How to enable Traffic Sign recognition
http://flic.kr/p/iHSCKB
http://flic.kr/p/iFSjJg
Controller 5F (Information Electrical)
10 - Adaptations
Select channel: (63) vehicle function list BAP traffic_sign_recognition_0x21
Adjust Value to activated
Channel: (151) vehicle menu select-service menu_display_road_sign_identification
Controller A5 (Front / front view camera)
07 - Coding
Byte 1
Bit 0 Enable - "01 traffic sign recognition (FTE) active"
Controller 17 (Instruments)
07 Coding
Byte 5
Bit 2 Enable - "Traffic Sign Recognition installed"
16 - Security Access - enter 20103
10 - Adaptations
Select channel Display end of speed limit symbol
Change to activated
Hi Skodissile and thanks for the info however I am having difficulty in accessing the system to begin to reprogramme it.  Would you mind giving me a step by step guide please - my car is a 2014 Octy Ellegance with the Amundsen system which I originally thought was supplied with both Traffic Sign Recognition and Lane Assist but apparently I was wrong according to the dealer.  I would appreciate any help on offer please.
Thanks,
Nosnehm
  • Replies 350
  • Views 182.3k
  • Some good news - I have just coded this on a vRS with Lane Assist, Bolero and standard Maxidot - AND IT WORKS!!!!   Photo to follow soon ........
  • andyvee, still time for you to be nominated for most helpful member of the year award. You get my vote
  • Sod all of this stuff (coding, Sat Nav etc), I just the cheap option of road sign recognition. Mk1 Eyeballs.
Thanks,
Nosnehm
You need access to VCDS running the latest version of the software.
Detailed instructions are here.
BUT you have to have Lane Assist, otherwise you don't have the correct camera. The smaller camera for Intelligent Light Assist doesn't do Traffic Sign Recognition.
Does anyone know exactly what is required to retrofit Lane Assist on the Elegance? Is it just a case of fitting a second camera for Lane Assist (or is it a large single camera for both Lane Assist and ILA on the VRS) and coding via VCD, or is some other hardware required? Is the wiring in place already, as per the VRS?
Like Nosnehm, I saw the speed signs come up on the Columbus when I test drove the Elegance and I assumed it had Traffic Sign Recognition as standard, so I'm disappointed not to have it. Do I really need it? Well, I've driven for 41 years without it, so the answer is no, but it would still be an impressive capability, as are many of the other "nice to have" functions on modern cars.
Well for a start you'd need the proper LA assist camera and the windscreen to go with it, doubt the wiring will be there either.....
.... and very deep pockets.
Sounds like a non-starter then. Ah-well, perhaps in another life!
  • 5 weeks later...
Out of interest does lane assist have to be enabled?
I can't see that this has been answered, does anyone know if you activate the traffic sign recognition via VCDS do you need to have the LA activated for it to work?
No you don't, they just share the same camera.
Thanks Andy :)
With regards to disabling the error, is it likely to be a case of we can't or a case of we haven't found the option yet?
I'd love to enable this, but it's not really an option as long as there is an error to annoy SWMBO. :-D
P
Sent from my D6503 using Tapatalk
One thought on this, is there a value we can set to make the car think we have nav, thereby removing the error?
P
P
If you don't have nav then I wouldn't enable this as it'll speed limits wrong, was telling Andyvee how mine once shown a limit of 100 on the m56..... Other time it missed speed mint changes...
Shame, it's quite cool...
P
P
I ran it a couple of weeks and it was to 75% of the time but because of the number of times it got it missed changes in speed limit it couldn't trust it with my license. I'm sure it works fine conjunction with satnav.
It just occured to me that the 100 might have been off of a truck decal that they have on the back. I'm not sure for UK trucks, but here busses and trucks have these 80/90/100 stickers that look just like speed limit signs. Considering the 'dumb' computer can't figure out where it came from without satnav.
Would be a great option to have like this for free, but not without satnav.
Can someone with lane assist post a picture of the back of rear view mirror ? Are the part Nos definitely different.
I have an elegance without lane assist and the Amundsen shows traffic signs on the nav screen but not the central display, obviously this info comes from the nav data.
Those are from the nav data. The cameras are very different.
Sent from my HTC One_M8 using Tapatalk
Look at a vRS windscreen. Has a huge screen module containing the lane assist camera (which also supports high beam assist if ordered) and the light/rain sensor.
Elegance models without optional lane assist have a completely different arrangement...the high beam camera being on the mirror base and is only capable of high beam control.
You need the lane assist module and nav for traffic sign recognition. Im not sure any UK cars have had this fully coded without error, is an option we cant get here but offered elsewhere.
Hi, I am in Bristol and would like to get Traffic Sign Recognition on my mk3 vRS which has Lane Assist, Amundson and standard maxidot - anybody local who can do this for me please?
Hi guys, when you enable traffic sign recognition does a warning appear on your car status when you meet a sign that the car can't read? Is there a way to remove the warning? It warns me every time I restart the car.
Thank you!
Yep - you get a limited functionality message - which means it isn't merging the data from the sat nav maps and the data from the camera.
Haven't found out how to get round that yet, when I see a car with TSR from the factory I might be able to work it out.
Not worth ordering for £300 as a VCDS can enable it for Free ( or beer money )
Yes it seems that the nav doesn't have some "communication" option active. I will investigate with the software. Thanks again.
Or it is one of the unnamed installation options on the CAN Gateway. Installation list; specified installations-Node_0x21 might be of interest.
TSR isn't available in the UK on the O3 so can't get my hands on a car to compare it to.
What's the advantage of Traffic Sign Recognition? How does a small symbol on a screen out of my eye line inform me better that an actual real life sign that's in front of me?
