How to enable Traffic Sign recognition
I certainly lost my speed display in the RNS too.
Speed display in the RNS comes back only after ''bus ruhe''. So, when you code TSR, it will not be displayed on RNS. But you just lock the car and leave it for the night and in the morning it will display it. Tested on several vehicles.
I expect that if you recoded back everything you did, it should pop back up after good night sleep :).
PS: Did you enable it in RNS settings?
Edited by mtl
  • Replies 350
  • Views 180.1k
  • Some good news - I have just coded this on a vRS with Lane Assist, Bolero and standard Maxidot - AND IT WORKS!!!!   Photo to follow soon ........
  • andyvee, still time for you to be nominated for most helpful member of the year award. You get my vote
  • Sod all of this stuff (coding, Sat Nav etc), I just the cheap option of road sign recognition. Mk1 Eyeballs.
Thanks for that MTL. I'll try again when I have more time and feedback.
Can this be activated within the Columbus settings without plugging anything in and changing codes etc?
No.
You can turn the speed signs embedded within the map data on and off though, but they only show on the Columbus, not on the MFD.
Just tried it on a vRS with Amundsen and even with the navigation set to MIB Standard the restricted functionality message is still there grrrrrrrr......
Morning Andyvee, did you ever get this to work without the warning message on the Amundsen?
I am not Andyvee, but sadly no. It will still give out restriction message.
Nope, and without having regular access to one to have a good play I doubt I ever will.
Next time your in the area, your welcome to test yourself on mine!
Was over in ChezVegas on Sunday :( , might be back over soon though
mine is available for prolonged periods of time if you decide you would like to attempt - as long as you reverse any failure...
Cheers, at some point I might take you up on that :)
  • 2 months later...
HAs anyone tried this on an MY16, I just did on mine and the channel descriptions have changed, but it rejected the first adaptation.
Try changing the corresponding Gen2 adaptations
Sent from my HTC One_M8 using Tapatalk
I did, it was on the first adaptation, I picked the gen2 version, just to enable it, when I applied it , I got an error message saying it was out of range.
What do you mean by 'first adaptation'? - Do you mean 'vehicle function list BAP traffic_sign_recognition_0x21'
If so, send me a full adaptation map of 5F from a MIB2 Columbus and I will have a look
What happens if you do the other adaptations and coding first then go back in to 5F and try to enable this?
What version of VCDS are you using?
Hi Andy, I have just been thru it again and I did the first bit last and it seems to of gone in this time, I will pop out and have a drive in a bit.
I don't know if this is a new but in the car settings menu there is an option for trailer traffic sign recognition
This option is ok, though I think that there should be another option above it, that enables display of traffic signs at the top of MFD.
Yep, seen that on some and not on others - do you have a towbar fitted?
Nope
Took it out for a spin, seems to all be ok, not sure how much recognition is coming from the camera and how much comes from the satnav, but it seems ok
Hope to get this sorted on my my16 amundsen soon!
I just do the first command last and you should be ok
Top tip: save money on option extras on new cars by looking out of the windscreen and remembering what the last speed limit sign was.
:donflameproofsuit:
Can't do it, I have a 100% tint on my windscreen!
With Amundsen it does not work ok due to limited functionality.
