What did you do to your Skoda today?
Fixed a loose screw on my amp mounting that caused a rattle
  • Replies 7k
  • Views 513.8k
  • Picked up the new VRS: 2013 Fabia VRS by Graeme_Smith, on Flickr
  • Popped to the garage at lunchtime to swap coolant temp sensor. I don't think it's the problem but it can't hurt. Going to swap O2 sensor later for the spare I have. Went well, all sorted in 5 mins. T
  • modified the cup holder     It's now a hobnob holder
Nothing done yet but bought a pair of 05+ rear lights for £10 plus postage on eBay. :)
Can't wait to get them fitted.
Took the near side front wheel off my Octavia to see the 'inner face (of the disc i.e. the one I couldn't see) heavily corroded, ridged, grooved and worn' and the disc that was 'worn, pitted or scored'. I found an almost completely flat, shiny surface. Rather like the front brake that is juddering severely and is considered dangerous but is not noticeable when braking.
On the brighter side I also cleaned out the inner wheel arch and got a hand full of mulch.
Then I took our visiting Yorkie up to Wimbledon Common for a walk
Cleaned out the EGR, didn't notice a vast difference TBH, except my fingernails are all coked up now.
Received these in the post:
Look bigger than my current rear lights, though meant to be off a Fabia vRS.
They're the same size as the original units, honest :)
Had a visit from Final Touch. Will take pics in a nicer location when I can.
Fitted rear bumper diffuser and wheel arch covers; looks well.
Changed interior map bulbs for LEDs:
I'll take your word for it Wardy. :thumbup:
Bought a set of roof bars that don't fit it (they fit every skoda since the favorite except the yeti and citigo)
Sent from my GT-I9300 using Tapatalk 2
Had the dreaded "start blocked by immobiliser". Only happened once, not sure what caused it and it started straight after, but starting to wonder if I'll end up stranded somewhere :S
I've probably changed a dozen or so sets, including the three Fabias I've owned which I swapped the rear clusters on :D
Changed front and rear Skoda badges on my Roomster. Quite easy with the info provided by others in the forum, and my thanks to them. That completes the changeover as the wheel centre badges had been changed some weeks ago.
Went for a drive at lunch and blew some of the cobwebs away :)
New secondhand parking sensor fitted, all is good in the land of late night unlit road reversing.
Ordered a set of foglights... So I can start my drl project... :D
Sent from my HTC Desire S using Tapatalk 2
Orderd a set of steelies and winter tyres finally
Edited by Gumby
Fitted the winter wheels and tyres on the Superb and TT ..... then it started to hail :whew:
Carefully picked a load of leaves off it.
Filled it with rubbish and took it to the dump.
The rubbish that is. Brought the skip back home again :D
Looked at her out the window wishing i was at Battlesbridge for the meet. :(
Stuck lad in the front and filled the rear
Edited by zeffania
Fitted some front mudflaps.
Guest
