MAP Sensor, Fabia 1.4mpi
Can anyone help me locate the MAP sensor on the Fabia 1.4mpi ?
I'm getting the code P0101 and the engine management light is on. I'm also getting less mpg than usual. From what I can see, I need to replace the MAP sensor. I can't find it to replace it.
Any help would be appreciated.
Hi there,
The MAP sensor on the MPI is below the throttle body at the rear. Here's a picture that another member posted a while ago, that shows its location.
Thanks very much. And thanks for such a quick response too.
You're welcome :)
I eventually got a chance to replace the sensor. I wiped the codes, went for a drive and sure enought the engine light came on again. Back to the drawing board.
The picture really helped though. At least I could find the part.
Edited by MCostello
