Everything posted by numskull
Repair estimates needed.
Please don't - under ANY circumstances. They say they can do it, they'll bodge it and charge you a fortune. It needs to goto a decent bodyshop. I'd estimate that'll be £6-800, plus the wheel refurb, which should be about £80.
Starting to really dislike my Superb - Blower, Clean Air sensor, Missing Databus etc etc - Good NW/Stockport/Manc person required
What AS has asked is, does your car have 6 forward gears, or 7?
How to go about buying a new Superb?
And they wonder why they didn't close the deal and so many are going bust. "I'm fired - but I'm a brilliant closer" said Lance in disbelief. "Drop the "C" from the last word you said; that more accurate!" said Swiss Tony..
traffic information function on superb mark 3 with columbus navigation
Have a look through this thread...
I agree. The 272/276 “280” will be a classic. It’s a real Q car; understated, comfortable, very well equipped - almost ridiculously so in L&K trim - plus it has tried and tested VW 4x4 mechanicals. And they’re very, very fast. And it’s already rare too. Its a keeper.
Rear Jet Washer Wipe Superb Sportsline
Try this…
Quiet tyre recommendations?
It’s more about the depth of the sidewall and the density of the tyre compounds, which are the major contributor to the transmission of tyre roar into the cabin, not the year. Of course, alternatives are available for the owner to change if they wish. Changing from the OE Pirelli P7’s to Conti All Season 2 has dramatically reduced the tyre roar into the cabin. Given they have the same profiles, the reduction is primarily due to the pliability of the tread vs the P7. And being newer, there’s that additional tread depth too.
Yep, they’re quieter than the P7’s, that’s for sure.
Think it’s the same problem on all of ‘em for all owners. I don’t know if any treatment will put a permanent end to it.
Put a good smear of grease like Lubriplate, on the back and centre hub of the wheel and you’ll never have a problem getting them off again. I recall a week or so into my ownership, having to hit all four wheels from the rear with a heavy rubber mallet to remove them, as I wanted to clean the inside and rear rims properly. It was very frustrating and Gawd knows what I’d’ve done if I’d had a puncture during that first week!
Creaking noise on slow manoeuvre fix
Thanks @UndertheRadar. At the moment it’s only the squeeky bed sound I’ve experienced (the ARB is doing it again) so I’ll listen out for the grawncing sound of the arms destroying themselves! That’s after I stop trying to listen for weird sounds from the DSG/Haldex/Diff/Tyres blah blah blah..😂
Is this a different sound to the well documented ARB creaking feature, or could this thread be mistaken for it? (or vice versa for that matter!?)
Just looked under the car and ignore me @JR RS please. I am, not to put too fine a point on it, talking utter bolucks my friend. I think my memory of the frustrations caused in installing the cable at the bottom of the engine must’ve addled my senile old brain even more than I thought!
Our 280 has the longer tray, which I presume therefore, is standard, as I had to remove it to install the RaceChip. Don’t know if it’s a European figment, or an L&K or 280 standard fit but on there it is.
Ignition - Start/Stop button
I did mine a couple of months ago using JFC’s post. 30 mins from start to finish.
280 TSI 2018 Exhaust valve making a buzzing noise
Goodho. How did you sort the broken stud for the actuator?
This is the fix. You’ll need VCDS / OBD11, or contact one of the members here who have it, to help you out.
Yep, it was staining and slight damp on the alternator which alerted the indy who looks after the 280, to the leaking pump; prepare yourself for a big bill.
For ONE?! Bloody heck!
Thanks @Macsamillion. £45 is excellent. Did that include duty and tax? Either way I’ll be getting a set given the failure rate. Weird that the Dodge Hellcat uses an identical system, given Dodge is a brand owned by a major competitor, Stellantis.
I’d imagine without it being on a lift, it’d be almost impossible to get enough heft to get it back on the hanger. It maybe possible if you get it on a set of wheel ramps? I wonder if penetrating oil put on overnight might’ve helped in the removal of the Nylok nuts? Its so typical of manufacturers not to protect components like these which are subjected to constant poor weather conditions and extremes of heat; 6 rubber caps would’ve stopped them corroding. Ahhh well. Just for ease of members, would it be possible for you post the details of the company which supplied the spring in the US? Also the springs they advertise seem to be a different shape to those on the 280, so is there any specific info one needs to provide to them so they supply the correct ones and finally, an approximate cost?
Airbag Theft
😂 Would’ve been ridiculous but alas no: her sister was called Zanthea.
Airbag Theft
My mate went out with and then married a girl called Candice Hunt… absolutely true.
Airbag Theft
Yes, there are airbag thefts but it’s nowhere near on the scale of Cats and the cars themselves. It’s a very amateurish scaremongering communication piece.
Superb Mk4
Interesting. The 280 in Switzerland is £64k at Fridays closing exchange rate 😳 (Dunno what spec that is) vs around £45k for the L&K in the U.K. Also (and this doesn’t make sense, does it?) the Swiss WLTP = 32mpg, which would be close to reality on say a 20 mile mixed drive, but the one shown by cnc shows the U.K. figure at 34.6? So much for “Harmonisation”.
