Gees RS Wagon
i think a LCR splitter in gloss black would look lovely on petes car. mite have to take mine off when i get the coilovers on lol
  • Replies 2.1k
  • Views 314k
and today matthew, i will mostly be fitting Eibach rear camber kit camber and LEDs! :rock:
Camber shims fitted ready for the coilovers this weekend! has a little play on the way back from brands and the car dont half hold on tight round the traffic circles!!
Pics of during...
me pal come to laugh at me hurt my self..
getting jiggy with it!
Eibach shim shimmy!
cant really see it that much at the moment as the cars not lowered but hold tight on that..
Hopfully i can get the coilovers on at the weekend. I start my n new job tomorrow so hopfully i get time.
edit: didnt get to polish it, or LED it up, but my key and LEDs arrive today so will get on it when i can.
Does camber like that do weird things to tyre wear?
It'd probably stop my 18x8s from rubbing - on the outside at least :D
if you go to much like me pal has on his bug, hes running -3.75 and his will chew tyres up. I ran this same amount on my Bora and the tyre ware was ok. its cambered more for the extra tuck in at the top of the wheel -1deg approx 5mm tuck in at top. for when i slamm lower it, this with the stretch on the tyres and the 20mm spacers on the 18s will see it stanced perfect. (thats the plan any way!)
we will see.. Stance is never that simple! lol
Pic of the arse of the bora on that set up with no rub :) 205/40/18 on a 8j
Will wait and see how yours turns out. :D :D
Fitting spacers here requires low volume vehicle certification. Which cost $460 - about 250 quid. :(
ahhh what! just to fit spacers? Even if there bolt on hubcentrics?
Stance. It's a dark art.
Bora looked good though!
They MUST be bolt on hubcentrics or they're illegal!
I can see the logic in the cert process to stop morons cutting springs in their garages and other daft stuff.
But it's very tightly regulated and you have to have a WOF (MOT) every 6 months once the car gets to five years old and they pick that stuff up and fail you if you have no cert.
thats harsh but good at the same time i suppose. Im not a great fan of spacers that you need longer bolts, have had some crack before which aint good.
can wait to lower it!
How do these camber things work with the calipers then as the discs with be running same camber as wheels but carriers will be running standard angle won't they or do you get brackets for them aswell
na you get shims to space them out mate. :)
looking good :)
Ooooo how cool :)
How much are they and from where if im tempted lol
They from Eibach matie. only about £35 :)
LEDs are coming people i promise! New job and all that had halved my time to stuff!
i have a load of silicone pipes to fit also and a little engine dress up (shhh those that have seen it already) These pods have been doing my head in for a couple weeks so i decided to crack on with doing this.. after alot of shaping again with the heat gun i get prepping..
prep
glue
messy messy
1st lot dried.. starting to rub back
getting there
just given it it last micro layer of filler..so should be ready for primer in a bit. im thinking i mite gloss black my A pillars just to give a bit of shinyness to the interior. after all, the leather is like gloss black no? Unsure yet.
comments?
prima`d up! woop!
looks rough down the bottom bit but this will not be seen. im quite please with the outcome so far.
Do it! go for a nice black colour. Looking good though G.
I have brought the outside of my car in! i went with Black Magic.
yeh i like to be different. hope it looks nice in the car.
will have to take off the passenger side and spray it tomorrow.
Yes that is the next mission, matching up sides.
yours is coming on nicely mate i will pop over to your thread in a sec and have a look at any updates. :thumbup:
just need to drill some large holes in the back for the wires and im done! will see how this coat drys and will continue to add till it looks like glass!
I used the dremel to cut the holes at the back so i had easy access to bolts etc.
what bolts dude?
im just going to use a 1.5" hole cutting drill thingy lol
