Yeti clock spring
I'd stick to AL. According to the website where I looked up AG (oemwolf.com), AL hasn't been further superseded. That's not an official VW group site though, so may be out of date. But it also may be the case that the suffix AK part is different, and doesn't suit cars that AG and AL do. On this page, while searching for the AL part, under the heading "Škoda part number:"There isn't an AK, which I'd take as further suggesting it's not equivalent: Electronic Module Škoda 5K0953569AL (skoda-parts.com)
Oil Pressure Problem
Probably not, unless they're using something quite inappropriate, but that seems unlikely. So is this car a recent acquisition, or you've had it some time and this misbehaviour is recent?
Yeti clock spring
- Oil Pressure Problem
Yeah I think the pressure switch is ignored below a certain rpm, except when cranking. 1500 maybe. What oil are you putting in it?- Oil Pressure Problem
Is it OK for a while after it gets fresh oil? Just wondering about possible dilution of the oil with diesel.- Oil Pressure Problem
May just be bearing wear. How many miles on the engine? What type of engine? Any signs of overheating?- Front axle nut size / socket
I've got a picture of the one I use somewhere I think, but can't find it. Did find this that I've written on here in the past: "The one I use is a shade over 48mm O/D, but measuring the recess it looks like anything under 50mm O/D should fit."- fault code p0130
Heat it with a blowtorch, then try. Back and forth, back and forth.- Fault code 16955 - Brake switch (F): Implausible Signal
Buy a genuine new one, they're only about £12.- Recent pics of your fabia for no reason, just stick em up!
Reminds me of this day:- Air filter box Mystery
Water drain hole, I should think.- Radiator fan not working - help!
When ambient temperatures are cool, it can take a minute or two before refrigerant pressure rises enough to trigger fan operation when A/C is switched on. Thermostat not opening correctly is vastly more likely than radiator blockage, but if the engine is not overheating this is unlikely.- Oil filter housing
Very few in this subforum will have any knowledge or experience of a 2.0tdi vRS Octavia mk2. You really will be better off starting your own thread in here: Skoda Octavia Mk II (2004 - 2013) - BRISKODA I can almost guarantee that the problems you are having aren't being caused by faulty expansion tank caps though. Best of luck with it.- Struggling to identify the correct condensor
Can you see the top edge of it from any vantage point? See 2nd photo here for example: Skoda Superb B8 (3V) 2016 Front AC cooling radiator condenser Diesel 1kW DSG3677 | eBay- Moving from an ICE vehicle to an EV - my first 1000 miles and observations on The Good and The Bad
Depends on your perspective whether that's a good or a bad thing. For a lot of people today, purchase price is a significant barrier to EV ownership, and in some of those cases (like mine) range is almost irrelevant; my daily commute is only 5 miles each way. I can/will slow charge at home without any cost other than the leccy. I'll never spend tens of thousands on a new car of any type, but I will buy 'end of life' cars that I know I can maintain cheaply myself. Just depends where your financial priorities lie. Horses for courses.- Resetting Service Interval Light. Yeti 1.2TSI
Find a forum member nearby that can use their VCDS on your car for a beer token or two? https://maps.google.co.uk/maps/ms?msid=209732397261666218585.0004c66cecde3f435ecb4&msa=0- Radiator fan not working - help!
That blue light will show red instead if the engine gets too hot, so you might be worrying for no reason? Check owner's manual to confirm.- Battery capacity calculate
Advertised capacity and real world capacity are unlikely to be exactly the same, even in optimal ambient temperatures. Where in the world are you and what ambient temperatures are you experiencing at the moment?- Radiator fan not working - help!
What ambient temperatures are you driving in at the moment? If the lower radiator hose isn't getting hot after a longer drive - 20 minutes for example - the thermostat may not be working. Are you getting a warning of overheating?- Oil filter housing
The OP was asking about coolant getting into his oil and wondering if it was via his oil cooler, my answer was referring to what typically happens if an oil cooler develops a leak. You seem to be interested in over-pressurised coolant, which isn't the same scenario? For coolant to be overpressurised it's either overheating, or combustion gases are getting in somewhere, via fire-rings of the HG, crack in head, EGR cooler leak etc.- Heater fan and headlights not working
Wow, fast work, well done.- Heater fan and headlights not working
I don't know, never tried (nor on RHD but I suspect the same work is needed), probably just the plastic cover under the steering wheel, two screws? Can't remember which type. Edit: not as simple as that sadly, perhaps not surprisingly.- fault code p0130
engine control unit; lambda probe; knock sensor; i... - Fabia(FAB) [EUROPA 2001 year] (7zap.com) (5th from last item 12) Fabia Octavia Golf Caddy Audi A2 Front Lambda Probe 1K0998262G Was 047906262 | eBay Shade over £50 for genuine, with Offer option- Heater fan and headlights not working
I think it must be a fault in the ignition switch. perfect spelling- Heater fan and headlights not working
Try it with the ignition switch turned to the first click round, one before the position where warning lights come on. - Oil Pressure Problem
