Bagged and smooth mk2 fabia vrs (pic/video heavy) now sponsored :)
I looked into them but ended up with the double sided suckers for about £3 from ebay. No marks on the paint plus I've done about 130mph with it on and it dint move :)
On a track day of course [emoji6]
Personally I don't like the Show N Go ones, I'm not quite sure what the attraction is, what exactly do they do? I know they flip down when the car is on show but the £3 suckers sound spot on.
Can you have black paint on lettering without it being on a yellow back ground or have I misunderstood?
I do agree with the numberplate in the window not being a great option, I can see it drawing attention to the car.
I would give my right pinky finger for this car if you're ever in need of a donor!
Sent from my SM-N9005 using Tapatalk
  • Replies 694
  • Views 117.5k
  • So the last piece of the puzzle is done. About a year ago again lol I got some focus rs seats (recaro cs) and was unsure on what to do with them... Had this idea of doing them in the standard vrs c
  • Driving to work the other morning at 4.30 am
  • So this morning I was like a kid at Xmas and the good weather outside. I was out there at 7 this morning swapping the wheels over which I've had for about a year.... OZ futura 3 piece splits paint w
It'd be on a white background on the nose of the car, yellow on the arse-end.
Don't get the point of the show n go plate holder... Unless you are trying to be deliberately subversive! Is there a reason not to have the plate attached permanently, Ant? I ask as the rear seems to stay, why not the front? I am guessing show-ers want to give a cleaner look the the front of the car, during a show.  Personally, I'd prefer to fit a nice frame around a fixed plate... Unless I had a rotating plate like James Bond's Aston, (Idea Later nabbed for the first Transporter film).
Edited by mrgf
it'd be on a white background on the nose of the car, yellow on the arse-end.
Of course, wasn't thinking
i don't like the price of them I know a lad that was selling one for £100 second hand aswell. In the end I got stopped by the traffic police after having the plate in the window for about 3 years can't believe I got away with it for that long but then again I don't race around on the streets just go to work, school run and gym (sometimes)
i paid a lot of money to have the front smoothed out then the smooth grill painted. It looks a lot better at shows when there is nothing on the front... I seen them James Bond rotating plate holders for sale hahaha. Personally I don't like the frames around the plate.
So are the TT Jacking points worth doing, is it safe to jack the car up on them with a trolley jack, asking as I've been using the rubber pucks over the normal jacking points on the sill?!
the tt jacking points are more for with its on the 2 post lifts. I've used the rear ones though but not the fronts. Hope this helps
Thank you :thumbup:
So lastnight I had a drive down to Derby to pick up a tmc tuning box from Sam, very easy to fit. I'm going to make fit better at the weekend and make a bracket for the box. So I started it on setting 7 took it for a blast and mid range seemed to be better, when we got back to Sams I turned it up to 9. Then I set of home and WOW the car flys now. I'm hoping to get to shark performance open day in August to get it on the rollers. I'm hoping for a good result now with all the mods on the car.
Quick update of mods
Forge fmic with boost pipes
Cobra sport tbe with decat (heat wrapped)
Gfb DV+
Vwr replacement filter
All the plastics cut out, front grill, airbox and a spider web in the boost pipe
Tmc tuning box setting no.9
Should be fun now to drive.
Ant
Make a difference on number 9 then? More top end? With that 7 speed it does fly through the gears
Still impressed on the comfort with the air ride!
Sam setting no.9 is like an animal now. From about 4500-7000 rpm goes so quick and you can feel the car pinning you into the seat when in manual with traction off
So far so gooooood...
I would say to anyone to get a tmc tuning box if your not bothered about a remap on your car. I'm hoping to get the car to the shark performance openday on the rollers to see bhp it's kicking out. I will post up the graphs or videos :)
When is the open day ant?
Sent from my LG-D802 using Tapatalk
I'm sure it's on the bank holiday Sunday. I'm going up for the morning then heading back home for about dinner time.
You going?
I don't think so bud
Is it any good
Gfb DV+
Ant what is the spider web in the boost pipe???
Is it any good
yeah there not bad pal get a good mixture of cars go.
Gfb DV+
at the back of the engine at the top there is a boost pipe take the rubber hose off and you'll see the web. I cut mine out and try to smooth it the best I could to get better flow ;)
You know those grills in the boost pipes are there to create turbulence so the air and atomised fuel mix more efficiently?...
No I don't know that I thought it was to reduce the power or stop any crap getting in somehow. Oh well it's been done for over a year now and still get the same mpg
and vw wasted all that money developing the intake system :D
The webbing/baffle is more likely there to reduce the noise from the turbo Imo. The audi tt has a baffled charge pipe too for this reason. The air flowing through the pipes would be turbulent anyway and the ribs would probly aid in generating laminar flow - think of the mesh in a maf sensor.
Most of the money is spent on refinement and noise reduction and ease of assembly. 90% of engine components will be a compromise because of this.
its a different charge pipe design on the tt which uses an external baffle like an exhaust pipe, not an in line gauze but yes that does serve reduce noise.
then they pop a little speaker in the engine bay to drown out the sewing machine sound!
