Everything posted by Sanqhar
New SE L boot rattle
Just been out to the car to check, forgot I had a wardrobe in bits in the back (Varioflex seats removed), I just love this car. DSL's picture is like mine showing the "top hat" unscrewed (and sitting at the bottom right hand corner). The centre screw wobbles enabling you to get the spare in the optimal position before tightening. tom
Is the spare wheel loose There is a large screw that sticks up from the bottom of spare wheel well. My memory is that it is a bayonet fitting (like a light bulb) except it can turn all the way around and fixes in two positions. In the loose position it will lift out. There should then be a second black plastic "top hat" that screws down on the screw above fixing the wheel in place . The "top hat" also supports the boot floor. If you have the "top hat" piece in position and the two are turning together, then in the resistance position try unscrewing it while pulling. When you can, visit a dealer and look at one of theirs. tom
Water Ingress - Passenger footwell
There is another thread on this subject on the "other" forum. https://www.karoqforums.co.uk/viewtopic.php?f=11&t=561 Rejecting advice here: https://www.honestjohn.co.uk/problems-with-a-new-or-used-car-your-consumer-rights/ tom
Flashing glow plug light symbol, first fault?
There are other posts re start/stop. I wouldn't get too hung up on it. I mainly only do short journeys and the start/stop is rarely working on my petrol 1.5 tsi SEL. One controlling factor is the state of battery charge. Remember charging does not occur all the time, a lot is done on engine overrun/coasting. tom
The higher engine temperature maybe a sign that a regeneration is taking place. Certainly that is the way the system burns it off. On my previous car, a Yeti tdi, I never had any idea as to when a regeneration was happening until I stopped and heard the fan running. There was no indication on any of the warning lights on the dashboard. Never had any problems until I had the "fix" (don't get me started on that subject). I only stayed with a Skoda because I liked the petrol Karoq and my local dealer (Vindis, Bury St Edmunds) well looked after me through all my car problems. On the Briskoda Yeti Forum some were using a VAG DPF App, OBD plug, to monitor the state of the DPF. Don't know whether it would work for Karoq diesels. Perhaps someone here would know. When I was looking to get rid of my Yeti I looked at a diesel Land Rover Sport. At least the salesman was straight with me when he said that I should take it for a 25 mile run at least once a week. As it is, nearly all my journeys are under 3 miles and with Covid restrictions now not even doing the occasional long run, buying a petrol car was the right decision for me. tom
What does the owner's manual say? I strongly advise getting it to a dealer or at least phoning the dealer. I no longer have a diesel but could this be a DPF issue? Diesels notoriously don't like lots of short journeys (the reason I now run a petrol). Does the fan run for a little while after you turn off the engine? In which case you are interrupting a regeneration, too many of these and you have a real problem. Have you checked the engine oil level? Interrupted regenerations lead to the excess diesel pumped into the combustion chamber (to do the regeneration) running down the bores and raising the engine oil level. Subject to what the dealer says, and I know it's marginal re the rules, but I would take it for a 15 - 20 mile dual carriageway run keeping the revs up i.e. not in top gear. This should get the engine hot enough for the DPF to do a regeneration. Hope you get it sorted. tom
New member, new Karoq
Amongst all this advice you also must not let the engine labour and vary your speed i.e. don't run at constant revs for any period of time. If you take a long motorway trip try to vary your cruising speed by 5-10 mph every 20 minutes or so. tom
Winter driving, a few observations.
No good for me. Compared to my standard size of 215/50 R18 this size (215/65 R17) would under read the speed which isn't legal. See https://tiresize.com/comparison/ tom
Like the wheels. Which ones are they? 16 inch? tom
DSG Paddle after purchase
I have only used them once. Didn't bother to use the gear lever to put it into Manual. I just pulled the left paddle a couple of times to get a lower gear for an overtake on a country road, quicker than relying on the kickdown. After the overtake I held the right paddle to put it back to normal. tom
Karoq 1.5 SE L Tyres
Are they any quieter? Have they improved the ride? tom
Road Noise
See my post of December 23 here: Still think that, aside from under the carpets and the boot floor and spare wheel well, fitting sound deadening is easier said than done. Access to the wheel arches (trim removal) and door skins (door card removal) may be problematical. Has anyone done it? tom
KAROQ TPMS FAULT
MoT Inspection manual says in Section 5.2.3. Tyres (https://www.gov.uk/guidance/mot-inspection-manual-for-private-passenger-and-light-commercial-vehicles/5-axles-wheels-tyres-and-suspension#section-5-2-1) Tyre pressure monitoring system (TPMS) The inspection of the tyre pressure monitoring system (TPMS) is for M1 vehicles first used on or after 1 January 2012. The TPMS warning lamp (see diagram 3) can operate in many ways depending on the vehicle type. You must only reject vehicles if it’s clear that the lamp indicates a system malfunction and not simply indicating that one or more of the tyre pressures is low. Diagram 3. Example of a TPMS warning lamp Note the bit "only reject vehicles if it’s clear that the lamp indicates a system malfunction". Various thoughts: Escalate to Skoda HQ Get it in writing that this is not a system malfunction and the dealer indemnifies you against a MoT failure on this point Get it in writing that you should ignore it Is your insurance valid driving with this warning light on? Good luck tom
How many gears does the Karoq DSG 4x4 Diesel have?
Just do a search on Facebook for James Rothwell Dubai. Tom
Sound deadening
Thought I'd raise this again. I recently contacted Noisekiller in Royton. They have a kit for the Karoq but haven't yet posted the fitting instructions on their website. They emailed them to me. Must admit I'm a bit daunted by the things you have to do. "INTERIOR OF VEHICLE 5 and 5a Undo the carpet kick strips by the door and slide these pads under the front carpets. Item 5a goes under front seat 6 and 6a These slide under passenger front carpet 6 a under the seat 7 and 8 These fit alongside the side of the transmission tunnel 7 to drivers side 9 & 10 These pads fit under the rear foot well carpets Pads Because of all the electrics in this area adhere these pads under the seat and on the upright of the frame" Access under the carpet doesn't seem too difficult "BOOT COMPARTMENT. 11* & 12* These adhere to the rear wheel arches side and top drivers side 13* & 14* Adhere to the passenger side rear wheel arch and top Pads 5 pads are included to fit on the rear wings" No idea how to remove the trim to get access to the inside of the side panels. The spare wheel and under boot carpet fitting (not quoted) seems straightforward. "PADS Adhere one pad to the outer skin of each door." The last door card I removed was in the 1960s on my Ford Anglia. I'm a bit wary of going inside the Karoq doors to get to the outer skin what with electrics and windows etc. Tom SKODA KAROQ 2017 onwards.docx
MPG Review after 2nd full years of driving
Thanks As you gather I missed the chart title under the "MyFuelLog2" headings Aged eyesight is my excuse. to
dealing with sticky wiper blades on a relatively new karoq
My original rear wiper judders according to how cold it is. No real problem with the fronts. I use VAG washer fluid and when the screen gets greasy I clean it with white vinegar. tom
I find this very confusing. Are these miles or litres? Is it based on what the car is telling you or "fill to fill" figures What are the single digit figures, (Aug 2020)? I can't believe that you were getting 9mpg at times, are these individual journey figures? Did you really get 99mpg at one point (Dec 2018)? The only chart that makes sense to me is the last one. tom
Goodbye Karoq
If you are thinking of towing check whether the e-Niro is type approved for it. I only mention this because two years ago when I was looking to change my Yeti I looked at, and liked, a Kia Niro hybrid. I really liked the car until I found out it was not type approved in the UK for towing. I could legally fit a towbar but not use it for towing, go figure. The only thing I could use it for was a bike carrier. tom
skoda connect app only shows log book, trip planner and service partner options.
What software/app are you using? Do you have the Ebay link. tom
Climatronic odd behaviour on heating - inner centre vents don't blow hot air on Auto
My left hand gets cold in these circumstances as well. tom
Tramping
Cold morning today and leaving the house I had to do a classic turn right and accelerate into the traffic. Needless to say I got the front wheels tramping. None of my previous cars (Yeti tdi, Passat tdi estate, Passat 1.8 petrol estate) did this. The car is fitted with Bridgestone Turanzas, that I do not like, a noisy tyre. Is this a peculiarity of the car (1.5 Tsi DSG, FWD) or the tyres. Does it do this with other makes of tyres? tom
Front Assist
Found this thread: And this: tom
iPhone battery level indicator
Just sat in the car and pressed "Phone". After trying I get the response "Phone not responding", Bluetooth is on. However, I realised that I was trying to get the car to pair with the phone once I got the phone to search for and pair with the car it worked. It has imported my Contacts and I now have the battery indicator at the top of the central screen. Result Tom
Varioflex -not so clever
Anyone found that they "lose" the little strap you have to pull to raise and lower the rear seat backrests. Having folded the backrest it always seems to get tucked in and out of sight making it difficult to raise. . It would be easier if it was a bright colour so making it easier to find. tom
