JR RS
Joined
Last visited
Currently
Viewing Topic: What have you done to your Superb III today?
Everything posted by JR RS
All good, no need to beat urself up over it. I was just surprised to hear that a TSi would come fitted with the longer version! Hence was trying to figure it out. Must say, the downside to the longer version is that it needs to be removed each time an oil change is needed. It comes off easily though.
u can find all the part numbers for that illustration here.
U sure about that? Can u see/access ur oil pan from underneath, without removing the under tray? As far as I know this only came with particular diesel models in the VWAG group got it. The petrol models only got the short version, including the Golf R, which the Superb 280 uses the same engine/drivetrain. ....unless u have the Rough Road package which comes standard on the Scout and Alltrack models.
Changed the plastic aero undertray to a longer version, which in theory should help with better airflow underneath the car. Item #1 in the Reference image below. Will b interesting to c wat it does to the engine temps, and fuel economy, if anything. Comes with a fitting kit (screws & bolts). No cutting, modifications, or special brackets required. Remove old, and put in new. Car needs to b on jacks up front, or up on a hoist. Part No.: 5Q0825236Q (has now been superceded by 5Q0825236N) Next I'm getting the centre exhaust tunnel cover too. Item# 2 in the Reference image below. The Superb has the slim/short version of it already. 5Q0825229C is the longer version. The rest of the under trays, minus #6a and #6b, my Superb already has from factory. Topside:- Underside:- Overlay comparison:- Reference:-
What fuel consumption are you getting please.
my Superb 220 (TSi) MY17 has been averaging 8.4L / 100 km, over the past 6 yrs plus. i regularly get between 750 to 820 km per full tank, using 98 RON. most i've done is 984km on a single tank, with 0 left on the Range indicator. with a Stg 1 ECU + DSG tune, i'm no light-footed driver!!
Waze driving instructions
+1 I've been using Android Auto for many years now and I've never seen instructions (Waze or Google Maps) shown on the driver's centre cluster. Same deal with those who have the Virtual Cockpit. It will only ever show the built-in navigation maps and directions.
The Superb III Picture thread
lol, u can actually c the feed.....err.....motorbike in the car's front door reflection.
Rolling shot of Gandalf on a Euro Club cruise, with the remnants of a P-plate (plastic) that fell off the back of a motorbike & smashed into the grille!!
At my last 90k service, it was noted that the upper timing cover was sweating/misting oil, which requires a new replacement upper timing cover assembly with new seals, as well as replacing the camshaft adjuster magnet with an updated unit. In the meantime, I changed the oil filler cap on my 220 Superb to a newer revision cap (yellow bottom) as the sweating/misting oil seemed to b concentrated around the cap. Old: 06K 103 485 A New: 06K 103 485 D After a week of use, there is no more oil misting around the oil cap. Don't know if it's because the new oil cap has fresh seals/rubber, or because it is indeed a revised version, though I couldn't pick out any design changes between the two caps.
How-to: DCC Recalibration
@sharkys - ur missing the bits underlined.... What I did : - lifted car - Control Module 14-Adaptive Suspension - Entered security code 20103. - Go to Adaptations, Select “Adapting with deflected wheels” - Acknowledge by pressing and holding the green tick, or swipe right. - Go back to Control Module 14 - Go to Basic Settings - Select “Adapting with deflected wheels” - Start by pressing and holding the green tick, or swipe right.
read the posts above!! as already mentioned by @Stunner - there is no right rear sensor, hence no readings/values. that's normal. as for the incorrect sequence error u need to follow the steps properly. summarised version:- - adapting with deflected wheels acknowledgement - run basic settings for adapting with deflected wheels - done ensure all 4 wheels r suspended simultaneously, and must b within range.
What bulbs are fitted to the S3 & upgraded bulb recommendations
+1, it's old, but not obsolete. ....also famously said by a Terminator 😉 The stuff recommended already still applies.
It's easy to change out the turbo inlet elbow and pipe. The Turbo Muffler delete is a lot more tricky cause of it's location. Likewise the diverter valve cause of the bolt location. I've got an APR Turbo inlet pipe (carbon), Racingline Turbo Inlet Elbow, 034 Turbo Muffler Delete and GFB Diverter valve.
Superb Mk4
Correct, it's a market thing. we're still getting the 220 here in Australia. We also still get the 280 here, instead of the 272.
Superb Mk4
It's the 220 (162 kw) that is being down graded to 204 (150 kw.
Superb Mk4
- Yes. No, the Arteon doesn't replace it. - Yes. The mk4 will have less shoulder room than the current mk3 Superb.
Superb Mk4
Superb Mk4
Sadly the wagon variants will b the exact same car, just with a different face & butt between the Superb & Passat. Both will b built at the same factory, on the same line. There is no new Passat sedan, unlike the Superb liftback. So nothing to share there. The mk3 Superb is the last of it's kind. It was different and a size larger than B8 Passat. The mk4 Superb is not unique anymore.
Firmware updates questions
Yup, my how to guide covers that bit too.
Start Stop Issues after new battery
That's incorrect - even if the new battery has the exact same specs (Ah and A), u still should do the battery adaptation, as good practice. Over time, as the battery gets old, the battery charging and conditioning algorithm will change, to adapt to the aging battery. When u put a new battery in, and do the adaptation - it will reset the charging and conditioning pattern, that is ideal for a new/fresh battery.
Yes. U can use VCDS or OBDEleven (pic below) to do it urself. A good battery technician/shop will know how to do it. A friendly dealer can do it for u. Plenty of how to guides & videos on the internet.
Superb Columbus Startup Screen - VRS
There is no Superb vRS, never has been. As mentioned above already, the welcome screen on urs has been changed by the previous owner. It can b done using VCDS or OBDEleven.
Was the battery adaptation coding carried out after the new battery was installed, by the shop? If not, ur car will still think the old battery is still there, and treat it like the old one.... literally.
I used the mibsolution website to get the firmware I needed. Mine was MHI2. I went up from 0942 to 1433, but mine is MHI2, not MST2 like urs. Yes I have Canton. There was no need to re-parameterize. No, it doesn't add more features as it's not an upgrade. I didn't have any issues prior to doing the update, I just wanted to bring it up to the latest available version. Since I did update, the Infotainment unit is much more responsive, taking less time to do things, and seems to boot up faster. Happy with it.
go to this website - https://mib-helper.com/ enter ur current version, i.e. MST2_EU_SK_ZR_P0250T, then it will tell u wat is the latest, where & how to get it, and install it. according to that, the latest version for u is MST2_EU_SK_ZR_P0480T (MU: 0480) i recently updated the firmware of my MY17 Superb. i made this set of how-to-guide of instructions. will give u an idea of wat is involved. Firmware Update Guide v1.0.pdf
