Awesam
Everything posted by Awesam
  1. Amazing! mines went up from £580 to £865 last year! I hoping it goes back down for this year renewal!
  2. The DQ250 is strong however i think if you pusher anymore then it will start to fail, i believe the tuner limited the torque to a safer limit. Otherwise if i was looking to go for 700nm plus then the recommendation was to upgrade to a DQ381. However I decided to get the strongest and got a DQ500 instead.
  3. 280 came with the DQ250 6 speed, 272 comes with a DQ381 7 speed. I ran my DQ250 up to 624nm with no issues before upgrading to a DQ500.
  4. What's the benefits of the swapping the camera and was it straight forward to swap?
  5. Littco do the L380 which is strengthened Core IS38 well enough to run over 400bhp. Im on my 2nd Littco turbo and they are really good turbo's, the other one I would full recommend is the Turbo Technics V4, the REVO ETR v1 was based on that. As for tuning, i think the best bet would be a Ecotune dealer due the map being custom, Revo is good for stage 1/2 with a IS38 however i think its a flash tune rather than being custom to your car.
  6. One of the most cost effective brake upgrade is the 4 pot calipers from a Porsche Macan which will allow you to run a 340/345mm disc so would fit under 18" wheels. A maximum of 360mm discs can fit under 18" wheels however it will depend on the caliper setup. Otherwise if you are not planning to go for more power then upgrade your pads and brake fluid which will help.
  7. I use 19's for summer, 245/40/19. Comfort is acceptable however im on coilovers so ride quality is firm. For winter i use 18", 235/45/18 and they are definitely more comfortable. Im now considering of selling the 19's and getting some lightweight 18's for summer.
  8. Do you need to remove the bumper to change the headlight bulbs to get access to the headlights or do you need to go through by moving the wheel arch to get to the back of the headlights?
  9. Damn! My silly comment has set a few of us off!! I take it back!! 😆
  10. Mines is Pre FL, 2015, I have installed a Mk4 Octavia VRS steering wheel which has heating options. However you will need to get 2 things which will make it an expensive mod! 1. CanBus adaptor to make the left side of the steering wheel function. If you have a FL then you may not need it as it will have latest BCM etc. 2. You need a new steering clockring and a loom from kufetec and some coding to get the heated steering wheel to work.
  11. BBK kits usually range from £2000+ new however you could get refurbished 4 pot calipers as low as £300 but would need to source the mount bracket, discs and brake lines. Check out facebook as they are always some on for sale.
  12. Mines went a few months ago but only one of them, can't remember if its the intake or exhaust one! However before that i changed the cam magnets first as they were cheap and easy to do. There is no wiring in the camshaft solenoids! only wiring is attached is to the magnets!
  13. Why not use this as it has adhesive on it: sourcing map 236mil 6 mm Insulation Boards Audio Stereo Sound Acoustic Noise Absorbing Damping Mat Car Sound Insulation Sound Insulation Cotton Black 50 x 80 cm : Amazon.de: Automotive I used this one for my boot area: Noico RED 315 mil (8 mm) 9,5 sqft (0.9 sq.m) waterproof Liner - Noico
  14. Autotech, however my first one seized as it was design flaw. E10 - 95 Ron is the weak mix over here. No times yet.
  15. I'm running a upgraded Hpfp for over 15000-20000 miles now, it been running from 480bhp then 540bhp and now 600bhp with no issue. Mines tuned on 98ron fuel (E5)
  16. Well I've done plenty of development on mines but did cost a small fortune to get the power I'm at.
  17. I asked aswell via Instagram and was told that the information in the video. I did further question regarding the hpfp and the spec of the exhaust and was told they won't disclose that as then everyone would copy it.
  18. I think if they have put in a downpipe, its with a cat. specs of it will most likely to be a 3" turbo or cat back system.
  19. It's surprising how much traction this is getting even though Michael from this forum has done it 7 years earlier with 560bhp and then 3 years ago he inspired me to push it further.
  20. I hated the Pirelli's P7, Im using Michelin Pilot Sport 5 for the summer and Crossclimate 1's for winter. Both have been great.
