urgently pls help
PLEASE HELP. I have a skoda fabia mpi estate aqw engine code car and two month now I am trying to fix the emission problem after failed on Mot. The CO 1.697, 0.950 lambda
What I have changed so far: thermostat, coolant, genuine: coil unit, plugs rear lambda map sensor, manifold gasket, air hose with new clips, cleaned throttle valve. cat test with vcds ok, front lambda a bit slow but ok, cylinders pressure checked ok,
No fault code. Previous fault codes 17564, 17549, and
16588 - Injector: Cylinder 4 (N33)
P0204 - 35-10 - Circuit Malfunction - Intermittent
16587 - Injector: Cylinder 3 (N32)
P0203 - 35-10 - Circuit Malfunction - Intermittent.
At the moment. Last emission control the CO was 1.300. on fast idle after I changed the above parts. The electrician told is not overfueling the engine.
Wednesday,13,February,2013,20:51:55:37412
VCDS Version: Release 11.11.0 (x64)
Data version: 20111111
Address 01: Engine (047 906 033 H)
20:51:52 Group 046
1408 /min RPM
408.0°C Temperature
0.84 (no units)
Cat B1 OK
Coolant temperature sender checked working fine was increasing 1.5 C and the thermostat was opened on 88 C
08:34:13 Group 004
768 /min RPM
13.33 V Voltage
84.0°C Temperature
45.0°C Temperature
Thanks.
The probable causes for these codes are:
  • wiring
  • injector
I'd be inclined to carefully check the wiring before condeming the injectors.
SN
