The Twins. (And Yeti RS)
I wonder if EVO magazine will contact you to run a article on your Yeti now that they have seen it?.   :D
  • Replies 2.9k
  • Views 707.2k
  • Here's a video from a rather bemused arial atom driver
  • Driven it a bit.   In a word, it is...   INSANE!!!
  • We have gone from this:   To this:   To this!!!       A Race Blue Yeti!   I need to get the Annapurnas on I think to complete the change.
Unlikely, I don't think they do much on modified cars.
Usually OEM cars and occasionally an aftermarket package you can buy.
Neither of which really applies to the Yeti. :D
PistonHeads mentioned it iirc. Did they do anything on it in the end?
Still need to see you for a ride in this now it's five million horsepower :)
Photos looks good (apart from the one of the plugs!!), what work do you anticipate it needs? Just general servicing or something more sinister?
It certainly shifts and my God is it good in the corners. The slides just seem easy to control then it just grips and goes
Holy ****, this will be good viewing at Combe
Did i just read that right :o
Bad luck Richard on the problem but good luck with going for absolutely bonkers power LOL! It's going to be hard to describe at that sort of power.. it leaves you breathless enough as it is now. Let alone lighter and almost 50% more power..... hmmm I think you may need to carry airplane sick bags for the passengers. :D
Yes, it cracked a piston.
Cylinder is filling with oil causing a misfire.
700! Hory Shet
Bad news on the breakage, it took a lot of stick on the track though.
Love the philosophy of if it breaks turn up to 11 :)
It was already pretty brisk going around snetterton. Going to be something else once it's done :)
ouch! No chance of Audi covering under warranty?  :D
I'm sure it will come back and be worth it!
I guess this is where "that which does not kill us makes us stronger" is appropriate.  :thumbup:
It has cracked a piston.
Apparently not unheard of with this engine highly tuned and used mostly on track for long periods.
Second hand engines are expensive.
The cost to fully forge this one, port the head and do the valves is about the same as a decent replacement.
But I don't want to spend a fair amount of money on it to be back where we started.
The engine forging is going to take three months...  and will mean it can handle a lot more power.
Plan is to just turn it up to 11.  So I can see an improvement for the outlay.
Richard proving that he IS sensible............. :D
TBO I'd do the same, who would want a direct replacement with the same potential issue?................if for the same cost you can make the engine way stronger & get rid of the "issue"!.... :nerd:
Of course the up side is it will handle more power, .....& we all know that you won't scratch that itch....................... :x
...............Because you already have the plans for turning up it to 11 as you say, it does make me wonder if this "breakdown/problem/issue" is all a rouse to be able to carry out your already in place plans for the power upgrade & get this past SWMBO.........................
:notme:
Great philosophy and one I apply to everything in life, shame the spinal tap reference will be lost on most of the younger members but essentially if its broke don't just fix it make it exponentially better so you see some benefit from having the pain of fixing.
Will the gearbox handle turning it up to 11?
No, but we have a few options.
The stronger synchro is now going into production and an upgraded gear set is looking likely next year too.
JDR are happy they can sort it.
It only needs to handle a bit more torque.
It's currently 500bhp/470lb/ft.
Most likely it'll end up with 700bhp/550lbft or thereabouts.  Guesstimate!
Edited by BossFox
Most likely it'll end up with 700bhp/580lb'ft or thereabouts.  Guesstimate!
So only light speed then! :)
:notme:
I think getting plans past She is one issue Richard doesn't have!
Got me thinking about warp speed.............
so made this up in honour of Bossfox
Edited by fabdavrav
