softscoop
Everything posted by softscoop
  1. There is no way of upgrading the Bluetooth module to connect to 4g or 5g network. All is not lost however. All you need to do is either untick premium Bluetooth in the cars MFD or untick SIM access on your phones Bluetooth settings and the car will just connect like a normal hands free and let the phone handle all of the connections, rather than taking over the SIM and using the cars external aerial as it would do in premium mode.
  2. Interesting, this video shows a solution but you will lose the rolling shutter. Whether that matters is up to you.
  3. Hmm are they talking about replacing the entire projector assembly or just the reflector bowl? On the Superb they are AFS-2 which combines the swivel corner function with a rolling shutter to give different light patterns at different speeds. Replacing the entire projector setup you will definitely lose the rolling shutter function. I've no idea if the corner function will continue to work without that. Is there a reason you want to replace them? Cleaning the projector lenses with a new set of bulbs made quite a difference to mine..
  4. Good luck trying to do it. You will loose the afs function as they use a rolling shutter to create the different light patterns - Hella Variox. https://www.hella.com/techworld/uk/Technical/Automotive-lighting/Adaptive-headlights-663/ I did search before and couldn't find anywhere that did a replacement set of these. I think your best bet would be to get the reflector bowls recoated.
  5. Just to be sure, are you replacing the entire headlight, or just fitting new bulbs?
  6. No they aren't coded to the car. You will need vcds or similar to put the headlights in adjustment mode when you align them.
  7. One illuminated if you have the passenger airbag deactivate optional extra
  8. I'm pretty sure that these type of aftermarket light switches with their own light sensors do not actually send any data to the car. They just act as if you have turned the light switch on yourself.
  9. Pretty sure the reset procedure is the same but you use the left+right+mic button
  10. Those files are for the newer MIB Amundsen units in the MK3 Octavia. The only way to update the maps on yours is to buy the upgrade SD card. Skoda used the same names, Amundsen and Columbus across several totally different generations of products which makes searching for the older units more difficult. The Amundsen+ is the same (albeit with different logos) as the RNS315. Have a search for RNS 315 maps, there are a few places where they are available, but I think there is a Skoda/Seat specifc set of maps which you must use.
  11. If you have one fitted that worked with an Android HU, chances are it's a composite feed. You'll need a composite to RGB converter. https://www.ebay.co.uk/itm/387075546283?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=d9az2whhqnc&sssrc=4429486&ssuid=Ivbg29OuQe6&var=&widget_ver=artemis&media=COPY I'm not 100% sure if that is correct, as most are to convert an existing RGB camera feed to cvbs, but from the picture it looks like its the correct way round for your use.
  12. Yes the Columbus supports reversing camera. There are plenty of threads on here about the correct camera etc to use.
  13. How old is your battery?
  14. Any car that is 23 years old can have problems regardless of how well it was built in the first place. It could be something as simple as the windscreen has been replaced and the adhesive is failing letting the water in.
  15. You have an ABS fault. All three systems ( ESP, ABS and tyre pressure monitoring) rely on the ABS data. The only way to know what is bringing up the fault is too read the car with diagnostic tool, as a number of issues can cause an ABS error bringing the lights on.
  16. A broken spring can also cause this. Only a small bit may break off making it hard to spot, but means the spring doesn't fully sit in correctly and can move about in certain manuvers
  17. Amazing that these still are coming out of the woodwork. BP05 LOF https://www.facebook.com/marketplace/item/3948881425339693/ Nice spec with ESP, xenons and satnav.
  18. I would be very surprised if they pay anything out at all if the damage is caused by a fault resulting in leak rather than a flood. Insurance and warranty against faults are two entirely different things.
  19. If you're having ABS issues that could be the cause of it. The car relies on the speed data from the ABS sensors on all wheels to determine what gear it needs to be in and also whether to limit or cut power from the engine entirely if it thinks the wheels are locking or spinning from lack of grip etc. When my Octavia had a faulty ABS cable it had exactly the same symptoms with the gears, not changing up or down correctly as the car didn't know what speed it was doing so couldn't calculate what gear to choose. Get any ABS issues fixed before you look at anything else, but the get the oil and filter changed on the gearbox as said above, it's a 40,000 mile interval.
  20. You should have no problem with battery draining if you fit a Stream MP3.
  21. None of the MK1 Octavia had a DPF. On the MK2 it's a bit more complicated. The 1.9 PD in the MK2, regardless of the trim never had a DPF fitted.. in the UK at least. All of the CR diesels in the MK2 have a DPF. These replaced the PD engines in early 2010. Some of the early facelift cars got the PD engines without the DPF. The vRS diesel MK2 had a DPF from when it launched in 2006- this was on both the PD and CR engined VRS. The 4x4 2.0 PD had a DPF from when it launched. The 2.0 PD fitted to the non-vRS and non-4x4 models did not have a DPF. Hope that helps.
  22. I'm pretty sure that needle staging isn't possible on the pre facelift cars, regardless whether you have maxidot or not.
  23. You can flatten the beam so you won't dazzle when driving on the wrong side of the road with this guide. https://www.briskoda.net/forums/topic/280456-european-headlight-adjustment-octy-ii-fl-halogen-lights/
  24. Yes they are identical
