Eddie-NLs Octavia Vrs Estate 170CR
Eddie-NL
I had to run another extension cable from the roof antenna to the radio, which was easy.
What type of cable did you use for the DAB?
It's an upgrade I'm thinking of doing, but can't fathom whether it would be the same cable type as for FM (with phantom power) or a different spec.
Hard to believe that a year has passed sinced I picked up my Vrs
My first mod for the 2nd year is
Have a Break!
Hallo Eddie.
Can you tell if this I possible to code on a 2011 facelift Octavia without any parts.
Or what do I need to do the trick?
Thanks. Great topic you have here.[emoji106]
Hi. I just retrofitted a Columbus DAB+ with 5-way sharkfin antenna. I got a DAB extension cable from Skodateile, it has FAKRA A (black) jack connectors.
It will depend on what gateway you have
My gateway i this one:
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AG    HW: 7N0 907 530 AG
   Component: J533  Gateway H53 1634
   Revision:   H53       Serial number: 101212F1000598
   Coding: 352302
   Shop #: WSC 73430 790 00217
   VCID: 75E10756DC613BB6B75-8020
No fault code found.
Does it do the trick?
   Coding: 352302
you can't tell by looking at the part number
you can only find buy out by trying an output test
Nearly 2 years since I picked up the vRS, time for another mod
Headlight Washers all fitted and working, before I anyone posts "what is the point of these"
They will be required if I end up up retrofitting Xenons, which nearly came close as I bought 2x headlights, but unfortunately the Courier managed to damage them.
Anyway the markings are on the underside of the bumper, so I plucked up the courage to make some holes in my bumper
https://www.youtube.com/watch?v=F4BMARZk0ag&feature=youtu.be
Edited by Eddie-NL
photobucket ransom
  • Like 4
