Phil's Fabia 1.8t Build Thread (ex 1.2 12v)
Don't think anyone would be daring enough to nick mine lol,
top progress Phil :), it's made me kick my arse into gear and get last few bits done to mine ready for mot
  • Replies 978
  • Views 143.9k
  • Few parts to add to the list.. And new 'daily/drive to track day' wheels arrived. And fit :-) Then i've been to collect some of Bens parts he's no longer using on his Fabia.. Fibreglass boot,
  • All fitted, all rattles and clonks gone. This Scale suspension is the shizzle. So well made its defintly worth the money. Damping set to halfway (6 clicks out of 12) Up on the ramps stripping everyt
  • Fitted driveshafts and all bolted up. Wheels on and lowered to the floor. All intercooler pipework installed, just front bumper to chop up to fit.   Started it and it runs!!! WHOOOOOOO
Haha. Theres an 05 plate version of mine on the road i have to go up to get to my house. Gonna steal his manual front windows [emoji23]
Hope your coming in it on Wednesday pal to the east Midlands meet.
Probably not, dont fancy wasting half a months tax. Also want to get front door windows working as it'll be a bit cold with them down haha
Today has been wasted on the other Skoda seen as its been neglected in a few months..
Doesnt scrub up too bad, removing shiny wheels for its new winter wheels.
My new air filter arrived today. Need to crack on and relocate battery before i can fit it.
Started the front doors, all i want is speakers and working windows..
Electric windows on front are ****ing me off big time. They have 12v to the motor and two wires to the switch. On both sides. I can operate one perfectly fine, up and down for ages. Then go to the other side and it doesnt work, unplug it all, plug it in and its fine all works. Go back to other side and it doesnt work again. The only thing in common is the ignition live and earth. Every other wire is disconnnected [emoji35][emoji35][emoji35][emoji35]
Totally annoying
The control unit in the motor runs on 5v doesn't it, not 12v?
Theres 12v to the motor, then when you operate the switches it goes up/down. Didnt check if it was 5v seitching. But surely as i have everything disconnected each motor should run regardless what the other is doing? How will they know? Confused
The drivers control unit is a master though with the others being slaves. Every other door is still routed through the drivers control unit. They aren't just switched polarity motors.
so can i not just bang 12v on each motor?
I dont see why not, they will be totally indperndant that way..
If you bypass the control unit then I guess so. Remember you will also be bypassing relays and thermal fuses.
They have a ignition live run in to them now..
Hopefully through a relay.
Through a fuse [emoji23]
How would i fit a relay? The switches dont switch 12v. Just 12v to the motor and lower voltage on the switch. It'll be fine.
Got my RSRs fitted to my FR wheels today. Gonna scrub off the melted rubber, should see another trackday.
Loads of life on them :)
Snap am having the same issue on mine and when I read the cods it's saying my driver side module is faulty when a i know 100% it's fine,,the seat ones don't even work anymore I can only think to recode them via vagcom what ya think
Smash 12v up them [emoji23]
Had a few hours on the Fabia today as it's my last day off. Finally got round to doing rear suspension, only changed springs as the AP shocks were knackered. So running standard shocks on them.
Out with the 14" steels and on with the FR 16" alloys and Federal RS-Rs.
Fronts look so aggressive but still subtle until you realise the tyres and brakes haha
Tested the clocks to see if the fuel gauge went the correct way, filled up with fuel.. It does. But before that i had to do some fault finding, i must have blown the fuse for the clocks whilst messing re-wiring the doors. All sorted and working again..
All ready for 1/11/15 when i can tax it, insurance starts then too [emoji41]
