Felicia Combi 1.3 - what oil?
You are finding a range of 10w-50, look at all aspects each oil offers and perhaps compare with the oils that you have used and liked and those you disliked and thoroughly disliked.
  • 3 months later...
  • Replies 338
  • Views 43.8k
  • Skoda factory recommended at that time (1994-2001) to use mineral engine oil 10W40 for petrol engines. Since the oil technology evolved a great deal, I invite everyone to use a semi-synthetic eng
  • The engine designer thought that was an OK pressure.  But that's going to be my last input here, because you clearly will not alter your view.
  • I would reccommend 10W40 if your engine is in very good shape and you live in a colder climate. But personally I would use 15W40 because 1.3 engine is quite old tech (OHV-Pushrod engine) and the toler
The HVE makes the car run like it's on air.
The most amazing oil I have ever used. No words, simply.
And NO MORE OIL LEAKS, like NONE. I was amazed to the point that I didn't believe my eyes
Edited by Thefeliciahacker
That's great. Why do you think that is, is the oil "thicker", and/or creates less oil pressure, additives help swell the seals and gaskets on a vehicle that is driven infrequently?
You had in the past oil leaks with the 15W-50?
  • 3 months later...
yeah
19 minutes ago, Thefeliciahacker said:
yeah
So with an oil one scale thinner the oil leaks stopped?
Ester my friend ester
The leak was from the gasket of engine oil drain pan?
my major leak was from the cam cover
The so called "pseutokapaki" ?
Has a gasket, difficult to find an original and many use Vika.
No not rocker cover, cam cover, in the front part of the engine, for the rocker cover you can find PAYEN gaskets, for the cam cover only VIKA
Skoda 1.3 Felicia cam cover, part No: 047103724
441010711256 is for his gasket?
