Nice little project but I'm guessing this is to locate your car if stolen? Can I ask why you'd want it back?
Looks interesting but moved to a more appropriate section.
Very interesting indeed. I'll have a proper read when it's not so late and I'm so tired.
Not enough Likes available for this post. Brilliant guide.
Nice neat little project indeed. I've played around with APRS units using VHF radio equipment, they report direct via base stations either locally or can go through a gateway and out to the net (www.aprs.fi) is the most popular site. Got to say though yours is defo the best option for the majority of people just wanting tracking.
As the post took an age to do annnnnnnnnnnnnnnnnd I was half asleep I forgot to say that all of it is password protected, I have also started setting up encrypting the data from the car using MQTT SSL.
From start to finish, you could do all the above in a few hours, it doesn't take that long once you get started.  The other handy thing is that I create images along the way which people are free to download if they wish.  They are sanitised for anything relating to my IP or Passwords and are generic, but you'll have all the software installed, just need to add your own config.
Power requirements are tiny, the Pi uses less than 2w of power so costing over a year is circa £6.
There are a few more things I want to do with it or what you could do with it :
1)  Enhanced mode which tells me when the car moves and Im not in it, Ill either use Bluetooth or a RFID fob, fairly easy to do using GPIO.
2)  Sensor Unit, comprising of 3 Axis Accelerometers, in case of impact collision.  This data will be stored locally and not transmitted.
3)  Install a solid state relay in line with the ignition with a button in the Map Panel to effectively "disable" the car by loss of power (not steering or braking just power), tied into speed so if it is TWOC I can merrily stop the car.
4)  Add a camera which records video on a 30 minute loop, in case of accident.
5)  Haven't thought of anymore yet but you get the idea.
Most of it is preventative but having paid 27K for a car, I want to have some peace of mind over its location.
+ 1, Brilliant.
You are a very bright guy Nuriyan, well done.
I work in IT bur am not geeky enough to do something like this so applaude you....you could probably sell them!
Very nice work there, I already have one ras pi, so I may just get me another to try this out  :thumbup:
I'd be happy to stump up a modest sum for such a device, assuming it could be wired/plugged into a vehicle by an orangutan like myself.
Brisky Group buy anyone?  :)
Edited by Gwilo
  • 4 weeks later...
WOW....we are not worthy.
