Everything posted by Lee01
Has anyone tried or installed the Koni Special Active?
Hi, Luisopas Translation for the community π Hello, I'm new hereπ, I have the following question, it is related to the suspensions of the superb. Mine has OEM suspension but Eibach springs, aesthetically it looks beautiful but the happy bounce is still there. My question is the following, the shock absorbers of a Golf GTI are suitable for the superb, it has the same platform! And another would be the following: what difference is there between the suspension that a Scirocco could have and that of the Superb. I have both suspensions saved and I could install them on the superb, but I don't know if they would work. Thank you and greetings, I await your response.
Driving without the engine cover
Perhaps change your habits or rid yourself of of old ones. π€·
"Service now ! " message on dash.
Editing of posts is a privilege of Freedom members.
That confused me as well. Isn't that what the dump valve is there for?
Battery (1 year old) keeps going flat
I doubt what I suggest is the cause but MkI Fabia's had a common fault where the alternator load sensor wire failed resulting in not keeping the battery charged sufficiently. It's worth considering as from memory it was a relatively simple and cheap fix.
Digital Switchover 2025 - End of Landlines just 2 years away
Openreach were already doing OH fibre when I left in 2018 so I suspect they'll just use the existing OH routing. No difference in speed or anything.
ULEZ and other similar schemes we are being told are all about clean air for everybody but are they really just a means of making money from motorists?
Absolutely unbelieveable! Some absolute arseholes have used and IED (Improvised Explosive Device) i.e. a BOMB, to blow up a ULEZ camera. It's sheer luck that nobody was injured or worse. https://www.bbc.com/news/uk-england-london-67653609 Vid in link https://news.sky.com/video/ulez-camera-blast-damages-vehicles-and-houses-in-sidcup-13025194 Pics via Xitter
Furry Bolts - Winter Wheel Time
I can't be sure but I think the furring is caused by a reaction between the alloy wheels and the steel hub and the wheel bolts. I forgot to add that I believe it's the same reaction that causes alloys to stick firmly to the hubs hence why @Warrior193 and myself use a smear of copper grease. I never bother with it when I put my winter steelies on.
the truth about electric cars
Give your head a wobble π€¦
How long do you think those tanks will keep a farm working? In the outback you say? So plenty of sunlight or wind available in Australia
How do petrol stations operate without electricity or refineries etc etc
My 2014 Rapid has never had an engine cover AFAIK.
Charge Door
I think the battery in question is the large 400v + lithium ion battery for the motor rather than a small 12v battery?
Columbus In German!
Well that's clearly not right. I'm out of ideas but maybe someone else will have another idead. Maybe it needs a factory reset but I wouldn't do that until exploring other avenues first.
Columbus In German!
OK that message says 'Your chosen languge is loading' so you might need to give it a while to load up.
Glow plug replacement 2005 Octavia
Should just be a deep socket I think. 8, 10, or 12mm usually depending on vehicl. You might need a knuckle/ UJ on the ratchet and some WD-40 left for a bit to sink in.
Columbus In German!
Can you get into settings (Einstellungen) and then language (Sprache) and then select Englisch?
New member
Morning, Mike. Welcome
Bike for Sale
Hi, Carlo. To advertise on Briskoda you'll need Freedom Lite at a minimum. https://www.briskoda.net/forums/subscriptions/
Fabia mk1 wing mirror size??
If you're at the scrapyard wou'll have a decent choice - Mk 1 Octavia, Mk 4 Golf's and early Audi A 3 mirrors all fit.
Do Telsa know what size the load bed is or am I missing something? https://www.tesla.com/en_gb/cybertruck
TL;DR EV's LESS likely to catch fire than ICE vehicles https://www.theguardian.com/business/2023/nov/20/do-electric-cars-pose-a-greater-fire-risk-than-petrol-or-diesel-vehicles?CMP=Share_iOSApp_Other&fbclid=IwAR0I0zEJXXnghZQ_mHYhvK1m4PsMttiMDnFLrC9HTcN_QOgqwhna2xt2QJ0
SD card
Gary missed the i out. Try this π https://www.satnavishop.co.uk/
I saw BG EVs even before 2018, George. Maybe BG have more reason to Greenwash their appearance than BT/ Openreach π€·
