Everything posted by skomaz
New Renault 5 EV
Whilst I like the yellow the 5 comes in that matt grey in combination with those wheels and what looks like a body kit is hideous
- Infotainment unit memory chip swap
My 2023 MINI Cooper S Level 3 Electric leased from Motability which will be with me for 3 years & now a 2021 MG5 as a dog wagon.
Where are you getting them from - is it somewhere local or national / on-line as I've started looking for All Seasons for the Kodiaq but in a 235/55/R18 100V (or above)
Transmission noise (from rear I think)
A rasping rattling noise sounds more like a heat shield issue??
the truth about electric cars
I'm currently paying 1.24 a litre and get about 40mpg from the Kodiaq so roughly £28 for 200 miles. In the swift it would be £22.50 ish for 200 miles and less if it was a motorway run. All fuel only of course
Recommend a headlight bulb H7
If it's a MK2 with projector lights a 35w London Colour HID kit works really well once coded and will pass an MOT.
Don't talk daft... We are many many years from that being reality believe me... It's part of my day job.
Stop start cuts out when car still moving forward.
Our Suzuki switch does this at anything below about 10mph but never causes an issue as it's a manual and restarts as soon as the clutch is touched. Automatics are definitely where any problems arise.
barn find felicia pickup.
TBH you've done a massive amount so far and it is starting to look car/pick-up like again!
Au revoir, my fellow Kodiaqers!
Presumably your vrs has been chopped in?
We don't have an EV, are not on an EV tariff and are not with Octopus but also get free electricity for a couple of hours a week at the moment. I think it all depends on your supplier.
Mystery item on rear suspension
It's the sensor for the headlight levelling system.
12V battery not charging, but charging?
Was your 'black to earth' to a an earthing point on the chassis of the car or on the battery terminal? - if on the battery terminal the battery monitoring connection is bypassed and hence the car doesn't know it's being charged. Doing the former may not matter too much for a quick top-up of a slightly depleted battery but probably would for a very flat battery.
How did you connect the charger? If it was to both battery terminals the car won't have been able to monitor the fact that the battery was being charged so may still think it's flat
So overall the charge cost you £16... The point I was trying to make was that because you were there for so long you paid an extra £10 for two drinks... Something you probably wouldn't have done at a petrol station where you stop for 5 minutes? I wonder how many EV users account for those 'hidden' extra costs?
So your 10kw actually cost you £12...
Holes in sill….both sides…same location?
my guess would be a drain hole for the box section?
2017 1.4 petrol fuel injector issue
Is this on a CZEA engine and what was the build date do you know? Just wary now as we have a 2018 1.4 TSi Kodiaq...
Skoda Kodiaq 2025 – Playing media files from USB
Usb c memory sticks are now available...
French breakdown advice
Nope not at all... (See above post)
Timing belt replacement.
If it were me I'd keep the Swift but I may be biased given I have a Boosterjet SZ5... It's a far nicer car than the Fabias I've driven recently, albeit smaller.
The pad warning light is just that .. a warning that the pads will need replaced. It's not a replace immediately light. So no malpractice at all and you'll probably get charged for the replacement and call out as it wasn't actually necessary
MY10 Scout Diesel, (next problem) noise vibration, in gear only whilst under acceleration, (plus an oil leak) help please.
There are two on the propshaft from memory - one at the front near the gearbox / transfer case and one at the rear in front of the Haldex coupling. As above the rear one seems to be the one that causes most issues but both can deteriorate. Skoda will apparently only supply a complete propshaft at a ridiculous cost but the couplings are available individually from third party suppliers and are common across the platform.
Passenger seat occupancy sensing
When we had a seatbelt warning fault on the Octavia I just unplugged the connector under the seat to no detriment
I had a call from SWMBO a while back re the seatbelt warning on the Kodiaq... It was the same issue of a bag on the passengers seat she'd dumped there in a hurry instead of in the boot.
