleven
I am pretty certain that a Mk3 Octavia will have indirect TPMS. You reset the TPMS using the CAR menu in the infotainment, you do not need OBD11.
As I posted, and which you seem to have ignored, for the layman (at least all the ones I've spoken to who do not have an engineering background, including 2 of my brothers-in-law who are retired head teachers) they assume a system with a battery and an inverter will supply their home during a power cut - so they won't even think about asking the question. You're making the classic mistake of an "expert", failing to understand the thinking of a "Joe/Joanne Public".
My point is that most people will assume that their solar/battery system will provide backup power to their whole house during a power cut - it's a reasonable assumption for a non-technical person to make (battery plus a "magic box" that connects to the mains). So they won't even have asked if their inverter is grid-tied or grid-forming - and the quotes they received when having their system installed are unlikely to have mentioned any restrictions during a power cut, the quotes I've just received certainly made no mention of it and neither did those received by either of my brothers (we're all retired electrical/electronic engineers).
I wonder how many homeowners with solar plus battery are aware of the difference between a grid-tied inverter and a grid-forming inverter? I suspect it's a very small percentage...
- 1.4 TSI CZDA – Turbo Actuator Fault
- Thinking of buying a 2015 octavia 1.4tsi elegance dsg
Low and high beam H7 halogen to led h7 coding
I don't think that's a coding issue, it looks to me like the LED bulbs are too voltage sensitive - and since the BMS allows the voltage to vary between just over 12V and over 14V while driving no coding is going to solve that.
My understanding is that not all solar battery charger/inverters are capable of running in off-line mode (i.e. during a power cut)?
- Are 1.0 TSIs fine with RON91 Fuel (Fuel Lid lists min. RON95)
Changing the bulb type requires changes to the correct Leucht channels in the BCM. What do you mean by "loupes"?
Naigation Maps update (free)
Keep looking on eBay, SOME sellers do list the size - but check it as soon as it arrives, the first"32GB" card I bought was actually 16GB so I returned it for a refund but the second one was 32GB.
I've had an Amundsen for 9 years so I hope I can clarify: 1) You MUST use a Skoda branded SD card. 2) Amundsen reads the maps directly from the SD card. 3) Having 2 map SD cards inserted at the same time can confuse the Amundsen, what I do is buy a Skoda SD card from eBay then quick format it and copy the unzipped new maps onto it. When done remove the existing SD card from slot 1 and insert the new one, and wait for it to be recognised... This has worked for me for the twice yearly updates since 2016.
Car Park Fires, Transporters / Ships, any fires, any EV,s involved or not thread, were they the cause just there and so made fighting the fire harder.
FYI Bristol Airport are building, and will open shortly, a multi-storey car park.
Skoda Electric Models
Since they are wholly owned subsidiaries of Volkswagen AG that's likely unless another car manufacturer wants to buy the brand name - but then they probably wouldn't be able to use VAG parts so would be SEAT or Skoda in name only.
Another Infotainment Query...
Have a look at this thread Infotainment Model Numbers
They're completely different!
