vRS Fuel Filter?
I was careful but the little F###ers broke :swear: , had to change the pipe, not as bad job as it looks, so be
CAREFUL WITH THEM CLIPS FOLKS :rofl:  :rofl:
  • Replies 82
  • Views 16.7k
  • Thanks for all the helpful hints and tips guys. So far as I can make out, there is nothing at all to be worried about or to take special care over.... And on an unrelated matter, if you'd like to spo
  • I haven't got a Mk1 Octy, but if I did have, and needed to change the fuel filter, one thing I would be careful with, is the clips.
  • I'd watch the clips on the filter. They can be tricky !!
I dont want to like that comment as its bad news....
Someone wasnt careful!
Wish I'd never searched fuel filter, Scared now.
Just to check I've got this right when replacing the clips make sure you don't break the the fuel filter?
Correct
  • 10 years later...
On 22/05/2012 at 14:48, IulianE said:
Good luck!Careful taking out the fuel lines,press to unclip.
ok.. ive read the entire thread. and i get it! but how do "press" them? which way i mean? and dont f*****g say "carefully" because i will lose my damn mind! do u press them on one side? two sides, more of a squeeze? theres square holes on either side? im at my end here plz i need genuine help. thank u
I changed mine a few weeks ago. The clip closer to the rear of the vehicle came off with just the press of a finger. The clip on the front end took about 20 minutes of lubricating and slowly easing the clip in and out to get it released.
