Amunsden Plus Bluetooth and Microphone install "How to"
A pleasure mate! Nice to meet you.
Glad it's all working ok, still can't believe they didn't do it from factory!
  • Replies 342
  • Views 101.1k
  • People are getting confused here between the different head units. For a bolero or Columbus you need a box under the seat for Bluetooth. This thread is about the amunsden plus which others have confi
  • .........famous last words! ;)
  • Asked a local Briskoda member with VCDS to help out activating my vrs Blacklines Bluetooth, just took a few minutes, no problem. Ordered the mic on Sunday 3rd Feb from Car-systems, it turned up yester
Yay!! Took the plunge and now have hands free communication. Was slightly worried when i undid the glovebox but all in all a very satisfying and worthy upgrade.
Many thanks to Welsh_kai_boy for his most excellent guide.
ordered the mic today
worked out to be £31 at today's exchange rate
Well mines all working and well made up with it.
I have a couple of questions that I'm hoping someone will be able to answer.
Does the Bluetooth prep in the Blackline differ at all to that installed in an SE plus? Both cars have the same HU so would have thought that the SE plus also just has the BT enabled in the HU and not a separate module like most other Octavias.
Also do I assume correctly that the BT prep in the Blackline does not have voice control? I've found no way of activating it (holding the phone button etc).
Also is there any way to set which device connects to the car by default or is it the case that you have to manually pick and choose using the phone function on the Amundsen?
As I understand it the Blackline effectively has GSM II HFP only prep.
Another massive thank you to Welsh_kai_boy ! Did the install today and apart from mislaying one screw it went like a dream.
To echo other posters thoughts
1. You can route the mic cable without dropping the gbox or removing the a pillar.
2. Removal of the fascia trim is easy if you use the correct tools and take your time, I used the £6.99 trim tools from Amazon and they made the job so much easier
Thanks again, now off to call all my mates to show off my hands free ;-)
Yes - they are quite big but one of them (the smallest one I think) worked well for removing the trim around the Amunsden.
Hi I would like to thank 'Welsh_kai_boy' for his excellent guide for ordering and fitting bluetooth to an Octavia VRS Blackline, I ordered the kit last week and was delivered this morning. Now all I am waiting for is 1st March for my VRS Blackline.
just like to say thanks to H17YD_L for installing my mic and sorting out VCDs activation this morning
great guy, knew exactly what he was doing and a very neat clean job
thanks mate :)
Thanks mate nice to meet you!
Got my Bluetooth activated and mic fitted by ms autos in Reading. Great service although I suspect they made quite a bit of profit out of the £72 they charged me. No grumbles though as it was a job well done.
Now you lot have to the mod bug it's time to get HIDS fitted (£28 London colour) and Numberplate LEDS (£7) with beer money for the coding. Had all mine done last week. HIDS are amazing and LEDs look really cool and lift the back into 2013.
I already have LED lights but not that fussed on HIDS, can't be bothered with trying to hide all the wires (the old lights were better as they had a plastic cover that was clipped in)
I called into Skoda Dealer on Beaconsfield Rd Nr Slough they enabled Bluetooth for me no problem and no charge !
Now waiting for the Mic to arrive any day now.
Big thanks to H17YD_L Hayden, sorted my Bluetooth activation this evening, connected phone on way home, played music off it, called home, without mic connected ( it needs the mic )
Was going to instal the mic at w/end, but got busy and now installed and working. Proper job
Cheers Hayden and thanks to welsh_kai_boy for the great talk though.
Fitted mine today easy when you know how ? Is it straight forward putting numbers in the phone book ?
Itll automaticly add them to the amunsden from your phones internal memory but not off your sims memory.
Phone book updated easily. Have to say the bluetooth works well, why they couldnt have done this at the factory ? Does it have voice activation ? Me thinks not .
Excellent instructions, we collected our Silver Blackine Estate this week, and have fitted the mic and activated Bluetooth today
It works great
Many thanks
Hi just a couple of questions for a novice with a new blackline last week.
1...I tried pairing the phone using the owners manual to see if it might already be enabled and pressing the phone button just mutes the radio so not able to pair-is this correct so means needs VAG comming
2.The orginal link to microphone kit http://www.carsystem...only,id387.html says "Not suitable for vehicles from 2012 model year" im sure this has already been answered but will it be ok for mine which would be one of the last produced.
Kind of nervous removing The touch screen surround trim!
cheers if anyone can advise
Edited by Geestur
The microphone in the link worked fine one mine.
I wrote the how to, you will have no issues and the trim comes off quite easily (some say start at the bottom by the ash tray).
if you arent sure order the mic and take to your dealer or local ice installer . show them this thread. get. a VW or Skoda dealer to activate BT .
