Building a Citigo Junior Rallycar
  • Replies 155
  • Views 53.3k
  • First rally today a few problems at the start car went into safe mode due to nipped abs wire on the way to the start line two stage maxs . Got it sorted thanks to Gary and kyle  White and the a sanpon
  • Car on its wheels was at the Scottish championship prize giving yesterday collecting my trophy for winning the Scottish championship
  • panels fitted
starting front brake piping
sterring column fitted and pedals
button box
This is awesome!
Reiger  suspension fitted
1kg lithium ion battery and alloy battery box
Light weight spa gas fire kit
co drivers foot rest
air intake
front bumper fitted and towing strap
lightweight bonnet pins
swicth panel completed and wired
Awesome stuff!
Sent from my SM-G920F using Tapatalk
Good work
I had forgotten all about this thread.... Awesome updates and great work gone into it.
Proper job!
Moving on quite quickly too, well done.
Look again at the Luke "recovery strap" you have fitted.
From experience of having worked with many of the Rally Recovery operators they will NOT use it, but will always use a solid mounting for their recovery cables.
Your battery carrier needs the top plate insulating to stop it shorting on the battery terminals.
And whilst the matt black looks very nice I suspect that after the first event it will start to look very tatty very quickly, especially where stickers have been put on.
How have I now seen this thread before.
Great project, and looking forward to seeing what it looks like when it's going :)
I think the matt paint looks brilliant :) but.. can imagine it being a pita to keep clean.
car is loking really really good, looking dorward to it being finished and seeing some action :thumbup:
hi thanks for the advice there is  rubber top between the battery and box which i haven't fitted yet needs to be done before log booking .
will have  look at the tow eye the mounting is behind the bumper we will also have a towing eye on the sump guard attached to the sub frame .  the matt black is for my main sponsors new product more to come on that in the next few weeks .
Edited by pben123
This is just bonkers, huge props though for doing something so involving at such a young age, got any plans to put the skoda badges back on? Quite liked the look of the black badges
I've lost track in all the awesome photos, what engine's going in this again? Just the 1.0? or something else? What's the power output?
Edited by Camlep
Just the NA engine, some tuning tweaks but there's regulations to adhere to :)
Badges sprayed gun metal grey will be going back on .
just the standard engine  with 1 3/4 inch exhaust with vortex box in the middle and sport cat .
air box removed and induction kit to front bumper. thats all we can change in the regulations  the citroen is 84hp would expect Citigo to be a few more .
We will put fedro Ds3000 pads in the front and have changed suspension struts to adjustable uprights with cast or and camber top mounts .
Regulations are very tight but this make us try and carry as much speed as possible and get the set up right it would amaze you how much a few clicks on the suspension can make to your times . In the last senior rally we competed in we would have finished 4 th over all beating escorts, subarus ,focus with lots more Hp and Power which proves HP is not everything
when we move out of Juniors we can add a bigger engine and a  sadve sequential gearbox .
Good man :) keep up the good work
belts fitted
seats fitted
carbon floor drivers side
some more safety gear
co drivers floor and hand held ext
Car looks sweet pal, something different to the C1/Aygo/108 and the Micras.
You going to be back over here in Scotland next year for the J1000 again? If so, I'll maybe see you at Crail in June.
mudflaps fitted think i will spray the brackets black
we put the car on the scales tonight  753kg just need to Fit windscreen in (10kg) and sump guard  (10kg) driver and co driver are 160kg so we are on target for 950kg with little  fuel and spare wheel 15kg  should bring us to minimum weight \  still need to corner weight the car and set suspension height .we were a bit worried that car would be over weight but all the weight savings form the start have worked .
Edited by pben123
there is a good chance we will
car of to skoda john mulholands to get ABS immobiliser removed
Looks like you are going to need to dig a bit deeper in the pocket for your entries this coming year!!
www.corkmotorclub.com/Club-Members/2016%20Insurance%20MI.pdf
Have you looked at the new Regs for harness length and angles to take into account of FHR's next year?
