Modifications on our Yeti 1.2 TSI
From another thread on here:
Type 1
Type 2
  • Replies 73
  • Views 67.1k
  • Full update Well, a few skinned knuckles later, I've hard-wired in my Garmin satnav via its existing car power plug, and a socket and piggy back adaptor from well rated sellers on eBay. No thanks to
  • I have two similar plug/sockets to power my A pillar Brodit mounted Garmin 3760 and dash top Talex Speed Camera GPS - both wired and fused into the fusebox - and there is room at the back of the fuseb
  • There is room for a power socket in the fusebox moulding, I've put one in for my Brodit mobile phone holder, and I have also run a lead up to the centre tray to supply a row of power sockets and a usb
Hi all
just thought I'd add an update of a few bits and pieces I've down to my 140 Elegance.
1. home made stone chip guard for rear arch (heavy duty stick on foil from Homebase)
2. Elegance (ex Mercedes-Benz) badges from eBay (well, I like them!).
3. door sill protectors (metallic stick on foil from Homebase)
4. Stubby aerial
5. Powerlink hard-wiring for Sat Nav (note I also used a piggy back fuse holder); note rolled piece of rubber used to pack the plastic moulding, no doubt to stop it creaking; this is how I found it so I don't know whether this was a "factory" modification or a dealer fitment!
6. Spare wheel kit (inc wheel, floor, jack, wheelbrace, spare wheel screw); means I also have a compressor.
John
John
Hi John,
thanks for an interesting post, would have thought the 'rubber roll' mod to be a dealer thing and I'm surprised to see that you can actually buy a factory prepared spare wheel (rim plus tyre and associated stickers). Would have expected that you'd order a rim and fit a tyre to it.
Regards,
TP
Hi John,
Regards,
TP
Regarding the wheel, I was going to order a rim and then get a tyre fitted but as I was told that Skoda had the complete wheel with the safety stickers, while I think I could have saved a pound or two, having ordered the boot floor etc I thought what the heck, and got the whole lot together.
A word of caution to anyone buying a new Yeti....the £55 for a factory fitted spare is much more cost effective than the £230 to do it afterwards!
John
Please find below photo's of some improvements to my Yeti 1.2
Rear bumber Stainless steel protection
Stainless Steel door sils.
foot rest
motor compartment insulation. (bought this after I saw it on YetII car, good tip)
Used Valvoline Tectyl to spray the weel arches.
Edited by Polypenko
Martin, can you confirm the objective of this is to prevent corrosion? Valvoline Tectyl also use sprays for sound dampening - I'm interested.
Good job on the other mods - are the door sils 2 piece? Just ordered the Skoda ones myself but yours look good as well. emoticon-0148-yes.gif
I am curious about the Tectyl spray also? It looks like you sprayed the wheel arch liners - plastic. If you wanted either sound or corrosion protection, you would need to take off the liners first, then spray.
Or am I not seeing the pic right?
Edited by Agerbundsen
The first Fase of the Tectyl was pure optical, I did not like the Aqua blue parts and prefered an
entire black surface.
In the second stage I'm going to do a complete Textyl Anti corrosive prevention of the entire
Wheel Arches and the suspension.
Agree that if you want to do a 100 percent protection you will need to remove certain
elements.
The Door Sills are two parts, eventhough I like the official Skoda ones, these are cheaper.
euro 105,00 incl de RVS rear bumber protection.
Edited by Polypenko
Just added the OEM door sils
Only the diesels get the insulation standard from factory for noise dampening. The part number is exactly the same - I fitted it as well for enhanced noise dampening. emoticon-0148-yes.gif
Good Evening,
A great thread, I'm thinking of ordering the under bonnet sound deadening from my local dealer and just wondered if you have the Skoda part number to hand? Also, does it come complete with the trim clips etc needed to fit it?
Many thanks in advance.
Good Evening,
Hi mate,
part number 5L0 863 831 bonnet insulation
clips are included in the package.
all the best,
Andy
Thank you for the quick response.
I've ordered it today, but unfortunately according to the dealer their aren't any currently in the UK - hopefully it won't take too long to arrive.
I certainly can't complain about the service from the Skoda parts department. The sound deadening took eight days to arrive, the dealer called me to tell me it had arrived, so no chasing involved - brilliant.
It's a quality bit of kit - with the clips already in place, it literally took 30 seconds to fit and didn't need any fitting tools.
I can't say that it makes a huge difference to the cabin noise levels, but I've never thought the Yeti was a noisy car anyway - quite the opposite in fact. I bought it more to tidy up the underside of the bonnet (not something I look at everyday), for £21 it didn't break the bank and if it makes the car even quieter that's a bonus.
  • 10 months later...
Just found this item on ebay, My link
Looks to be the same type as the Powerlink item but is half the cost and comes with free delivery! Think I will order one, all I want then is my Yeti - next month hopefullyemoticon-0140-rofl.gif
Love the sat nav install! A couple of questions if I may!
Was it easy to feed the cable from the fuse box out into the car? (I havent got my Yeti yet so cant look and see - is the UK fuse box on the right??)
Where about does the earth connect to?
Simon
Just as a matter of interest as I'm not planning any electrical modifications, but my fusebox is under the bonnet near the battery, which would presumably make the kind of things shown here rather more difficult. Is the location of the fusebox different for different trims/drives/engines - or is it random?
Page 233 of the 2010-2011 Owners Manual shows the fusebox on the left side of the dash panel (the picture shows a left hand drive vehicle)
But page 234 shows an under-bonnet fuse box, which is where mine is: I just wondered why some are there?
My front fusebox is on the right (drivers) side. Take off the panel and have a look.
tom
This is because there are TWO fuseboxes!!!!
See pages 234 and 237 of the Owners Manual.
F11 and F12 are for the Lambda (Lambada) probe - who says Yetis can't dance!
Edited by Terfyn
As a technological incompetent, I always 'get a man in' to do jobs on my car. I bought a Brodit Proclip mount and adaptor online to fit my Tom Tom to the A pillar (right hand side, UK car). Managed to install this myself (not quite that incompetent) Then I found online a firm who sent out a man in a van; he opened the drivers door, removed a small panel at the side/end of the dashboard to reveal a fusebox, took the wire from the adaptor and neatly tucked it under the A pillar rubber, connected the wire to a fuse, put the panel back on, closed the door and relieved me of £30. Works a treat!
Edited by Bobdog
The fuse box under the bonnet is the heavy duty side of things, the fuse box referred to is at the end of the dashboard. See your manual for explanation of the under bonnet fuses. :thumbup:
  • 1 year later...
Hi Everbody, dont know where to post this but the sound deadning (insulation) in the middle of the firewall on my new 1.2 is already "sagging". There's bare patch of painted metal about 300 mm long with a few holes just above it, looks like there should be some kind of plate to hold the insulation up with clips to go into the holes. Went to the Skoda where I bought it, they looked under the hood of another 1.2 it was the same. (bad batch?) The diesel model had wiring loom clips in the "spare holes" and sort of by default the loom holds up the insulation. Are your 1.2's the same? Here in Brisbane we are probably the last outpost for Yeti's so appreciate any input.
Good bit of info re the mudflaps - most of us have had them fiited from Day 1 so don't know how effective they actually are. emoticon-0148-yes.gif
Are they a dealer-fit item? I can't find them in the brochure.
Chris
Hi,
just retrofit folding mirrors
GY
Edited by GiscoYeti
Evening,
I've just taken a look at our 1.2 and there's no sagging sound insulation visible anywhere on the firewall. It's all taught and flush against the bulkhead.
