Everything posted by numskull
Ventilacija
Jeste li dali skenirati automobil da vidite koji su kodovi grešaka prisutni? Također, pokušajte upotrijebiti Google prevoditelj, kao ja, da vam odgovorim na koatijskom!
- Close escape
- Close escape
Clutch and Flywheel Replacement - 2.0 Diesel 150bhp manual (2016)
The change cost £1,100 on our MKII CR170 about 6 years ago. That was with a multi-marque indy who always carried out services on our cars at the time.
L&K Shock Absorbers
Great. I have no idea what the costs from a dealer in the U.K. would be, but I’d estimate it’d be 25-50% more than an independent supplier for the same unit.
L&K Shock Absorbers
Thats right, and they also come with a “special” Skoda dealer price too…🙄
Quick Maxidot Question: Superb 3
😳 It could be the Greenline gets the B&W version - just another guess. We like long-boring stories so why didn’t you keep the L&K? Or the other one for that matter?!
DCC Suspension Mystery
The OP is asking for advice. Given you’ve not read their entire post, I’ll clarify; they stated they believe the OE’s units were already replaced. As for age/mileage related failures, our 2016 car OE shocks are fine - they’ve done 49k. The OE shocks on SWMBO 21 year-old Focus are fine. They’ve done 81k. Shocks tend to fail independently, so a failure of all four at the same time would be unlikely in the extreme.
I’m guessing on SEL and above. L&K gets a sort-of colour display.
Can I ask a few basic questions. Have you had the car scanned for DCC faults? If not, you should as it could highlight a system issue. I suggest you find a decent VAG independent to do this as a main dealer will charge a ridiculous sum for this. Have the individual struts been checked? Do you have DCC set to Comfort, Normal or Sport? I ask as Sport can be twitchy at the rear, especially when it’s unloaded. Do the symptoms you describe, happen on all settings?
Rear nearside vent glass replacement
Any chance the local council had been cutting the verge, Lee? Where’s there blame and all that… £500 for any piece of non-heated windscreen glass is completely insane - especially a bit like that - but trade discounts on glass are huge, which explains why glass insurance replacement excesses are so low.
Can I ask which product you used?
I have a - ahem - a slightly creaky flap, so I’ll give this a go, thank you. I also decided to fit a Stop/Restart disable cable and I understand what you mean about the lack of space to get the central lump of the cable installed!
Coasting & ECO Mode
Right. And then one gives a tiny blip to the loud pedal and you’re coasting again. EDIT - yep, zaklee what ^^ said!
Coasting & ECO Mode
You only have to touch the brake and engine braking is restored.
Sacked by my dealer...for complaining about poor service!
Pretty amazing that dealers can sell cars which they have zero ability to properly service. I’d stick with Winchester. Most decent dealers will do a while you wait service.
I’ve had chromed steel caps on ours which I bought from eBay for four years and I’ve had no issues getting them off or back on again.
The 280PS Thread
Yeah, in the Summer it’s fine… well, not the oil, obviously (thank gawd for 5/30!) In the winter it does struggle. Currently 27. Drops to 24 in the Winter. Gentle right foot and using Eco does help, as there are long stretches I can coast. I know what you mean, but I’ve always coasted whenever I could when I had a manual, so it doesn’t bother me. In any event, you can use the paddles to downshift if y’want.
How to remove the lights in the bottom of door card?
If they’re the same as the Superb units, I have a spare which you can have.
The 280PS Thread
^^^^ is what I do, albeit I’ve been using E on my enormous 4 mile round trip to work (🤣) now the weather has warmed-up; definitely improves MPG. My 2016 idles at 1000 in S mode.
Metallic Suspension Knock
Definitely sounds like a loose bracket or other type of fixing. Did you buy from a dealer?
Broken vent tabs on superb
I’d speak to the retailer in the 1st instance however, I’d be very surprised if they’ll be covered under any used car warranty.
It sounds more like a rattle rather than a metal-to-metal sound, but it’s impossible to be sure. Can you, or better still a passenger, try to ascertain where the sound is being produced? Turn off the AC, retract the load cover and drop the rear seats too.
EPC error
It’s to pop in any parts you find that fall off under the dash, so the techs can easily find and chuck them in the bin and say they’ve refitted them…
I would think it will drastically reduce the diode life, as all the fan is doing is circulating hot air inside the headlamp unit.
