Enabling cornering fogs with VCDS - updated for vRS
Hi, anyone succesfully activated the cornering fogs for MY18 RS245? I followed the steps but still could not.
  • Replies 191
  • Views 47.5k
  • Just checked, they do both come on when I put it in reverse which is not a bad idea especially when you are reversing out of a tight spot and the front swings at a large angle!
  • I  now have 2 rear fog lights - an absolute doddle!   I'm posting the adaptations in a minute.   Why Skoda dealers can't get their head round this is beyond me ............   http://www.briskoda
  • Nice work lads. Shame the same can't be said for Skoda UK   So as originally thought, instead of simply activating the cornering fogs during manufacture, Skoda UK have instead decided to issue a rev
When you're testing it, make sure your light switch is on 'Auto' and it is nighttime.
Sounds daft, but it caught me out when I activated on another member's car
Yes I'm always on auto. But confirmed it does not work. You have tried on MY18 RS245?
I've done it on a facelift my17 mk3 184, but I can't for the life of me remember how I did it.
Hi
I did it on my MY17 VRS 245, using OBDEleven PRO
The link to the thread with the OBDEleven screenshots is here,
On 10/12/2018 at 06:53, vfrguy said:
Hi
The steps in the obdeleven do not work as well. In fact, it caused light error on fog light.
Please from doing on a MY18 RS245, not sure about other rides.
Hi
Is your car LHD or RHD?
The screenshots are for a LHD (I think), I had to alter them a little for my RHD VRS
If yours is RHD, I can send you the screenshots
4 hours ago, vfrguy said:
Hi
Mine's a RHD...THANKS!
Hi
OK here are the OBDEleven screenshots from what works on my RHD MY17 VRS245.
I have also posted my notes from when I coded my car, it works on mine, good luck!
Central Electrics-Adaptions
Leuchte 2SL VLB10 Changed Lichtfunktion B2 from nicht active to ‘Abbiegelicht Rechts’ (same side as A2)
Leuchte 3SL VRB21 Changed Lichtfunktion  B3 from nicht active to ‘Abbiegelichct Rechts (same side as A3)
Leuchte 4TFL LB4 Changed Lichtfunktion  B4 from nicht active to ‘Abbiegelichct Links (same side as A4)
Leuchte 5TFL RB32 Changed Lichtfunktion  B5 from nicht active to ‘Abbiegelichct Links (same side as A5)
‘Static AFS Light’
Changed ‘Abdimmgeschwindgkeit from 0 to 50%/S
Changed ‘Maximaltemperatur’ from 0 to 100 C
Changed ‘Obere Grenztemperatur’ from 0 to 95 C
Changed ‘Untere Grenztemperatur’ from 0 to 80 C
Also changed ‘Obere Geschwindigkeitsschwelle’ from 40 KPH to 80 KPH (top speed at which cornering fogs work)
25 minutes ago, vfrguy said:
Hi
‘Static AFS Light’
Thanks. Will give it another shot when I have the time and update back.
By the way, the notes do not quite tally with your screenshots, but I get the principle of what you are doing.
Hi
You are absolutely right! I should stop writing these things late at night!
The screenshots have just been taken off my car, so I hope they will work for you.
Good luck again!
8 hours ago, vfrguy said:
Hi
Good luck again!
I tried according to your latest screenshots...
And it works! Thanks a bunch.
Hi
Pleased it worked for you, I knew we get there in the end!
I think the first set of screenshots are for a LHD car, because I got the foglight alarms after I used them, but I managed to work it out.
Cheers
  • 11 months later...
Could anyone help me to activate my cornering for lights? I have tried the usual way which I did my previous Octavias (2013,2016 and 2016) but it didn't work. Coding was accepted though Via OBD11.
BTW, Car is Octavia 2017 1.4TSI 150BHP with split headlights (LED Head light and tail light)
Also I want to activate both of the rear fog lights and turn light (when boot lid is open).
thank you in advance.
Skoda Octacia III RS 2019 model 2020, I wanted coding the cornering but no succes. I did all combinations, which I know (and did before on other cars  up to 2017 2018...), and which are here showed too, including RS modifications, including the temperatures 100 95 90 etc, but these lights still not works. The car have full led lights with led fogs + virtual cockpit. Looks that this unit needs something new coding...
Welcome @Steve001001
Can you post a VCDS autoscan along with an adaption map from 09 and I'll take a look :)
  • 3 years later...
Hi guys
I have a Skoda Octavia mk3 2019 1.6 diesel DSG.
I am trying to activate cornering lights to come on and followed the instructions and changed the first two adaptions. I still can’t get cornering lights to work. I did have cornering lights activated two years ago but I recently had a replacement BCM UNIT installed and updated by a specialist and got component protection removed. Since I’ve not got the cornering lights activated anymore and really would like to have this on my car again.
any help would be much appreciated.
