The ultimate Mk2 wheel whore thread
Hoping the uk prices will be the same.... Otherwise import duty and customs 'handling' charge would make them too expensive :(
  • Replies 484
  • Views 78.1k
Not particularly exciting, but a Golf GTd pulled up next to me in the petrol station with standard 'Seattle Shadow' alloys and they looked fantastic.
Yeah agree don't look bad at all
  • 3 years later...
lol
Stolen from google images.
Those are both TSW...
The latest investment
For the Octavia?
For the Octavia?
Correct, back up for the 19s and a bit of track maybe, or maybe even replacement for the 19s
Look incredibly like Speedline Turinis. Uncanny!
Good choice :thumbup:
One less spoke, Steve, and two less than TD Pro Race 1.2s
  • 5 months later...
Bit of a thread revival and unfortunatly have no pics but im a new fl mk2 vrs owner and would love to fit 8.5x19 et47 now going by end of this thread they 'should' just fit but id like to run 225/40/19 is this a no go and would i have to sacrifice for 225/35/19 it will be running on either eibach pro at 20mm lower or the pi at 30mm, cheers all
Speedo will be out if you ran 225/40 19
Standard 18" on the mk2 octavia run 225/40 18. When you go up a size you should drop 5% sidewall to keep the speedo as close to the original as possible.
225/35 19 is the tyre to go for. But you could argue the standard wheels are 8.0" wide and the 19s are 8.5" wide so 235/35 19 will also be fine and will give plenty of give (like the 225/40 18s).
