Urrell
Everything posted by Urrell
  1. If it was losing boost via a faulty wastegate actuator I can see that needs repairing or perhaps replacing but the turbo?
  2. The car is well after that, why was anything fitted?
  3. Clutch pressure plate fingers broken?
  4. How did you get on bleeding the fuel filter? I see Carista now has a run fuel pump setting to prime the fuel filter in the Beta app.
  5. Urrell replied to EP90's topic in Skoda Yeti
  6. I take it you are talking about water temperature. Sounds to me like the thermostat is faulty. I cannot see how the DSG thermostat could affect it that much.
  7. I suspect that's all they had on that website.
  8. The rear view camera that displays on the infotainment screen was never a standard fitment, it was only available as an option from SE up.
  9. Does the reversing light work?
  10. Urrell replied to Yety's topic in Skoda Yeti
    Try tapping on Ash, mine shows as amount and percentage.
  11. Any state of charge will be like that, it's the charging system on the car making the headlights bright when it's running.
  12. Mine does not have a DMF, it is not smooth below about 1500 revs when applying much throttle in 4th and 5th.
  13. How many revs is the car doing when you do that?
  14. My 1.6 TDI uses a 32mm socket.
  15. Coil packs in a TDI? What engine do you have?
  16. Could it be the DMF?
  17. Urrell replied to Willson's topic in Skoda Yeti
    That is not a Skoda Yeti fault code.
  18. Urrell replied to a post in a topic in Skoda Yeti
    Why not Google it? I suspect plenty, you could then Google reviews to find a good one.
  19. Do you ever kneel on the seat? So that element has failed after 2 years!
  20. You should be able to work it out from here. https://skoda.7zap.com/en/cz/yeti/yet/2015-779/2/201-201010/
  21. That paperwork suggests the dieselgate fix but that only applies to pre June 2015 cars not cars after that that use ad-blue. The only thing I can see missing in the boot (lower of the 2 circles) is an Allen key that's used to remove the rear light clusters to change bulbs. Edit: Where in any paperwork suggests the car is a Business model?
  22. That's what it said in my manual for my 2005 Fabia I had before the Yeti, but when I got a call from the garage that it was time for a cambelt change I argued with him about what it said in the manual, he said Skoda were changing them all to 5 years!
