Everything posted by pragmatix
"check oil level" warning
I check everything when picking a car up, they don't like it, I found protective tape still on sills, tears in seats, lights not working, wrong tyre pressure , missing spare wheels and even odd alloys. though I must say in defence of specialist cars Dundee the only thing I found was high tyre pressure
It was them that told me to check it and gave me the oil too, I've found them to be very good.
Yes it's normal, the 1.5 is known as using oil it , I was advised to check the oil on a regular basis, not that I need telling I've always done weekly checks.
Which Car guide 2022
whoops read that wrongπ
The Enyaq is a good drive, just a shame the seats don't fold flat or come out., when did the Karoq get the huge interior, mine must have missed out on that maybe it was an extra.
Cup holders ridiculously shaped
They still give the mugs out, oh and a rather fine pen and usb c adapters, mind that miserable lot in Dunfermline, didn't get my business
Mudflaps
I find that they stop muck at a low level but do nothing for higher up the sides, I've taken mine off as they where catching on the rough track I live up
Is this hole/split in the door rubber normal (by design)
Normal
Travel Assist not available
Fairly standard, if the job is proven to be a warranty issue then you don't get charged
Seat Belt gets stuck in B Pillar Trim, please check!
Mines fine can't get the belt trapped
Wheel options
very nice find I've seen it before and partialyexplains why MY21 SeL are on 18s instead of the old models 19
Karoq Windscreen Condensation Issue
It's more to do with the weather rather than the car especially if you do short journeys I.e. under 20 miles the car never gets a chance to dry out
Clunk at front wheel when turning up ramp in multi storey car park with my Karoq-any ideas please?
It's still under warranty book it in to get checked, mine did something similar it was a a dry bush sorted under warranty.
Playlists USB
Car has just been in for a software update, and as far as I can tell it's solved my problem music now plays as I expect it to, no on software version 0276 upgraded from 0270.
Music from USB stick.
Change of primary name
The best I've had is 44.8 on a long run over 225 miles
I think you will be disappointed with the mpg, my average is 37.7 that's over 7556 miles
Karoq front park sensors
After market beep only are easy not so sure about connecting into the cars system though.
Playlists USB
Mines going in for an update on the 22nd I'll let you know what happens,
Playlists USB
I'm due to the dealer for a software update which I'm led to believe should sort that problem and the freezing of the infotainment system lack of audio, dropping Bluetooth etc.
It does play in the order of an album but it always starts at the beginning it the stick.
Playlists USB
I have the same problem the usb I had in both my fords was fine in them , showed the album art too, it's really annoying when it restarts at the beginning.
Karoq Sunglass holder
I believe if you have the sunroof it can't be fitted.
loading user profile
My car is in tomorrow for a software update, due to freezing infotainment. the 1 Ltd is surprisingly good though as you say remembering to change gear is a pain.
Adele hells teeth how do you put up with that wailing
