Shark Performance STS group buy - get your FREE STS here
Wooooohoooo got up this morning to find an Email sat in my inbox.
Opened it up and there was my Performance Map :) :) :) :)
Will give feedback once I get it loaded on.
Thanks Ben :thumbup:
My webmail is FUBAR :( It's a conspiracy I tell you !!!
*edit* Despite my ISP farming it's webmail out to Google it seems it's only broken in Chrome and not IE WOOHOO! Looking forward to the drive to work now :D
Edited by Avalon
  • Replies 451
  • Views 54.3k
Had the new map on the car for about 1,000 miles now:
First few drives you can really feel the ecu adjusting the boost as it learns - I was a but unsure at this point and maybe a little concerned that this was going to be the new 'feel' for the car, but i needn't have worried - its now bedded in fine and at low speeds feels completely OE, but when you're boosting its absolutely fantastic. Completely changes the car - its a real weapon now :rofl:
Thanks Ben!
Quick question - what if anything should I also be considering changing now i'm running higher boost? I know some of the early TFSI engines it was recommended to change the dump valve - is this necessary on the later TSI (fl) cars or is the later VAG item now up to the job?
Nothing to worry about on the TSI engine Rob, the DV is not like the older pre FL cars :thumbup:
Pleased to hear that you're happy with it :)
So in answer to my previous question, way up the thread, I should be looking at dump valve upgrades? (Mk 1 Octavia vRS).
not sure about the mk1 but on the TFSI the original revision Diverter valves were a poor diaphragm design which was prone to tearing. VW released a newer D revision DV whihc was a piston style design and solved all issues and for only £50 instead of the £100 for the forge variant which is similar in design however requiring serving periodically
Thats a big fat yes for the MkI vRS, the standard Bosch DV was very prone to failure in standard cars never mind ones that have been remapped
Ross
Is there a way of telling which DV a TFSI has?
Not without visually inspecting it, and if you're going to that trouble, you might as well have the new version ready to fit and get it put on there. If yours in an 07, it's pretty much nailed on that it'll have an old one :thumbup:
Ross
Right, so any recommendations for a replacement? What to buy and who to fit it etc.?
For the 1.8t you want to be looking at a Forge 007P DV.
Cheers. Any recommendations for suppliers or fitters in the South?
Also, is that an atmospheric or recirculating DV?
When i click LINK on the xconsole i get "Device not found" message. Help please
my 57 plate had the older one if that helps
I had this and just plugged the XConsole into a different usb port and it worked fine. HTH
Hi,
Sounds like you may not have installed the Driver.
When you plug the device into your computer and it asks for the Driver point it to the "C:\xconsole" directory, it should then install the correct driver and be available.
Hewey
Captain Britain - if you require help feel free to give the office a call and one of us will help you over the phone :)
Thanks for the help everyone,
I did what Hewey advised, it worked, and have just sent the map,
Fingers crossed.
Fingers crossed.
Glad it worked for you. :thumbup:
Not without visually inspecting it, and if you're going to that trouble, you might as well have the new version ready to fit and get it put on there. If yours in an 07, it's pretty much nailed on that it'll have an old one emoticon-0148-yes.gif
presumably, its an under car, engine tray off jobbie?emoticon-0101-sadsmile.gif
Or you can lift the drivers side of the car, remove the drivers side front wheel and wheel arch liner and do it that way. I did mine the undertray method though.
Edited by Bogwoppit
