Breezy_Pete
Sponsor
  1. Don't think there is one?
  2. Suffix G part superseded the suffix C part in Oct 2008, so either should be fine. Sounds pricey though for used.
  3. Nicely matched levels of overkill!
  4. Inspect the connector of the refrigerant pressure sensor in the high pressure line near the engine coolant expansion tank (look for corrosion). Or look at VCDS data for refrigerant pressure in measuring blocks of HVAC module. See what numbers it shows. You can probably look at measuring blocks in there which say if the HVAC module is demanding fan function (at stage 1 (slow) or stage 2 (full speed)). It is OK/normal for the fan to run when A/C is switched on even if the engine coolant is completely cold; refrigerant pressure >9 bar will trigger stage 1, and >16bar stage 2, even with no heat in the engine coolant. But if you switch off A/C the fan should go off, as it should if the pressure drops below 12 bar (stage 2 down to stage 1) or 6.3 bar (stage 1 off). Those observations are based on a climatic rather than climatronic system, but I don't know why there would be any difference.
  5. Found some helpful info re cruise, I think. See post by Nathan G here: Vag-com cruise control programming - Skoda Fabia Mk I - BRISKODA Follow the link in his post to the archived guide, then do the bit under the Enable Cruise Control using VAG-COM/VCDS Looks like you go in via the 'log in' button, not the recode button. Edit: when I say 'do the bit under...' I suggest you do plenty more research before just doing anything. Not sure how specific that info may be to mk1 Fabia vRS, or whether that code is going to be applicable to your ECU. Reckon it'll turn out to be doable though. Video that doesn't need the sound on! How to activate cruise control VCDS - YouTube
  6. No it's all behind that wall, but I find it quite a low one. If you look under the 'Individual vehicle information' tab, then 'repair info', you can get to info about absolutely anything to do with any Skoda model, in downloadable pdf form. With a bit of planning you'll probably have downloaded everything you can possibly imagine might be relevant before a 1 hour 'flat rate' session expires; connection/bandwidth and storage space permitting.
  7. I'd still love to see the data as a VCDS log sometime, if anyone else shares my curiosity, and has the car and kit to investigate.
  8. Skoda-Parts.com Borská 87/47a 301 00, Plzeň, CZ
  9. You can assure me, but I'd be much more likely to believe it if you could show me somehow with some VCDS data or similar.
  10. Oil cooler I would guess.
  11. I'd stick with one from the same engine, or one with exactly the same part number including suffixes. BLT version has fewer valves inside than the ASZ I seem to remember, probably to do with the electric as opposed to vacuum operated anti-shudder valve/TB. Check for wiring damage near the connector before spending on anything though.
  12. If it sorts itself out within 200km, is it worth bothering?
  13. With the registered version I see the following for engine ECU, Central Elec and Instrument cluster modules on my Polo, none of which show anything to do with cruise control, slightly to my surprise. Maybe I don't have the right version of J519? Never thought of trying to fit it, so dunno really. There will be various documents available via erWin if nowhere else that would give tables of coding for whichever is/are the relevant modules of your car, similar to these pop-ups. An example for my Polo engine ECU is: Not sure how you'd work out which documents you'd need easily though, especially if not sure which modules are relevant.. I'll have a look at our Fabia tomorrow, see if that shows anything more helpful.
  14. Awesome, I think you've just taught me something. I'm pretty sure my latency has always shown as poor. Just assumed that was 'as good as it gets'.
  15. I'll be happy to hear that any of those fixes/workarounds work for you, but I can't help wondering if it isn't something like a poor connection between engine ECU and Central Elec unit, since everything else is 'unflaky'. Edit: having thought about it for another minute, maybe it is just that the engine ECU exchanges more data with the diag port and VCDS than any other module, so it could still be selectively affected even with excellent wiring etc. if there's some bottleneck that doesn't matter for other modules' data.
  16. More configuration than data. If the car it came from had all the same options, it's probably been coded identically, but if not there might be some functional anomalies. This page shows (as an example that may not be exactly comparable) the coding options for a 9N Polo, you get the coding by adding together all the numbers for each of the fitted bits of kit. VW Polo (9N) Central Electronics - Ross-Tech Wiki VCDS Lite ought to be adequate for recoding, and for clearing the airbag fault AFAIK, as recently confirmed a few threads down from this one: https://www.briskoda.net/forums/topic/498514-anyone-use-vcds-lite-on-their-early-mk2/ But I guess you don't know how the original unit was/is coded, unless you have a historical VCDS autoscan saved somewhere? I'll try to find the equivalent coding table for your car when I get a chance. If everything you expect to work works, there's probably no need to do anything pending relay arrival.
  17. Not a lot of downdraught going on as he gets out, judging by his shirt.
  18. I was only guessing about cruise requiring a recode of engine ECU, maybe it's only Central Elec? BXW rings a vague bell for a 1.4/16v in a mk2? Big thanks from me for demonstrating that Lite does indeed seem to work on early mk2s.
  19. Not true, but I'm pretty sure if anything works via the K wire, everything should. The cable and VCDS side of things seems to be fine, in my undereducated opinion.
  20. The engine ECU is probably the one you most want to be able to chat with/recode in order to enable the cruise though, right? I don't think the CAN wiring comes out to the diagnostic connector, but will check later. 4HV is the engine ECU type, I think, not engine code. See link in my sig for how to find that. Is it the original engine ECU?
  21. They are contacts that make/break circuits as the vent control knob is moved to different positions, and possibly the temperature control too. There are only pairs of pads on the board (yellow rectangles) for two to be fitted on this variant - from a 9N Polo - but positions in the white plastic moulding for two others associated with the temperature control knob. Only the one fitted (in one of the green rectangles) as shown in this case, but I have taken this unit apart several times so the other may have dropped out and got lost/misplaced. The one here possibly senses when the knob is pointing at windscreen vents to do some A/C-related function, not sure what the other would do on this one if fitted. I think if there was one on the temperature control knob it would indicate 'max temp demanded' to the stuff controlling a PTC auxiliary electric heater, only fitted to diesel Fabias and only then as an option, ISTR. Have a look where there are similar pairs of gold-plated pads on your board and hope that there aren't too many choices to confuse matters!
  22. Very promising. Sounds familiar. I think once you get this sorted all will be well. From the ross-tech site: If when you try to connect to a control module, you get the error message "Can't Synch Baud Rate", go to the Options Screen and try setting the Start Baud to 9600. If 9600 doesn't work, also try 4800 and 1200. Turn the car's ignition OFF and back ON after each failed attempt to connect!
