Sport Mode DSG
Until today I've never driven my car in sport mode.
A short blast at legal and sensible speed on a C road then B road was great fun.
I use these roads regularly in D mode and my Yeti steps up into 6th a few times, However, in Sport, despite settling at 60 MPH cruise at the end, it did not flick into 6th at all.
Is this OK?
As always ... thanks in advance
Nigel
my dsg7 won't use top gear in S mode
hope that helps
Yes it's fine.
It uses the highest gear for economy, not a concern when using Sport. :)
If you select cruise control when sport is selected it would have used top gear.....
By the way that is normal behaviour.
If it's the same as my 6 speed DSG in the Octavia Vrs, in sport mode in 5th on the red line the car is doing it's Max speed thats why it won't go into 6th
The wife's Fabia Vrs wont go into 7th for the same reason
I think
Been driving around in a Octy II 1.2TSI DSG 7 speed for 2 weeks now and been trying to get to grips with it through experimentation. Not normally one for 'auto's' but I'm getting to like this engine and box combination. Likewise found the box will not use top in sport but I was aware this might be the case from my dads experience with his previous Superb. No cruise on this loan car, which was a shame as it's crying out for it with DSG.
Points I was less keen on being the selections the box would choose on hill decent; went into engine braking in a big way, getting down to third and 4 to 5000rpm + on a number of occasions. Tried selecting fourth manually and on all but one occasion it let me. Next not so keen on the manual selection as my brain must be wired differently; I want to push forward for a lower gear and pull back for higher, so I've really upset the engine on a couple of occasions :giggle: Finally the way it can take off if in drive with brake released and no accelerator applied; seems a tad dangerous to me.
TP
Thanks for all your responses. I guessed it was the case but it's important to know.
I will try again with cruise set
Nigel
I can confirm that it won't select 6th in sport. Have to say that I think sport is redundant in the diesel as it develops peak torque at low revs. Leave it in D and just shove your foot all the way down when you want some poke and you will be just as fast. Quite the opposite to the 7 speeder on the petrol engines where sport is a hoot - albeit a tank and wallet emptier!
I'm not sure sport is redundant. Throttle seemed sharper and it flicks into first at junctions more readily than D.
It just feels a bit sportier too with more revs.
I quite agree though by crushing the carpet in D it goes rather well.....and catches many a boy racer out....so I understand :giggle:
I have never understood sport mode on the Yeti (or my Octavia before it) all it appears to do is change up later, hold onto gears for longer and not use top gear.
I have not noticed any improvement in throttle response.
Whereas my e39 BMW's it sharpened up throttle response as well.
Sport mode does seem to improve the little TSI as does the new ecu sport mode on the Octy III, which appeared to have a similar effect with the 1.4 TSI manual.
TP
Tried it out myself over the weekend en-route to our caravan. I found acceleration was much quicker and held onto gears longer, but never went into 7th gear even on the motorway. I soon went back into drive when I saw what it was doing to my fuel consumption
I was under the impression that the DSG will not go into top gear myself but I took note of this the other day and it does.
TP
Maybe then the TSI petrol DSG is different, as the Diesel DSG in sport mode doesn't do much.
I think the throttle is much better in Sport. 2.0tdi, so is take up shame it doesn't have launch control like my A5 3.0t di dsg.
Sport mode is a real hoot, I love leaving the boy racers behind, well, over a short distance anyway - but victory is sweet. :rofl:
For a really fast get away go to manual - the system will not allow it to be over rev'd. I've not done this but recall a YouTube video, which I can not find, where the guy just floored a Golf TDi for an electric response with the box changing up at MAX revs.
Anyone brave enough to confirm this?? :devil:
Is this the one you were looking for ?
:devil:
Sorry Brijo should have said it was a dsg in manual 'tiptronic' mode. Good video though and does prove a point about standard manual v dsg just in sport mode.
The video I recall was from the USA.
No problem. It was this clip that reassured me, last Spring, that going DSG was not just for old f*rts :angel:
Absolutely agree with that. I remain so very impressed with our new 140/dsg set up.
Actually the quickest way to get away is the launch control:
1) traction control off (TCS)
2) DSG in mode S
3) both brake and throttle pedal to the floor: if the car runs smoothly at between 2 and 3 Krpms (petrol higher, diesel a bit lower) the the launch control works and is activated
4) let go of brake pedal and awaaaaaaaaay you go - beware of traffic ahead :)
2) DSG in mode S
Doesn't work on a Yeti. The moment you press the throttle and the brake the engine is cut...
Blasted nuisance when you want to left foot brake on a slippery surface!!
And its harder to dry out the brakes after driving through water...
