inspectorman
Everything posted by inspectorman
  1. Inner clearance will be 4mm less; outer clearance will be 8mm further out.
  2. Described as mirror frame. Part number might be 5JA 857 532 C 9B9 5JA 857 532 5JA 857 532 C and www.skoda-parts.com have two in for R/H at the moment. Your local Skoda dealer may well be able to get it too. Speak nicely to the parts guy. I'd practice getting the glass and frame off first in case you need to order the glass as well.......
  3. The only way I can see to achieve this is to reset the long distance data before your road trip. Then, up to 99 hours or 10K km you should be able to see a summary of time and distance; but only on the central infotainment screen.
  4. Three bulbs in each rear cluster are part of the sidelight circuit
  5. Yes, the headlight marking on the switch hardly lights up at all. Some other VAG switches like 5JD 941 531 look very similar but would have to be checked for pin markings and connector block dimensions. And I'm not sure if the white nylon female torx connector in the back of the switch is significant or not. Breakers in Bristol with a Rapid? Don't forget the rear sidelights as parts of your checks.
  6. Number plate bulbs out next. The successful run with no side light bulbs was not the answer.
  7. Progress! Have a good look inside the holders, too.
  8. Can't see a pattern in your statements pointing to a particular light position. But, at 8 years old, good practice to get all the bulbs out of their holders and inspect the bulbs and holders for unpleasantness. Any corrosion or darkening of the bulb glass should get them replaced. Don't forget the number plate bulbs. Switches do die. £20 will get you another. Is there only one fuse for the entire lighting circuit? The 2014 Rapid manual I'm looking at has ten separate fuses covering the lights (dependent on what's fitted). Which one are you replacing?
  9. This guy managed it with a knife. Looks like a Polo flap release; the motor is changed from the outside by removing the mounting screw and pulling the whole tank neck shroud out.
  10. People use all sorts of grease on slider pins; usually what they have to hand at that moment. Quite a lot are unsuitable for long term use and will migrate from the bearing surface, damage the bearing surface, rot the rubber and generally cause headaches. Silicone grease is not normally recommended for metal/metal surfaces and what you have may not have the high temperature / pressure specifications of a dedicated guide pin grease like Molykote G-3407 https://www.dupont.com/products/molykote-g-3407-caliper-pin-grease.html. Hard to find in small quantities but occasionally pops up on your favourite auction site. Wurth make a brake paste but only rate it to 160C and not the 200C of the G-3407. But at least you can buy it easily in sachets. Or Proslip pin grease. Ceratec from Mintex is OK. New pins are cheap enough and will remove any doubts about galling caused by incorrect lubrication.
  11. Near Aldermaston? Only near there or throughout Hampshire? Some interesting pulsed reactors inside the perimeter. Not to mention the EMP simulator.
  12. Here you go. I had forgotten the foam tape glue got a bit tired last summer so I had replaced the foam tape with some silicone / rubber dots. 5 small ones along the top edge and one bigger one down each side. Kwality.com.
  13. Solved with a little bit of sticky backed foam. The weedy plunger springs in the dash are meant to hold the lid down on its catches - but it's all plastic on plastic with no damping or softness, and scope to move L/R / up/down a little. Hence the noise.
  14. VagCom or VCDS is the only way, I believe.
  15. Model? Engine type? If it's a 2016 2.0 Tdi Octavia (engine CKFB, CKFC, CRVC ) Then the answer is M6 x 16. Easy enough to test with whatever you might have lying around. N 10338903 hex collared bolt M6 x 16
  16. 2 minutes will find this on youtube Filmed on a potatocam and really showing inspection and replacement but you should be able to infer how to get it off. Alternator problem easily diagnosed by checking voltage when the engine is running. 14.4 / 14.8V would be nice but anything below 13V or so indicates a problem (as long as you don't have all heavy electrical loads on).
  17. I hope you don't have this chap's experience; (Lenkräder dürfen gewechselt werden wenn im Fehlerspeicher SOS und/oder Travel Fehler gespeichert ist. Ich habe heute mein siebtes bekommen. Skoda Deutschland ist sich sicher das es nicht das letzte sein wird.) Steering wheels may be changed if SOS and/or Travel faults are stored in the fault memory. I got my seventh today. Skoda Germany is sure that it will not be the last. Posted on Thursday. He has a 2.0 TDi with 48,000 km.
  18. Yes. The bonging was associated with the warning lights appearing, the warning lights going off, or passing a crisp packet in the hedge. The solution was a new steering wheel and a couple of other modules (but my dealer is shy of telling me exactly what has been carried out). By reading the German forums I knew the solution was going to be a new steering wheel before the dealer did. The dealer also told me there were no steering wheels in the spares chain or at the factory. Considering Skoda were pushing out 30,000 Octavias a month in 2019, this seemed implausible. I waited over a month for one to surface and be fitted. If you get the car scanned with VCDS you will probably see; Steering Wheel Touch Recognition Control Module: Subsystem 4 - Part No SW: 5E3 959 542 D HW: 5E3 959 542 D Component: KLR 074 0019; Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 236
  19. Yes, although for me that change happened in two stages - once when I'd pointed out to my local dealer several updates were due, and then six months later when the "travel assist not available - bong" "feature" went from occasional annoyance to full on madness. Mine was delivered with 1664; went to 1668; then 1806; now at 1896.
  20. I have now changed four sets of rear discs on four Skodas before the first MoT over the last ten years. One one I heard chunks of the disc surface delaminating and hitting the wheel as I drove. Truly awful quality and quickly replaced by me with components from a known brand. Anyone who fits these as OEM parts needs their head examined. The truth is probably that Skoda/VAG use a range of suppliers, all driven down to the lowest possible price - so you might be lucky. The picture shows a Rapid rear disc at 15K miles / 2.5 years. Didn't bother Skoda with a warranty claim since I knew I would be fobbed off. £35 and an hours work sorted it. Now - 10K miles and a year later - not a sign of anything happening to the rear discs.
  21. All brake pads require a little clearance to get in and out of the calipers; I speculate that you're hearing a very dry pad take that clearance up. At the next service I'd get the pads out and get a little suitable lubricant on the back of the pads and their ears. Mintex Ceratec is one type. Getting the pads out will also let you see if anything else is going on - sticky slider pins, trapped stones... the list goes on.
  22. Solenoid / diverter valve; ruptured diaphragm; boost leak ? Or some associated hose / part? PCV valve? The noise sounds like the boy racers who modify their turbo setup with blowoff valves to make a similar noise. Apparently this is desirable in certain quarters.
  23. Real world; Hatch; 12K miles; anywhere between 55 to 58 brim to brim. Not a lot of nose to tail traffic, though. Swiping and poking is pants but you get used to stabbing at the bits you need. It's impossible to have buttons for the level of functionality it offers - you end up with zillions of tiny buttons. By the time yours is delivered the early horror stories will be sorted - or there'll be more knowledge in the dealer chain of what the faults are. Interestingly the Golf has just released a major infotainment upgrade with a better chip at the heart of it - this might be on Octavias in a year.
  24. Read the labels on the current one. Probably 096 or 096AGM. 120-ish from Tayna for a decent AGM. Unconvinced about upgrading (unless you have good reasons involving almost all short journeys (and even then a monthly tickle on charge will solve that)). Standard 096 86-ish.
