JR RS
Joined
Last visited
Currently
Viewing Forum: Skoda Superb Mk3 (2015 - 2023)
Everything posted by JR RS
I put Gandalf on the Dyno today as I was curious to see how much power it was actually making with the APR Stg 1 ECU tune and DSG tune. I'm happy with the results. The torque was shigher than I expected. Outside Air temp was 20 degrees. Did 3x runs. Each time it did approx. 220 kw and 530 Nm. Being the stock IS20 turbo and intercooler, the Intake Air Temps (IAT) was getting too high, making the ECU reduce power towards the end, as u can see in the graph. A larger intercooler will help vastly with sustaining the power curve for much longer. Tis next on the cards. Max: 222.7 kW / 532.3 Nm
Steering wheel upgrade
Provided u get the same before and after "specs" then no. i.e. if u went from round with paddles to flat-bottomed with paddles Or If u went from round heated to flat-bottomed heated. However, if u went from round non-heated to flat-bottomed heated, then u'll need to change the steering clock-spring and do coding.
Closing the tailgate / boot with the remote
I have an MY17 - I can open and close the boot with the key fob. It won't work if I'm inside the car and use the key fob. I need to b at least 3 m or less away from the car for it to work.
Standard cruise control on an ACC equipped Superb
I notice the the facelift is using different ACC hardware/software. I've got this on my pre-facelift MY17..... 13 Adaptive Cruise Control System description: ACC BOSCH MQB Software number: 3Q0907572C Software version: 0195 Hardware number: 3Q0907572C Hardware version: H04 ODX name: EV_ACCBOSCHVW48X ODX version: 001009 Long coding: 320147C355FFC428949C8045 Trouble codes: No trouble codes found
DSG Reset (Basic Settings)
+1 i often drive in Manual mode, and i've never had to downshift into 1st. i'll drop down to 2nd, and when i'm almost at a standstill, the car will automatically drop it down to 1st, seamlessly.
Air quality sensor replacement
Do u have Air Care on ur Superb, and if so, is it Active?
+1 My Superb MY17 also doesn't have the ACC long coding for Cruise Control mode.
Yup, been well aware of that since day 1. It's just annoying that it gets alarmed and hits the brakes, and by the time I tap the accelerator to override, the cars behind r swearing at me for braking for no bl00dy reason!!! The coding makes the driving less "erratic" and safer.
Car windows open when the car is not in use
Bl00dy 'ell!! An easier solution would've been to go into Convenience Opening settings for Windows Operation in the infotainment and turning it off!! Now u've butchered ur key fob!
I like this feature - tis the small things that make the driving experience more enjoyable. I love the ACC - very useful and handy to have over the conventional cruise control. The only thing I hated about it initially was the undertaking prevention, where it would brake when there is car braking/slowing in the adjacent lane. Was annoying that the car would brake to match it's speed. I promptly disabled this using VCDS.
- Enable Ambient light menu with VCDS
- 2023 280ps L&K replaced 2016 220ps Style
Right side foot rest pedal.
It's pretty easy to do. There is one torx screw holding it in. Remove that, and slide the footrest upwards to unhook it from the side. Should come out.
Superb Sportline
I've got 19s on my Superb, and it's very comfortable with the DCC setup. It is more comfortable than the 18s I had my MK2 Octavia RS. It's going to b 6 yrs and my 19s don't look faded or dull. I don't wash my car often enough. On the Superb - the 19s not look great and ride great.
Superb Sportline
If the car has DCC shocks, it's suspension is 10mm lower than the Standard setup without DCC. Was explicitly mentioned in the brochure.
Front wheel arch liner foam
thank you once again @varooom so 3W3 is the one. i do have under bonnet insulation too, hence the 2B1. cheers 🙂
sadly we don't get the L&K version here in Australia. however we got a lot of options as standard, and option packs to add on top. so whilst mine is officially a "Style" (according to mySkoda app, and erWin), it has most of the things that u c on the L&K. regarding the insulation padding in the wheel arch - i'm not sure what classes they've got going. i couldn't find anything obvious in my vehicle build sheet apart from "2B1 - Additional exterior noise suppression" and "3W3 - Special interior noise suppression". not sure if that has any influence.
Mine came with the foam on the wheel arch liners. I added some extra sound deadening material on it, just cause I had leftover material.
VCDS options on Superb III
Scandinavian mode will not activate the headlight DRL eyelashes / whiskers. The facelift Superb has a completely different headlight setup and electronics compared to the pre-facelift Superb - hence there is no point following VCDS or OBDEleven steps/apps for a pre-facelift. U'll just end up stuffing things up. Unfortunately I have no idea about how this can b activated on the facelift Superbs. I have it activated on my pre-facelift and I Iove the look of the eyelashes/whiskers.
tis the "same" DQ250 in both the 162 and the 206 Superb. what is different is how they drive the wheels - 162 is DQ250 FWD version while 206 is DQ250 AWD version.
Dash speaker replacement
High Beam and AFS error
U could try swapping out the modules as suggested above, but keep in mind that each headlight has 3x modules, one of them being the ballast. Unfortunately getting to them is a bumper off job. To do that, u need the wheels off and wheel arch liner off, ideally. U can see 2 of the modules in the bottom pic below. I made a how to guide here. Removing Front Bumper.pdf
No bother - always glad to help. With the front, it uses/shares the same hole as that is used to hold the wheel arch liner and/or front mudflap. With the rear, u need to drill a hole into the wind deflector trim Infront of the rear wheel. Then fix using rivet or nut & bolt. Front & rear easy to do. With the middle, u need to use the supplied kit. It contains black automotive sikaflex bond/glue. It comes with all the instructions - u just need to prep and follow it step by step. I did mine at home. The mudflaps were a pain to do - took ages, and I had to trial fit, then shave off a bit more that trial fit again until I got it right.
based on the error description "sensor for variable lighting motor", and assuming u have SLA headlights - it sounds like the motor associated to roller that does the high beam shape/masking is failing. it would explain why it won't let u put the high beam on. if that is the case, sadly that will require an entire headlight replacement.
Skoda Superb 2023 model
Yup, that's the current facelift mk3.5, just MY23 version. The "next gen" will b different, and most likely mk4. Likely they'll reveal the mk4 this year, 2023, with production to start sometime in 2924.
