Everything posted by RADIOTWO
Estate boot dimensions ?
42" long X 40" Wide
Heating...where has it gone ?
Sitting in the yard not moving will never get the water temp up, you need to be driving for the temp to rise and you say its very cold that will make it worse
I am confused ! I asked how long have you been driving, 10, 20 60 Mins ? and you say the gauge shows 80% the temp gauge does not show in percentage it shows in centigrade (but guessing might be Fahrenheit) but still not a percentage. please answer the questions ?
Octavia RS Front Foglight water ingress ...removal?
I had exactly the same problem on the same year as yours and was done under warranty
How long have you been driving for ? and where is the temp gauge ?
Jemm
I second what Ootohere says about titles, it is very confusing
Panoramic roof leaking
Check the drain hoses they are poss blocked
- Reversing camera fitting
Selector Lever
What has 2.0lt DSG and 70K got to do with no Warranty ? I always thought Skoda was a three year unlimited warranty
Rear dashcam fitment service
Have a word with RS Connect Group (01675 624000) who are a UK based company that fitted my Front and rear camera, I cannot give prices as was included in the purchase price of the camera, but what I will say is they did a good job fitting it
Rogue cable in boot area.
What has got to do with the Virtual Pedal !
The previous owner must have left it off the order, although I have the wires in the boot
So are you saying its a option ?
Precisely, thats not what it shows, it shows a picture of a car and inner and outer setting but nothing like the activating and deactivating you show above
The problem is it does not show like that on the Mk4
Can you give me a link to the settings as I have not found any thing that gives the option to switch on ?
Is it not for the tailgate opening by means of the foot swipe !
TICO
Please read the previous post as he told you how to do it, and when you take a photo make sure you take the whole dash, not half covered with the wheel
Check engine light
Plugging in the OBD is the only way to read the codes
Diesel in oil
But our current car is a 2021
Diesel in oil
I am a bit confused with this matter, I have seen the coments "you have to do more milage" I (we) have had Diesels for most of my driving life and admitting only the last two were Euro6 but my wife who drives it on a daily basis only does seven miles to and seven back, and we do a couple of miles to go into the local town, and have never had a problem with "Regen" or Derv in the oil, only thing that would point me in the direction of regen is the Fan runs sometimes when we stop but that's all.
Diesel in oil
What has too much oil got to do with doing longer journeys ! and how has the oil got to the stage of needing some removed ? When was it last serviced and I would get hold of the garage and ask why did they put too much oil in
Guide on electric tailgate retrofit
"tailgate button" you say it should work with the existing one ? i assume you mean the one in the centre ? No you need one one in the tailgate to close it. Also it will need coding (I guess)
Constant live when IGN is on
The power is going off after a certain time, and no its not the voltage as its hard wired to the fuse I will check to see if any of them go off after a certain time
2021 VRS 2.0 TDI I have had a Dash cam fitted and they have wired to a fuse so it goes off when the Ign is off, (not on constantly) which is what I wanted but I have found if I stop the engine and leave the Ign on the cam shuts off after a few mins. Is the a location (fuse) that stays live while the IGN is on ?
