Everything posted by varooom
Websites options to do a detailed VIN look up??
Does your home address contain numbers only for both Street 1 Street 2 values as error suggests? I have used Firefox no problem myself.
Intermittent ABS/EPS warning light
https://www.briskoda.net/forums/topic/262215-list-of-vcds-owners-previously-known-as-vag-com-vcp-owners/ You might be able to find someone local to you with VCDS or VCP that can scan you car for free / few beer tokens.
Window washers not working
You may wish to check T6p to see if signals are reaching this location, if not then we can track back futher. J519 LHD - T46b (Connector C) You can check here if you need to see if this is outputting power. If not, then we need to look for signal from stalk to next location.
Latest software update
I only looked in this thread, and see your post from Oct last year with the same hardware version for unit/screen as the image you posted was all. Not sure it was a newer unit with an updated processor for the reason.
@DSG245 I have seen your post from the other day, and today. Are you trying to imply you have new hardware? Because your HW for system and screen didn't change is all.
Amundsen MIB2 Firmware Update
Yes there is update direct to MU 1433 I can send you a link now if you check PM
Hi
Let us hope you don't need us too often (meaning no faults!)
Can anyone clear some codes with vcds Manchester/oldham
Oh bugger! At least there are more Manchester choices you can reach out to. @Gizmo Need to remove and entry from your VCDS list above☝️https://www.briskoda.net/forums/profile/87798-lgm/ (Oldham, Manchester)
Check through the usual list, see if someone is local to you (likely) https://www.briskoda.net/forums/topic/262215-list-of-vcds-owners-previously-known-as-vag-com-vcp-owners/ Oldham, and recent forum visitor https://www.briskoda.net/forums/profile/87798-lgm/
Yes it's spot on, will send over in next 5 minutes or less
You should hold down Menu button to get into the hidden menu, in that screen you will not be able to load new firmware. Looking for Software Train
Rear wiper washer ???
Could be, shame that it snapped.
skoda superb 2016 columbus firmware
If your download link is slow, let me know... I have faster server 👌
I can send MST2_EU_SK_ZR_P0480T link to download in next 5 minutes
Someone had same jump the other day, fingers crossed your file is intact (they should have checksums. Yes sometimes VAG do make very large jump in numbers that seem extreme! I am not sure as I have never flashed this myself, in theory it should take care of itself... usually no logo is changed. I would need to check, but 99% certain I have old firmware here, and you could force downgrade, but highly doubt you would need this. Just make sure to have stable power, so a battery support unit (official way) But you can also start engine to provide power, just be sure to not start engine mid-update!
The connector does appear to have Male connections at both ends? Can you see any evidence of this inside the entry location where it should plug in? Didn't want you to beat yourself up when you get new motor and find that you could have changed a cheap part.
SupportedTrains = "MHI2_ER_SKG11_P2104*,MHI2_ER_SKG11_S2104*,MHI2_ER_SKG11_K2129*,MHI2_ER_SKG11_S2129*,MHI2_ER_SKG11_P3260*,MHI2_ER_SKG11_P3304*,MHI2_ER_SKG11_P3325*,MHI2_ER_SKG11_K3330*,MHI2_ER_SKG11_K3333*,MHI2_ER_SKG11_K3343*" Yes you are correct, the first entry in SupportedTrains list your currently installed. So you should be able to flash with no problem.
P2000
I did realise that the image was for LHD, but I shall try to look again in a moment at the parts fitting. The only way to tell 100% in part's program is using a VIN or PR codes. So yes, once more it is possible that it is indeed fitted to your car, as seen here in RHD image (sorry about the LHD from earlier) Taken from the Workshop Manual, might be worth trying to locate it I am not saying you do have this part on your car, just that it might be there.
Drivers side light bulb 1.9tdi removal
Thanks for taking the time to post back, and with pictures for the next person with sausage fingers (like me also) that needs to perform the task. Appreciated!
P2000
Well at least you can put to bed the notion you don't have a NOx sensor, as your car does (after turbo) Part number has been replaced, (not that I am saying to fit anything at this stage at all) So ideally you need to locate someone with scanner so you can read in some measurements now and begin the diagnosis process.
Rear caliper bracket
In case it wasn't clear, I was laughing along with you, not at you. All been there and done similar. Done well to get 60k, clearly treat the car with respect and not thrash it about 🤝
Yes not likely to come loose now, or ever.
P2000
Do you know your engine code from your V5/sticker in the boot. Most likely to be 4 characters, example CUSA
P2000
You can search on google or on the site for P2000 / P2002 and will show a fair few results (not always fully answered/fixed) It might be an idea to locate someone with VCDS for example and get some live data scans done, in particular read out Soot measured/calulated and Oil Ash volume values. Get some live data logged from the car on a drive if possible.
P2000
Welcome to the forum, what's the actual current car mileage? What scan tools if any do you have to hand?
