Official Briskoda Fabia II Monte Carlo Register
Daylight running lights. They may have been turned off!
under steering wheel is fuse box (behind long plastic trim) pop this off and you will see your fuses. You should also see a switch. This is the daylight running lights(DRL) switch. Turn this on and with the ignition on and lights off they should be on.
  • Replies 399
  • Views 196.7k
  • Just traded in my 2005 Octavia 4x4 estate, owned since new, for a 2014 fabia 1.2 estate.
  • Just got monte over a month ago. 1.6tdi 105bhp Estate Registered Jan 2014 Love it!  Hoping to remap, refurb alloys, and source an arm rest...
  • abaday789
    abaday789
    Bought Second hand from dealer in 2015 1.6 TDI 105bhp Reg in Oct 2012 Wanting to Remap at some point and Install HIDs. Possibly replace rear drums with disc brakes else just respray them due
On Thursday, April 05, 2012 at 07:00, Full Monte said:
Ill start us off
Reg Date Oct 11(61)
Colour Red
Options Amundsen sat,bluetooth prep , Rear E/W , spare wheel ,armrest
Mods Interior lights LED, LED DRLs and sides, Headlights Osram Nightbreaker Plus 90
Ill start us off
Reg Date Oct 11(61)
Colour Red
Hi full monte
Can you tell me what LED drls you used or do you have a link to the correct bulbs i need for mine ..looking at changing my standard drl bulbs for led 1's .
TIA
Mike
  • 4 weeks later...
Just picked this up the other day trying to find previous owner
Edited by ady1970
On 25/06/2018 at 23:48, Kgod1991 said:
2014 Estate
Just recently done rear axle swap to discs
Got a link to that??
Peter
  • 3 months later...
January 2013 (62)
corrida red/black
1.6 TDi
Not sure what options it actually has but happy as it is right now
mods after the warranty runs out will be amusnden sat nav, rear sensors, exhaust of some sort and a remap for eco not power.
Edited by mikey362
Add image
Hello all.😁
Reg Date: 2012
Colour: Red
Options: Bluetooth (I think!)
Mods: K&N 157s Induction Kit.
Eibach Springs Front & Rear
Rally Mud Flaps
Stage 2 Remap 132bhp 160nm Torque
Free flow Rear Exhaust box (to be fitted)
The remap gave me more power and better mpg. If I drive it tidy!🤔 The mud flaps stop that annoying streak of mud and grime that appears down the front doors. Very happy with the car so far😊
  • 4 weeks later...
2012 Black edition . 85hp remapped . 32600miles , cruise , climate , maxi dot and rear parking sensor .
2014 Black Edition 1.2tsi
All standard for now!
  • 5 months later...
  • 4 months later...
2014 Fabia Monte Carlo Estate (1.6 TDI, 105 BHP)
Metallic grey with gloss black trim, black and grey cloth interior.
Bog standard (electric windows, AC) apart from roof bars, ECU Remap, now running 145 BHP, 310Nm torque.
Future plan is to upgrade the head unit and possibly retrofit Cruise control.
2011 Monte in red. Bog standard at the moment but planning on a roll back and remap, shark fin ariel, debadging the rear, Heko’s (done), then just making it nice and tidy with return wheels and a bit of lacquer peel to sort.
Here is my MC 2012. Great car and here in Croatia it is really hard to see more of them in MC edition.
MODS: full led, stagging, new engine maps - from 90HP to 138HP, new emblems.
  • 4 months later...
Never put my car on the list.
2012 Monte Carlo 1.6 tdi 105hp.
Bought with 89,000 miles on the clock and is now sitting at just over 93,500 miles. Will have it a year come February first.
As far as I can make out it came with no options on it, no third headrest,grey seats etc.
Has been modified slightly, its got:
-vRS intake pipe
-Deflapped airbox
-Air filter sock removed
-Dieselgate flow transformer removed
-Heat reflective tape on airbox and intake pipe.
-De-Restricted turbo damper
-New backbox
-Whiteline Rear Sway Bar
-vRS grille striping
-Team Heko wind deflectors (not seen on car, older photo)
-Generic motor factor Mud Flaps.
Not really modified too much but its definately a nicer car to drive than standard. Sounds much nicer too, without being chavvy in the slightest.
I only really plan on remapping it but otherwise i'll just be renewing bushes and what not. It's been reliable in all my time owning it so I dont see a need to potentially mess that up.
As Of December 2021:
-Darkside Developments downpipe
-UlterSport Backbox
-Supersport Coilovers (lowered only about 20mm)
-PSBushings Wishbone bushes
-Powerflex Dogbone mount
-312mm Front Brakes
-Remap to 140HP
-Rear Strut Brace
-Pair of Spotlamps Hidden behind the grille
-Currently on a set of 16" Spyders for Winter duty. Will be going back to the 17s with some fresh rubber for the summer.
Quite a few changes made over the year, most of them due to parts wearing out and so needing replaced anyways. The exhaust was rotten and I happened upon a smoking deal for a nice darkside downpipe and a backbox.
Had to get it mapped after that of course.
The brakes came about as I got a deal on them and was needing to replace the 288mm stuff anyway.
Then the shocks gave out so they needed replaced anyways, and again I got a deal on some coilovers that would work well so I would be daft not to.
Then I noticed the boot creaking like mad so I put in a brace and so on and so on.
I'll probably put a cr170 turbo on as well as a bigger intercooler funds allowing come summertime.
Edit As of August 2022:
-Poly ARB D Bushes (20mm)
-Rear Axle Swapped for a disc one
-New axle stripped and refreshed with polybushes
-256mm vented rears put on
-Intercooler fitted
-Boot sound deadened
-Superpro Steering Rack Bush
-Soon to have caster increase bushes and new Track rods.
Edited by DieselMonte
Forgot to mention mud flaps.
-vRS intake pipe
-Deflapped airbox
-New backbox
What back box have you got for it and where from? Did just a back box make it sound better?
Just an exhaust I found on eBay. It said it was for a fabia and looks like a fabia piece but apparantly it was completely the wrong backbox. The tip was too long and needed some cutting and welding to fit. The tip sticks out slightly under the car now. To me it sounds a bit louder.
  • 5 months later...
Unfortunately I recently lost someone and have inherited a Monte.
Red & black
Sept 2011
Pretty standard as far as I’m aware
Done & tried:- repaint wheels because they had awful scratches and scuffs. (Mum didn’t drive well 😢)
Considering:- Have brakes, shocks removed and either refurbed or replaced. (Everything really rusty under there😯)
Check if I can get cruise control fitted without paying the crazy price Skoda quoted.
Upgrade stereo and speakers.
Find better mats.
Find a boot tidy I like.
Find a 3 spoke steering wheel I like better
Edited by felix79
Registered - December 2012 (62)
Colour - Red
Options - Spare Wheel, Mats, Sunroof, Parking Sensors
Future Mods - Cruise Control, Maxidot, Amunsden+ and Stage 2 Remap
  • 10 months later...
-vRS intake pipe
-Deflapped airbox
-New backbox
-UlterSport Backbox
-312mm Front Brakes
-Remap to 140HP
-Rear Strut Brace
How do you find the 140 bhp remap?
Any issues with reliability, clutch, turbo etc?
What sort of mpg is it doing after remap?
Yeah it's been fine on my car, no issues stemming from it if that's what you mean. Clutch is fine at 120k+ miles, no slipping yet. Turbo and all that is OK too. I did have to replace an n75 valve but that was nothing to do with the map, mine just went a bit wonky. If you service it well and don't neglect it you'll not have any trouble.
Mpg improved after the map, and if you're trying to drive economically it's a lot easier to get more mpg out of it, if that makes sense.
-vRS intake pipe
-Deflapped airbox
-New backbox
-UlterSport Backbox
-312mm Front Brakes
-Remap to 140HP
-Rear Strut Brace
Hi, is the de-flapped air box a DIY job or a new part purchase?
Diy, I used a dremel to cut away at the flap.
  • 3 years later...
Picked up a Monte Carlo for my daughter as her first car, would like to know what the options list was for it if anyone can point me in the right direction.
2013
White with grey seats
1.2TSI 105
Has HID's fitted but that's it I think
Tech Edition
Needs few jobs doing but it's a cracking little car
Edited by JimVrsOctavia
64 plate VRS
Race Blue and black
Has 44200 miles on it
Only had it 3 weeks
