Awesam
Everything posted by Awesam
  1. Also look out for coolant leak on the bottom tray as the Thermostat housing and waterpump are prone to leak and especially if its a high miler.
  2. I'm beginning to regret responding to your post! Maybe I don't have the patience as I'm recovering from covid! My car is tuned to Stage 3 which has a ECU and DSG tune done by JBS in Chesterfield. It's running a standard clutch, no mechanically modification done to it, only software! There are plenty of Golf R owners who are at Stage 3 and running between 520 - 550 bhp and limiting the torque to 600nm on a standard/stock DSG with no issue. They have to be on top of the maintenance to reduce the chances of failure. Naturally the life of the DSG clutch will be reduce depending on how they drive and how many launches they do. The top DSG tune is from TVS Engineering and they have agents across the UK - AKS tuning, Awesome, CLP automotive to name a few. However a few tuners have their own DSG tunes which work well - JBS, Ecotune, Unicorn and of course Revo. It all depends what you after! Personally would I go to stage 3 again if i had the chance? Most likely not. However I now have a car which is faster than an the previous model M3 which i would never be able to afford and has cost me a lot less. Plus the size of the Superb allows me to ferry the family about in comfort and ease along luggage.
  3. So mines to tuned to 422ft lbs which is 572nm on a standard DQ250
  4. Maybe I got it wrong and its 500nm as stock. Not sure what you mean by mechanically value. When you get a dsg tune they adjust the clamping pressure to ensure the clutch doesn't slip with the increase in torque.
  5. TVS DSG Software (awesomegti.com)
  6. I thought APR had stop making their clutch packs! The APR clutch pack allowed for higher torque levels I think up to 800NM+. All upgrade eases the strain on the gearbox. The only other company I know who are doing clutch packs are RTMG, RTMG DSG DQ250 Upgraded Clutch Pack – RTMG (r-tmg.co.uk)
  7. depending on which DSG you have: DQ250 - 600NM Max DQ380 - 700NM Max
  8. Most will need minimum 18" rims to clear if its 4 or 6pots. Mines are 8 pots and im running 18's. I know the Tarox 6pots minimum rim size is 17".
  9. Will and Rob are top blokes. I'm surprised Will never tried to tempt you into a TTV3! lol If you were planning to go beyond stage 1 then I would have recommended the BCS downpipe or Trackslag 4" downpipe, both are expensive however the craftmanship is to none. The turbo should give you a solid 400bhp if you did go beyond stg1. Sadly not many people cater for the Superb for a full exhaust system, mostly here are custom built. Was toying of the idea of getting a Milltek cat back system for a VW Arteon, which in theory should fit with some modification.
  10. Just luck to be honest. It was from a friend of friend who selling them.
  11. 🤣 Clearly I never paid no where that! I even paid less than the Racing Line 4 pots!
  12. lol just paint them and put some stickers on them.
  13. No, not required tbh. I would just upgrade the rear brake pads.
  14. I've just noticed this morning that my passenger side door mirror wasn't folded in but the driver side was. So tried opening the door side door and that was locked however the passenger side door opened and the alarm went off as they key was still in the house. So based in this thread I'm assuming that my passenger side door lock need replacing! I've got a MK3 Superb and Im hoping it using the same door lock as I'm planning to do it myself. Found the part number for the Passenger side: 5TC837015, only £60 and probably about 2-3 hours to strip and install .
  15. I've got a Tarox 8 pot fitted Front TAROX Brake Kit - Skoda Octavia Mk3 - KMAU0964 - TAROX Online Store
  16. TBH 480bhp is overkill! I wish I did a stage 1 or maximum stage 2 as currently the car is ridiculously fast, there is never enough road and also there no safe place to put the foot down unless its on the motorway and you are overtaking. Yours is tuned to the perfect level as I would say 400 - 430bhp is plenty for the road. My mistake was I always desired a car which was as fast RS3/4/ M3 however could never afford one of those. in hindsight I wish I had saved the money! lol oh well Good luck with the sale.
  17. Nice clean car! Have you got the standard cat-back exhaust? if so I'm impressed with the power and doesn't seem as restrictive as previously thought
  18. I had a P7 delaminate its thread whilst on a dyno and then blow out! Scary experience for the tuner, he's nerves were shot when he came out of the car! Luckily he's already bald!
  19. I had a Quaife LSD in mines, that made a huge difference.
  20. Stunning car! I do missed my MK2 VRS. Yours is screaming a K04 conversion!
  21. Upgrade the pads and you should be fine.
  22. Lol fun it is however watching the fuel needle drop in real time isn't! I would say stage 1 is plenty as it's the best value for money and performance gains. Stage 3 is good but not worth the outlay tbh.
  23. Fantastic result! Well done on the restoration!
  24. Strangely enough mines has started doing the same! Its ok over speed bump, its when the ground is uneven and the car is unsettled! The creaking is most likely to be your top mounts when they replaced the front shocks!
  25. True! When my car was at JBS for tuning in December, they quoted me £550 with an INA Branded one at that time.
