Everything posted by SC03OTT
Apple CarPlay with ios18 / iPhone 15
I’d try a different cable first. For info, I’m using the below. 90° connector. https://www.amazon.co.uk/dp/B0BRMF3HD6/ref=pe_27063361_487055811_TE_dp_1
I updated to iOS 18 last night (iPhone 15) and it works fine on my 17 plate. You had the cable long? I do find CarPlay (or its integration with the car) flakey. Mine drops out sometimes and occasionally comes up with a message suggesting the device isn’t compatible. Odd, given that it was 30 seconds ago 😂
Octavia mk3 vrs indicator brightness
I have changed to LEDs for the indicators. Never had concerns over dazzling. Certainly no more of an issue than everyone sitting with their foot on the brake in traffic.
Driving modes
I’d say it depends on the cars spec. DSG and/or DCC yes there will be a difference. A manual without DCC, total gimmick. Just modulate your right foot.
Octavia Scout 2016 MKIII - Disable foglight on together with turnsignal light
The facelift LED units utilise both LED strip for indicator and DRL. You are correct for the pre-facelift however 👍
Ah ok, so it’s the DRL that turns off. Not the headlight. The Mk3 Octavia is the same. The indicator is the same LED strip as the DRL.
Normal startup noise 2016 EA888 2.0 Video included
There doesn’t need to be, at that age and mileage. From my understanding…
That’s also normal operation for cornering fogs. anyway, VCDS or OBDeleven can be used to make this change. It’s easy enough. You just need to find someone local to help you.
I don’t think I’ve ever seen this. Examples?
CD player
I’m gonna just ask it, why bother with this effort? Put your CD collection on an SD card or USB drive. Cost is negligible and no changing CDs all the time. “…as where will it sit.” - on the shelf in a charity shop, where it belongs.
FL vRS key fob
still have the car. Metal tip is still alive and well on the key 😊.
Stone chips on bonnet - a lot more than I would expect to see.
British Leyland? Really..?
What bulb is this please?
What’s rare about it? Looks a standard vRS setup.
Steering Wheel Lock Recommendation
“Good news, we found your stolen car sir thanks to the tracker”. “Ah great, where is it?” ”Bottom of the lake up the road”.
The Superb III Picture thread
The size difference is quite something when next to each other. I remember that being a big car when it came out too.
Octavia Mk4 Facelift Brochure UK
In my experience, yes.
1.4 TSI iV vRS DSG 2021 Estate - Wish List
A 4.8W solar charger to charge a plug in hybrid? What?!?
What's your Vehicle Score?
Good for a bit of fun I guess.
Vrs front fog lights.
Pre-facelift won’t fit or indeed work. The facelift uses LEDs but the pre-facelift uses filament bulbs.
My Octavia and gremlins
Kudos for posting an update with solution 👍
Can we add speed camera alerts to Mk4 Sat Nav?
Do you ever, out of curiosity, unblock me just to see what I’ve said? I’m not aware of this being done. Tried any of the other VAG forums?
Major Service Records
do you have these things armed and ready to go? Always seem to be very quick to post them 🤔
Lack of spoilers
I quite like number 7 🤔
Skoda Octavia III rear axle
150ps and below was TB. 151ps+ was IRS. Im 95% sure that was the figures banded about anyway.
Skoda Octavia Vrs Petrol - What mpg do you get?
About 37mpg, averaged over 60K miles.
