Phil's Fabia 1.8t Build Thread (ex 1.2 12v)
I suppose another 5mm could clear the bit that fouls. Only have 10mm spacers at the min.
  • Replies 978
  • Views 143.9k
  • Few parts to add to the list.. And new 'daily/drive to track day' wheels arrived. And fit :-) Then i've been to collect some of Bens parts he's no longer using on his Fabia.. Fibreglass boot,
  • All fitted, all rattles and clonks gone. This Scale suspension is the shizzle. So well made its defintly worth the money. Damping set to halfway (6 clicks out of 12) Up on the ramps stripping everyt
  • Fitted driveshafts and all bolted up. Wheels on and lowered to the floor. All intercooler pipework installed, just front bumper to chop up to fit.   Started it and it runs!!! WHOOOOOOO
Looking good mate getting there, did you get all the deletes coded out too with the deimmobilise ?
Na.. Just immobiliser turned off. I have vagcom anyway so will know what faults there are.
I'll get that done when i take it to get mapped on the rollers [emoji106]
Finally got round to the wiring today.. Sorted it out.
Then got it in the car..
All in and the main things plugged in. Still need to run some wires under the carpet in places and sort the rear out.
After help from Dan i got reid of the evap system and sorted out the fuel lines.
Tried starting, it only turns over and not firing. Hopefuly something simple, will have a proper look tomorrow after work.
https://vimeo.com/141102627
Fault codes..
Might have been damaged doing immobiliser, easy to do, good to see it runs
Spent the day messing around..
Scuttle pannel and wipers are back on.
Ibiza transfer tower is in and connected up.
Fitted ibiza exhaust hangers.
Tidied up some engine bay wiring.
Fitted new battery box and lid as mine had all smashed. Managed to snap a 40A strip fuse when tightening the nut back down.
New ECU will be here tomorrow..
Had a play with my brakes to get a good 2mn clearence between barrel and caliper. Then give then a quick coat of paint where ive grinded them.
Started to gut my cat.. What a ball ache. Wish i never started it [emoji23]
Tomorrow i will refit interior and hopefuly have a go at bleeding the brakes/clutch etc (not looking forward to refilling the system)
Spent the day sorting the interior out. Heater isn't wired up as the ibiza had climate and fabia has A/C and electronic heat adjustment. So need to find a manual fabia heater and then wire up fan. Not overly bothered at the moment.
Seats back in.
Just rear lights to wire in and bleed the brakes.
Rided all the VWs at the scrappy for useful spare parts.
ECU arrived, fired up straight away.
Sprayed a spare easher bottle and coolant cap black to see what they looked like. Dont think theyre too bad.
Tomorrow i WILL do the brakes[emoji23]
Buy a mk2 leon mfsw ;) and a skoda badge...
Na, gonna get after market. No use having a mfsw with no radio [emoji23]
It'll all be getting stripped out next year.
Getting there bud :)
Spacers arrived for front. Went with 15mm.
Had a good play on VAGCOM and sorted a few issues out..
Airbags have all been removed, the light flashes 7 times then goes out on the dash so should all be ok.
Just rear beam to swap over and fit the sensors to remove the last two lights [emoji5]️
Exhaust tomorrow then a test run. (If im fit as im going round York this afternoon)
[emoji41]
Please get a video of the test drive man ha nearly there now!
Airbags have all been removed, the light flashes 7 times then goes out on the dash so should all be ok.9c37c3cd125749a5d2e91d6398c8a569.jpg
Just rear beam to swap over and fit the sensors to remove the last two lights [emoji5]️b3500cbd9958753970f4a124e7569de1.jpg
[emoji41]
You fitted the crash sensors then :)
came on fast! good work man!
I dunt mess about [emoji23]
Should be done soon
I'm soooo excited for this build thread... It's come along way in such a short time. Well done man
I want pops too :(
May see come Christmas when my insurance is due if a switch of insurer will allow me to run a decat :) Mine tries to pop but can't manage it :(
I want pops too :(
It says subtle but its ****ing loud [emoji23]
It says subtle but its kitten loud [emoji23]
 Hehe.
I'd probably end up annoyed at it as I tried to remain incognito... like my dam filter. Got a comment from a client that he heard me coming and I wasn't even doing anything daft... its just quite bassy on overrun from ~3k down.
Ill het a proper vid tonight [emoji23]
MEOW!  Roaarrrr!  :D
So i sorted the drivers headlight tonight.. What a ball ach, none if the pins wanted to come out. One snapped and another pulled out of the pin.
Sidelight..
Headlight..
Indicators..
Main beam was ok to start with.
Did notice the motors turned on and adjust fully, but now i have no adjustment on the headlight switch.
Also noticed the car was in limp mode.. Didnt bother plugging in though.
